2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum F10 front door locks stopped working.
      06-16-2025, 11:21 PM   #1
Serf27
Serf27's Avatar
2983
Drives: 335i
Both of the front door actuators on my f10 stopped working. They don’t make any noise or move with the fob or interior button.
They manually work but that’s it.
I’m having a hard time believing that both failed at the exactly the same time.
The rear locks work fine.
The 15amp fuse in the glove box was good.
Ideas on where to look next before replacing actuators?
Thanks.
E90 335i-408WHP. Alpine over Terra brown
E70 X5 35i M Sport-Stage1 Tune. Alpine over Black
E91 328 M Sport-Alpine over Black-Alpine over Saddle brown.
E93 335i-DINAN tuned. Alpine over Saddle brown
      07-24-2025, 11:16 PM   #2
1ucky0ne
Drives: BMW F80, F07, F10
Thanks.
I can't also believe that both of them would blow at the same time. There are several fuses anyway and they should all be replaced, even if they look ok. It's worth browsing through YouTube, there seem to be at least 5 fuses, which ones are good to check, depending on the equipment level.
Did you check already error codes via ISTA?
      07-30-2025, 06:36 PM   #3
Serf27
Serf27's Avatar
2983
Drives: 335i
I checked all the corresponding fuses. They visually looked fine. No codes when I scanned with the protools app.
I’ve just been manually locking the passenger door and uses the metal key for the driver door.
I’ll check the fuses again and get a door actuator for the drivers side if that still doesn’t work. Maybe a soft close actuator.
