02-22-2024, 03:48 AM | #1 |
Rep 1
523i F11 SLOW heating
I have a 2011 F11 523i 3.0. It is VERY slow to warm up, it takes at least 20 km before both cooling water and oil are at 90 - 100 gr. The oil temperature never gets above 95 gr. My mechanic has replaced both the thermostat and the oil heat exchanger with the small thermostat. It's still the same. The dampers in front of the radiator work as they should. They are closed until it warms up. If you come from driving on the motorway and onto a normal road, the oil temperature slowly drops to 80-90 degrees and the water temperature also drops. If I have turned off the cabin heating/ventilation completely, it has an easier time keeping the temperature.
All help is gratefully received |
06-06-2024, 04:55 AM | #3 |
Rep 2
Also interested as I have the same issue and car (F11 with N53) as the OP. Have also replaced the thermostat and pump. Any pointers would be appreciated. Thanks
06-07-2024, 09:05 AM | #4 |
Rep 24
To try and avoid discussing it in too many threads at once:
https://f10.5post.com/forums/showthread.php?t=2108544 I'd be interested to hear more about what you've tried. |
