2010 2011 BMW 5 Series Forum F10 2015 Adaptive LCI LED Headlights Upgrade |
05-26-2018, 06:16 AM | #89 | |
Rep 1,214
07-04-2018, 10:38 PM | #90 |
Rep 953
These guys are using image from this thread to sell their fake LCI LEDs..
https://www.ebay.co.uk/itm/Full-LED-...4697%7Ciid%3A1 |
07-05-2018, 10:13 PM | #91 | |
Rep 590
11-24-2018, 11:50 PM | #93 |
Rep 590
08-13-2019, 07:57 AM | #98 |
Rep 8
Help!!!
Bought a pair of very expensive OEM led headlights for my Pre-lci F11 (Xenon) and i've got no clue where to start.
Need help with wiring and what FRM 3 module that will work. My current FRM is 61359247062901 Have ZGW and NBT retrofitted and a computer with ESYS but i'm to scared to try programming myself. But I could do it with assistance or perhapps get help through teamviewer I've also bought a mirror that has S5ACA Headlight assistance in case it will be needed for the install |
08-13-2019, 02:31 PM | #99 | |
Rep 953
08-13-2019, 06:01 PM | #100 | ||
Rep 590
08-14-2019, 03:18 AM | #101 | |
Rep 8
A whole harness!?! Ive heard that three cables to FRM from rear fusebox and one from the one in the glovecompartment. Two CAN wires to each headlight.. But my senses tell me that two of the wires from rear fusebox should go straight to the headlights instead? But all of this makes me wounder if its better to try to sell the lights instead |
08-14-2019, 12:25 PM | #102 |
Rep 953
Its 3 cables from rear fuse box to the headlights, 1 wire from front/glovebox fusebox to headlight (NOT FRM). for a total fo 4 power lines to the headlights. Then you have to get 2x CAN 3 cables to each headlight from the ZGW. And then LIN cables from FRM to Headlights. Total of 8 wires to each headlight and you can buy the headlight connectors as well as all the other connectors.
Some ppl have used some splicing of other power cables but im not sure that's the safest as each headlight power line needs a unique fuse just for itself. Its not the easiest retrofit but its definitely doable.. |
08-14-2019, 12:27 PM | #103 | |
Rep 953
Some ppl have used some splicing of other existing power cables but i'm not sure that's the safest as each headlight power line needs a unique fuse just for itself. Its not the easiest retrofit but its definitely doable.. |
08-14-2019, 12:28 PM | #104 |
Rep 953
08-14-2019, 01:41 PM | #105 |
Rep 590
I'm thinking about adding NBT but what's the difference between that and CIC can you tell me ? and where are you going to purchase retrofit kit EbAy?
08-15-2019, 10:53 PM | #106 | |
Rep 8,364
08-16-2019, 12:48 AM | #107 | |
Rep 8
Thank you! Finally something that give me some clearance! This is very helpfull and makes sense, do i need new connectors as well? What about the FRM, do you know if i can use my old one? (6135-9247062.9.01) |
08-16-2019, 03:16 AM | #108 | ||
Rep 953
08-16-2019, 03:35 AM | #109 | |
Rep 8
It says FRM3 on my module but it seems that i need to exchange it.. Its just about 200$ for a used one so compared to the headlights its not so expensive |
08-16-2019, 06:29 AM | #110 |
Rep 8
