10-23-2017, 12:22 PM | #1 |
Rep 78
Drives: 2013 BMW 535i M Sport
20 inch rims tire help
Calling all resident tire experts!
These came off a M5 and will be going on my 535i M-sport. Fronts: 20x9 ET 20 Rears: 20x11 ET 36 Which tires would you all suggest for the above rims. Looking for a bit more meat to protect the rims and no rubbing issues. 245/40, 285/35 245/35, 285/30 255/35, 295/30 Open to other suggestions, thanks!! |
10-23-2017, 03:37 PM | #3 |
Rep 78
10-28-2017, 12:49 AM | #5 | |
ZEROdoubleZERO
228
Rep 659
11-01-2017, 11:43 AM | #7 | ||
Rep 78
I forgot to mention, these are 343's... they are Rohana's RFX5's. I'm goign to try the 295's in the back.
11-02-2017, 09:58 AM | #8 | |
ZEROdoubleZERO
228
Rep 659
They will stick out past the fenders front & back and the rears will rub. The M5 has wider front fenders and I currently have 20x11 et +38's on the rear with 295's and they poke past the fenders by 6mm (yours at +36 will poke 8mm) and they rub, so the M5 must have wider rear fenders or narrower rear axles. I have a 550 and those wheels are the wrong offsets for Your car. You'll see when you put them on, if by chance they do fit without sticking past the fenders they are not the offsets you mentioned. Its also possible the M5 owner ran alot of negative camber to make them tuck?? Good luck you've be warned by the experts. Post some pics of them installed. Also try calling Rohana and asking them, they will tell you they are "Aggressive fitment" which is wheel manufacturers code for "they'll stick out past the fenders and look like shit!" Call them, trust me. Last edited by Teddylongtooth; 11-02-2017 at 10:17 AM.. |
11-02-2017, 12:10 PM | #9 |
Rep 14,521
305's will not fit on a F10. I'm running 295's with an aggressive offset
11-07-2017, 11:37 PM | #10 |
Rep 17
sorta in the same dilemma
have a 535xi Mport Currently have the bmw oem 312 / 20 in wheels with ac schnitzer springs(drops about an inch) current wheel setup front - 245-35-20 - continental a/s dws - Front Wheels: 8.5Jx20 ET33 rear - 275-30-20 - continental a/s dws - Rear Wheels: 9Jx20 ET44 wanted to know if I can increase it to 245-40-20 or 255-30-20 - front 275-35-20 or 285-30-20 - rear will it cause vibrations.. or rubbing. any help would be appreciated. |
11-09-2017, 11:19 AM | #11 | |
Rep 29,212
11-27-2017, 01:56 PM | #12 | |
Rep 78
The 255/35 in the front fit fine with no rub. You are definitely right about the backs rubbing at 295/30. They rubbed but just BARELY, I would have to hit huge dips for the tires to hit the fenders. So I went with 285/30 and there are no rubbing issues at all. |
11-28-2017, 07:33 AM | #13 | |
Rep 14,521
11-28-2017, 11:00 AM | #14 | |
ZEROdoubleZERO
228
Rep 659
11-29-2017, 07:43 AM | #15 | |
Rep 14,521
Teddylongtooth228.00 |
11-29-2017, 07:51 PM | #16 | |
98
Rep 305
I'm on 20x11 +28 rears with 295/20/20. I raised to 1 finger gap on coils and no rubbing. |
11-30-2017, 11:30 AM | #17 | |
ZEROdoubleZERO
228
Rep 659
Heres a pic of my 20x11's +38 with a 295/30r20 on h&r springs with the tire in the wheel well, looks like it's rubbing to me... Last edited by Teddylongtooth; 11-30-2017 at 01:16 PM.. |
11-30-2017, 11:49 AM | #18 | |
Rep 78
View post on imgur.com Also my car is on the stock suspension, which I'm still debating if I want to lower |
11-30-2017, 01:17 PM | #19 | |
ZEROdoubleZERO
228
Rep 659
11-30-2017, 01:30 PM | #20 | |
98
Rep 305
Here is 275/35/20 on 20x11+35. One size down from your current. |
lsturbointeg9188.00 |
11-30-2017, 02:26 PM | #21 |
Rep 14,521
yup! i kinda figured it would have a really stretched look
11-30-2017, 02:28 PM | #22 |
Rep 14,521
see...with that offset and the smaller tire 275's it actually looks like a pretty damn good fitment
