01-26-2022, 12:12 PM | #3 | |
Rep 37
I'm not too savy with these things, I plan on shopping at Indies for these items. That being said, I just moved to Northern Virginia, any recommendations would be appreciated! |
01-26-2022, 12:41 PM | #4 | |
Rep 1,509
How long are you planning on keeping the car? If your main concern is the rumble, it's most likely the engine mounts. I would replace those and service the diff fluid first. Your seat mat is bad so a software update won't fix it. It senses if you have a person sitting in it or not. It's cheapest to replace the seat bottom or get a whole used seat to swap out. |
01-26-2022, 12:45 PM | #5 | |
Rep 37
I'm sure I can tackle the thrust strut and bushing; but dam that engine mount looks exhausting... |
01-26-2022, 12:57 PM | #6 |
Rep 1,509
It's actually not that hard. You can easily access it from the bottom. One bolt on top of the mount and three underneath it. Work on one side at a time. Use a small jack and a block of wood to lift the engine up slightly so you can wiggle the mount out
