2010 2011 BMW 5 Series Forum F10 Final Stage Resistor / Blower Motor...Already? |
01-23-2015, 05:27 PM | #1 |
US Barvarian
11
Rep 57
Hey guys,
Searched all over with no avail... Wondering if any of you have had the Final Stage Resistor go out on your f10. My fan is acting up, on, off, slow, fast, etc. I am guessing its the FSR/Blower Resistor. I know on previous BMWs they have been fairly easy to get to/replace. Any one know the location for replacement? Passenger footwell? Car is a 2011 535xi with 68K. Just googled the PN. http://www.getbmwparts.com/parts/ind...&siteid=214672 Let me know. Thanks!
-mbrodie121
_______________ 2014 X5 50i M-Sport BSM/BK : 2007 E92 335i Montego/Saddle/M359/JB4 G5-ISO-FMIC-DP-CP-DCI : 2004 E46 M3 Convertible JB/Cinnamon/19 ZHP Wheels Last edited by mbrodie121; 01-24-2015 at 12:24 PM.. |
01-24-2015, 01:16 PM | #2 |
Rep 687
mine was acting up on my e46, but with that car, pull the fuse or battery first. let the car drain.
Connect it back and it works again. Happened to me twice in 12 years. Not sure if the same with our F10's now. |
01-24-2015, 08:55 PM | #3 |
Rep 1,698
Yes, my e46 had problems with the blower resistor twice. No such issue with any BMW, including the F10 now, since then. But your description is exactly what it did on my e46 - lack of fan control speed - erratic behavior, up, down, all over the place.
2017 BMW 650xi Gran Coupe | MSport | Exec Package | Driver Assist Plus | ACC Stop & Go | Adaptive Drive | B&O | Night Vision | Cold Weather | Active Seats
2015 Audi R8 V10 | Brilliant Red on Black | S-Tronic | Carbon Sideblades | Carbon Trim | Full Leather | Sport Exhaust | Illuminated Doorsills | I-Pod | Contrast Stitching Previous: '14 550xi, '07 335i, '01 325i |
06-14-2015, 05:03 PM | #4 |
Rep 1
final stage resistor location for F10
Hi,
I found the place where the F10's final stage resistor is located. The blower motor assembly itself is behind the cabin filter housing, on the passenger side. The top two speeds on my F10 (535i/2011) stopped working continuously earlier this month so I started researching the issue. The resistor is located right below the duct (on the blower motor assembly) that connects the filter system to the blower motor. Unfortunately, that means it's behind the fuse box--and the resistor itself is relatively long. One side of it (with one of the torx bolts) sticks out and you can see it looking into the fuse opening from the glove box, but the other side is about 3-4 inches towards the firewall, and there's another torx bolt there. I'm not sure exactly how to proceed with replacing it just yet. I don't *think* it will require a dash removal but it may indeed require a few components to be shifted around at the very least. My current thinking is that the fuse box needs to be dismounted and moved towards the passenger side door to give enough room to access the torx bolts on both sides of the resistor (as well as its connectors--it has two). But this is a work in progress. I may just give up and take it in to the local mechanic..if anyone's had success here with a DIY I'd love to hear about it. Bill |
06-16-2016, 11:13 AM | #5 |
Rep 1
2011 f10 Final stage unit
Just wondering if anyone had any updates on replacing the final stage unit in a f10 is it something you can do yourself or does it have to be taken to a dealer?
06-27-2016, 01:49 PM | #7 |
Rep 249
I replaced my resistor and my blower motor. The resistor is on the bottom of the blower housing. If you have questions, or can't figure it out, let me know.
http://f10.5post.com/forums/showthread.php?t=1213317
2011 BMW 550 i / Sophisto Grey / BMS Stage 2
07-04-2017, 11:46 AM | #9 | |
Rep 30
I didn't replace my blower motor resistor or FSU however by following this you can get to it. its right underneath the blower fan once you remove it. How to remove leaves/debri from blower motor BMW F10: How to fix the Blower motor housing with missing foam: |
07-04-2017, 03:49 PM | #10 | |
Rep 29
