2010 2011 BMW 5 Series Forum F10 N63 Alpina Turbos Installed |
03-27-2016, 09:53 PM | #1 |
Rep 163
Finally got around to installing my rebuilt Alpina turbos this weekend. Just wanted to share the experience in case anyone else decides to go this route.
I bought the turbos for $500 from an E30 forum, in "working when pulled" condition from someone at a dealership. After receiving the turbos, I noticed that one had very bad axial shaft play (I measured .005"). I contacted 5 companies that rebuilt turbos and only one was up to the task, Pure turbos. I paid a little over $1000 for the rebuild. I was very happy with their work besides the fact they forgot to mail them back to me on time, and then 2-3 weeks later when I emailed asking the status they never responded and just put them in the mail. My parts list from BMW for the install: (sorry, lost the description for what they are, but they are all the crush washers/gaskets you would need) 07119963201 x8 11428624158 x2 07119963072 x4 11657577018 x2 11627576991 x2 After receiving: View post on imgur.com I started the install at 12:30 in a friend's garage. Airboxes removed: View post on imgur.com Stock turbos with heat shields removed: View post on imgur.com Stock intake: View post on imgur.com Turbos removed: View post on imgur.com View post on imgur.com View post on imgur.com Surprisingly, my old turbos with 63k on the clock had extremely minimal shaft play. I'm impressed. Old vs new: View post on imgur.com Visually, they're exactly the same from the housings. If you look at the compressor wheel you can see they have an obviously different design. New turbos installed: View post on imgur.com Cranked the car in small intervals without starting to prime the turbos then fired her up. Ran perfect from the start and no issues. After a test drive...I'm moderately disappointed. I can feel an improvement on the low end, in comfort mode the torque is hitting a lot earlier than I normally would expect it to. On the high end...I don't feel much of a change. I'm on the basic BMS S2 settings still, and have stock downpipes, so I feel like if I turn up the boost/aggressiveness I would notice it more. I do think these would make a huge difference on a TU where a flash tune would be possible. Also, it's worth noting that I was planning on installing an intake so I left the airboxes open essentially as a hot air intake. With the intakes installed I may notice a much bigger difference. Overall, the install wasn't that difficult, but a lot of the time is spent cursing and trying to access the bottom v-bands and oil drain lines. I was able to finish in about 5-6 hours. If you're thinking about going this route and have any questions let me know!
03-27-2016, 10:05 PM | #2 | |
Rep 2,416
You need less back pressure and crank those suckers up in boost.
2011 550i RWD 60-130 7.35
m5james432.00 |
03-27-2016, 10:14 PM | #3 | |
Rep 163
I've also been silently hoping we get a flash option for the DPs but I know that's never going to happen
03-28-2016, 11:12 AM | #5 |
1506
Rep 676
Drives: '17 F31 340xi US Spec
Nice and quick installation. Sadly, the downpipes are not going to help you very much. For sure will see some improvements, but not much. The reason you are disappointed is due to the fact that your DME is not calibrated to run those turbos. The turbo efficiency, turbo curve, volumetric efficiency, wastegate operation and much more are very different on a 550i vs alpina. The sad part is the fact that you can not fix that without a proper reflash and JB4 can not do anything to help it.
Turbo flow characteristic map. Top is 550, lower one is Alpina. Part of wastegate function. Top is 550, lower one is Alpina. |
m5james432.00 |
03-28-2016, 07:50 PM | #6 | |
Rep 163
But wow, are those tables directly from the DME? I'm impressed at the level of complexity that these ECUs have. There's so much more than just igntion/fuel anymore.
03-28-2016, 09:58 PM | #7 |
1506
Rep 676
Oh yeah, the dme has about 35 of similar maps used just for turbo/waste gate control.
03-29-2016, 03:05 PM | #8 |
Rep 14,521
so $1500 all together with no benefits whatsoever? sorry to hear that!
03-29-2016, 10:22 PM | #9 |
Rep 436
Sleeping giant. Mentioned earlier, couple it with M5 DP's and exhaust. Open the JB S2 to maximum boost with waste gate posotion 1 and pure 100 octane with a can of TORCO and there you got it. 548RWHP
03-29-2016, 11:41 PM | #10 |
Rep 785
I personally didn't want to bother with any turbo upgrade on my N63 simply for the fact that there is no actual tune available.
