2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum Replacing peeling buttons question
      02-24-2019, 06:30 PM   #1
BlueSander
Drives: M550i
Hi guys,
So as many of you have known, the F10 has some serious problems with peeling buttons by the climate control area. I was able to replace the fan buttons easily. However, I would also like to replace the AC & heated seat buttons as well. Have any of you able to pull them out? I thought I should ask first before breaking something here.
Thanks
      02-24-2019, 07:28 PM   #2
Damage Inc
Damage Inc's Avatar
962
Drives: 2017 M2
subscribing
Current: 17 OG M2 / 21 Huracan EVO
Past Performance Cars: 01 M3, 05 M3, 06 M5, 08 M6, 08 M3, 11 M3, 13 M3, 15 M3, 911 C4S, 911 GTS, 17 M2,R8 V8, R8 RWS, 22 R8 Perf, 22 Lambo EVO
      02-27-2019, 10:28 PM   #3
Encendido3
Encendido3's Avatar
Drives: 2016 535i M Sport
I'm in the same boat. Curious to see what others have done
      02-28-2019, 10:34 AM   #4
Qsilver7
Qsilver7's Avatar
Drives: F06 650ix GC / F15 X5 50i
Just out of curiosity...those that have this issue...do you touch your buttons often? I only ask because it is so rare for me to touch any of the IHKA buttons because I let the AUTO feature do its thing. It's only on rare occasions like the MAX button during a heat wave...or the REST feature when doing short errands when its really cold and the heated seat button. But the fan and temp speed buttons rarely get touched. Again, just curious to know...and not for any condemnation.
Here's a link to the TIS website that gives instructions on how to replace the IHKA buttons: https://www.newtis.info/tisv2/a/en/f...ols/1VnXKCffWs
Do note that there is a special removal tool (00 9 340) that facilitates button removal...but the tool can probably be easily fashioned from something you have around your home. Here's a pic below of the tool...and if you click the link above to the TIS website...there's more images:
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral.
      02-28-2019, 11:04 AM   #5
TTG
TTG's Avatar
Drives: M340
Great information and I am 100% with you.
To me, it seems like, these are the folks who do not know how to use the "Auto" function of the unit. When necessary, touching the knobs to adjust the temp makes sense but not the actual buttons.
It is super rare occurrence if I ever had to touch any of the buttons.
Now, heated seat buttons, completely different story
2016 F10 535i xDrive - AW - Retired
2011 E92 M3 - AW……………....ED April 29th, 2010 - Retired
2007 E92 335i -Space Gray.....ED Oct 19th, 2006 - Retired
      02-28-2019, 11:12 AM   #6
Surly73
Drives: '11 535xi 8AT KWv3 MPE MHD xHP
I am curious about successful and cost effective button replacements for the fan buttons.
That is the one adjustment I make, especially for a long period where IHKA -> OFF_MEMORY was not coded on my car.
Generally, when I'm short tripping on work days to my commuter train station I have IHKA off, unless conditions (number of occupants, outdoor temp) causes my windows to fog. I'll then turn on one segment of manual fan at, say, 17C.
On longer/normal trips, then I'm full AUTO.
My driver's side fan button has one failed spot in the little fan logo. I'd replace it if it was easy.
      02-28-2019, 12:01 PM   #7
BlueSander
Drives: M550i
Mine isn't all that bad. However, let say the heated seat buttons, which I use quite often, wherever you see the black color (aka painted) by itself and surrounded by lighter color (aka unpainted area), over time, that black color peeled off. The rest of the button is good but at night, the light goes through that area which is larger than usual which catches my attention easily and annoys the hell out of me.
I got the whole set of buttons for $57 shipped from ECStuning 100% authentic BMW parts. I replaced the fan buttons already with ease. Heated seat passenger side and the AC button are the next 2. I have similar problem with the trunk release button and the mirror folding button, both missing a tiny black dot but it drives me nut knowing that I can't replace those 2.
      02-28-2019, 03:15 PM   #8
Encendido3
Encendido3's Avatar
I know in my case the PO had worn the buttons out pretty badly. I'm in the process of fixing the little nuisance issues here and there.
Thanks for the info!
      02-28-2019, 04:33 PM   #9
BigKutta
BigKutta's Avatar
2019 330xi  [10.00]
2017 Audi Q7 3.0  [0.00]
2020 M2C  [10.00]
Do you guys punch your buttons, or press with a stick? My buttons are perfect after 7 years
      03-01-2019, 11:30 AM   #10
Qsilver7
Qsilver7's Avatar
