2010 2011 BMW 5 Series Forum F10 My n63 intake build from stock to complete front facing CAI |
03-21-2021, 07:20 PM | #1 |
Cole
324
Rep 498
Accidentally posted in the wrong section before.
I'll make this short and to the point. I, like many other n63 owners paid a good amount for the ARM intake. Now, the intake is great quality and I'm not saying anything negative about it. But........I decided to try something i haven't seen done and it worked perfectly. I ordered the intake ducts from an x5m which point forward and installed them with an maf housing from a chevy cruz and a cone air filter. It sounds much better than the ARM intake, definitely has smoother throttle response, and only cost half the price. X5m intake ducts on amazon-$165 for both 13717638569 13717638568 https://www.amazon.com/dp/B00XKU78CU...p_mob_ap_share https://www.amazon.com/dp/B00XKU78CU...p_mob_ap_share Maf 3" housing from Chevy cruz- $80 for both https://www.amazon.com/dp/B07T9FQVJN...p_mob_ap_share Cone air filter-$60 for both Total- $305 Pics below. I am planning to extend them into the front grills later. One of the biggest advantages Is I can now change sparkplugs and coils without removing anything. I know my filters look a little beat up and they are going to be replaced shortly. Last edited by AnotherM; 04-10-2021 at 02:41 PM.. |
03-22-2021, 08:30 AM | #3 |
Cole
324
Rep 498
03-29-2021, 02:44 PM | #5 |
Rep 47
Drives: 2015 550i
03-29-2021, 05:14 PM | #6 |
Cole
324
Rep 498
I have a 2012. I wouldnt imagine you would have any fitment issues. The intake ducts would fit no problem and you may actually have more space for the filters than i do becuase my coolant reservoir is in the fron while yours was moved to the back.
04-02-2021, 10:20 AM | #7 |
Cole
324
Rep 498
Update:
Depending on how restrictive of an air filter i used, i started getting random bank rich codes. What it appears was causing this is actually how high the cruz maf housing positions the MAF. To fix this, i cut about 1/2" off of the cruz flanges, tapped new bolt holes, and than for fun painted them white to match the car. Overall, pretty simple project, but tedious. |
550bye1453.50 |
04-02-2021, 10:50 AM | #8 |
Rep 31
Drives: 02' x5 4.6i | 99' 540i/6
I like it, I've been wondering if there was an easy way to get rid of that looping back intake tracts, seems unnecessary. But I'm wondering, why place the filters under the hood? Seems like they would be taking in a lot of hot air right there.
04-02-2021, 10:57 AM | #9 |
Cole
324
Rep 498
Definitely, i plan to extend them into the grilles eventually. Im waiting until its hot out to see what my IAT are. Right now they are actually lower than they were with stock piping. It has bern pretty cool out until now so i plan to watch the IAT this weekend
04-03-2021, 03:59 PM | #10 |
Cole
324
Rep 498
All of the modifications i did to the MAF housing worked perfectly. Car is running as strong and smooth as ever.
It has been mid 90s today so i decided to feel the intakes after some driving and the filters were so hot i couldnt keep my hand on them. Obviously going to have to extend the filters into the grilles ASAP! Pulled great though..... |
550bye1453.50 |
04-03-2021, 11:10 PM | #11 | |
Rep 263
Can any of you TU guys answer to this???
2011 550i (N63)
Upgraded 51mm turbos, Heatsync Stage 3 Flash, JB4 stacked, BMS WMI, Arm Charge Pipes, Heatsync Catless DPs, X-Pipe, Res Muffler Delete, xHP Stage 3 Trans Flash, Turbosmart Diverter Valves, 3.5 TMAPs, Oil Cooler, Heatsync Front Mounted Max Cool Intakes, Walbro LPFP and e40 mix rollin on Stance SF07 9x20 w/Toyo Extensa and 10.5x20 w/Toyo R888R. |
04-06-2021, 07:59 PM | #13 |
Rep 31
04-09-2021, 07:25 PM | #15 |
Cole
324
Rep 498
Extended the intake into the grille
4-3" 45 2- aluminum 45 Last edited by AnotherM; 04-09-2021 at 08:46 PM.. |
550bye1453.50 hasanalothman0.00 |
04-10-2021, 01:33 PM | #16 |
Cole
324
Rep 498
I drove around today with the new intake set up and it feels very smooth. I do feel like the throttle response may be a little less aggressive and the sound is definitely not as pronounced, but i measured the IAT and it was significantly less than before. I have to wait until it is really hot to compare apples to apples and will post actual numbers if anyone is interested.
04-10-2021, 11:08 PM | #17 |
Rep 844
Are you tracking LTFTs and STFTs to see where your fueling is at? The MAF sensors are typically calibrated for a specific diameter MAF housing as they measure airflow and then calculate it based on diameter. If you got a rich code, youre already at least 30% off or more.
2014 M5 Competition with ESS Tuning Flash
Gone but never forgotten...2015 X5 50i M Sport, 2015 550i M-Sport, 2015 M3, 2014 X5 50i M Sport, 2015 435i M Sport, 2011 550i, 2011 535i |
550bye1453.50 |
04-11-2021, 08:35 AM | #18 |
Cole
324
Rep 498
I dont have any issues with running rich anymore. The problem was the MAF was positioned higher than it was designed so only half of the sensor was exposed to the air coming in. It was not able to get correct readings. All good now though.
I periodically watch maf, o2, and all fuel trims. I am now also monitoring IAT. Last edited by AnotherM; 04-11-2021 at 10:43 AM.. |
550bye1453.50 |
04-15-2021, 11:53 PM | #19 | |
Rep 263
Edit: sorry, didn't know video didn't work, here's a link https://youtube.com/shorts/XnrrxpVo7-o?feature=share
2011 550i (N63)
04-16-2021, 09:48 AM | #20 | |
Cole
324
Rep 498
04-16-2021, 04:32 PM | #21 | ||
Rep 263
I would order them before you pull your stocks ones off (if you have never before that is) because chances are that you won't be able to put them back together. My OEM DV's fell apart into pieces so definitely worth the purchase. Don't quote me on this, but I believe if you don't like them within the 30 days of purchasing them then you can return them minus the shipping and taxes. The sound is 10 times louder then the stock ones though. Far better design and construction though, I would it's a must for all N63's and really all BMW models.
2011 550i (N63)
04-29-2021, 11:01 AM | #22 |
Rep 31
It looks great! I was wondering, from what I'm seeing, you must have attached the filter right to a silicone hose. Did you happen to cut a small strip of 3" tubing to slide inside the silicone hose then have both the hose and the filter attach to that?
I haven't seen anyone address this. And this is something I have also seen in other posts, but no one ever goes into detail on how or why? Can we just unplug the MAFs? Does tuning need to be done? I mean I can unplug the MAF on my LS Chevy and it'll drive fine, but it just goes to stock fuel maps when you do that. But that is a very simple engine. |