No point in adding more air if you can't control it, that's pretty much the bottom line. BMS gets the job done in stock form but it's in no way a 'tune' but a workaround. From what I understand from Terry@BMS is that how the N63 piggyback works is, in the boost on S2 is only going to retard the timing more and cause the computer to make adjustments. Being that the engine/components work more than they actually need to because it's compensating for what is supposedly being 'loss' since it tricks the ECU into thinking it's being 'under-boosted.' On top of that, I would not run Torco daily. You're better off doing a 40% E85 mix, it's cheaper too. It's been proven that Torco or any Octane booster has negative effects (research all over the net) while there are no facts regarding E85 usage as long as it doesn't sit in the tank for a long time but that's the same with any fuel. Last edited by SLVSRFR; 03-30-2016 at 07:10 AM.. |
03-30-2016, 07:01 AM | #11 |
IG @bmwF9xG80
3817
Rep 7,595
MattPro yep definitely gotta get tuned even if you don't get downpipes now or yet, although with flash tune you will pass emissions due to the CEL delete software properly tuned flash.
MissionPerformance correct me if I'm wrong
60-130 6.5s X4M
60-130 5.04s G80 M3 Stock Turbo 60-130 4.82s | 9.4@148mph 1/4 Hybrids IG: @bmwF9XG80 |
03-30-2016, 07:11 AM | #12 |
Rep 785
There is no tune for the N63. Only for the N63tu
03-30-2016, 10:06 AM | #13 |
1506
Rep 676
Yep that is right. Also because these turbos have diverter valve, they won't work on N63tu as plug and play.
If OP want to get rid of them, we will gladly buy those turbos and adapt them to work on Tu since we already have a proper time for those. |
03-30-2016, 01:36 PM | #14 |
Rep 14,521
It's always great to hear people try new things and it's always a platform for others to follow. This would have been a great upgrade if it worked! Appreciate you trying! I've been contemplating for next year to upgrade my turbos to the Pure2 upgrade and see if MP can tune it? We'll see!
03-30-2016, 02:25 PM | #15 |
Rep 203
548 rwhp? I'm not a pro on this stuff, but that sounds like a stretch to me. What I would bet money on is no gains in that situation being contributed to the Alpina turbos. Lastly, even if the car did put down those numbers with the mods you mentioned, the original poster was probably hoping for daily driving power gains, not just when running race fuel.
03-30-2016, 06:41 PM | #16 | ||||||
Rep 163
If you can get a flash tune I would definitely do turbos, it's amazing how much they help on those 6 cyls Quote:
But yup, running more than 100 octane is pretty crazy for my goals right now haha
03-30-2016, 08:17 PM | #17 |
Rep 436
By all means, it is all good information. Indeed running pure 100 octane+Torco is not the healthiest thing, however, replacing the original OEM turbos with Alpinas we noticed a yellow like slightly abrasive residue around the turbine and compressor section. This does no harm to the susceptible components with the exception of the O2 sensors, sounds arrogant although is not the intent. Another advantage to the setup is a 3 minute transition from MAP 1 to MAP 0 with JB S2 pr just lower boost when back to 93 Octane pump gas. It is all good....IAG.....
03-30-2016, 08:47 PM | #18 |
Rep 436
To the guys at Mission Performance,
I am thinking about ordering brand new OEM 2013+ Alpinas GT2260 from Garrett. In my book the gains were substantial willing to take the risk of a $4000 cost. My current Alpinas will be available for $1500 if anyone wants to grab them. |
03-30-2016, 08:55 PM | #19 | |
Rep 203
03-30-2016, 09:10 PM | #20 |
Rep 436
Good question;I am attached to this vehicle since its European delivery. It has 18500 miles (mostly work overseas while the car sits Georgia). I recently sent in the last payment in exchange for a title. I am not independent or wealthy avoiding another cycle of payments.
04-05-2016, 03:30 PM | #21 |
Rep 163
Well.... I am officially an idiot. Ever since installing the turbos the car has felt so slow to me. Smooth as before, but still slow. So today I finally had time to do some datalogging to figure out why.
Connected the JB4 interface, and then it hit me. I have been in map 0 ever since installing the turbos. Turned it back to map 1 and man, it does feel faster. The only issue is that I think the turbos are spooling a little too fast for the JB4 and the boost is spiking to about 18psi and it has to pull it back fast. But wow, I'm an idiot
04-05-2016, 05:14 PM | #22 |
Rep 249
I'm running stage aggressive at 3.5, I have the Bluetooth adapter and the JB4 app and boost spikes to just a tick over 18 psi on the app.
Nice to hear this may not be a total bust for you. |
