2010 2011 BMW 5 Series Forum F10 19s and meaty tires, or 20s |
11-19-2013, 02:01 PM | #1 |
Rep 348
Anyone have advice or opinions on what to do for new wheels and tires? The stock 19s on my car look miniature and the offset is obviously not great. But, I'm having trouble deciding between 19s and 20s for a new set.
With the 19s, I'd be able to fit a lot more tire on there - and I hate stretched tires that are too small for the wheel. I'm thinking something like this: If I went with 20s, I'd run a little less sidewall and maybe a little narrower, but still squared off. But, 20s will be more expensive. HOWEVER, will the 19s and a nice meaty tire be enough to fill the wheel well when dropped about an inch, or must I go with 20s for a decent look? Here's a great example of an F10 with 19s, but small tires than I'd run, but I won't be lowered that much: Thoughts? Advice? Thanks! |
11-19-2013, 03:43 PM | #2 |
Rep 8,279
You already said your stock 19's look minature so I wouldn't recommend you getting 19" replacements.
20" is the way to go and in regards to tires you can do 295/30/20 and 255/35/20 which will give you plenty of sidewall meat. |
11-19-2013, 03:59 PM | #3 |
Rep 147
Definitely go for the 20" rims, mine are 20x9.5 front, and 20x10.5 rear.
Black Sapphire 550i | HRE P40SC | H&R Springs | Active Autowerke's Exhaust & Downpipes | BMS Stage 1 | M5 Sway bar | V1
11-19-2013, 04:03 PM | #4 | |
Rep 348
Actively searching for more examples of 19 (seen tons of F10s with 20s and obviously they look great) to judge. |
11-19-2013, 04:32 PM | #5 | |
Rep 8,279
I'm local in socal as well. |
11-19-2013, 05:04 PM | #8 |
Rep 1,209
Something about the T1S tire in 285. They just sit so wide compared to other makes.
11-19-2013, 05:24 PM | #10 |
Rep 348
11-19-2013, 05:27 PM | #11 |
Rep 8,279
11-19-2013, 06:18 PM | #12 |
Rep 348
Haha, touche.
But, I've found that getting a car I need and dropping $5k on wheels/tires isn't the same when it comes to justifying costs. Although....they are pretty wheels. |
11-25-2013, 04:45 PM | #13 |
Rep 29
Drives: 2012 535i
Staggered Question?
Can someone please post a scientific or a definitive technical answer and not an opinionated answer to this question. This has came across my mind for sometime and is seeking a good answer. And maybe others are too.
- What is the problem with staggering wheels on a BMW of different sizes like they do on 'Vettes. 'Vettes runs staggered sizes; e.g. 18x8.5 front and 19x10 rear. This gives the car a more aggressive look with smaller/narrower tire front than back. Why not? what problems would it cause on a BMW? I'm just sayin'. |
11-25-2013, 05:47 PM | #14 |
Rep 348
On a RWD one, no problem really, other than perhaps something with the speedo. But, when staggered like on the Vette's you mentioned, the sidewalls compliment each other (larger up front, shorter in the back).
But, I've seen an f10 with some rake and it really didn't look that good; I would prefer it to be level. |
11-25-2013, 08:09 PM | #15 |
Rep 29
Drives: 2012 535i
Good reply and thanks for you insight.
12-14-2013, 05:58 PM | #16 |
Rep 683
If you go 20s, a fairly meaty rear is the 285-30-20 on a 20x10 or 20x9.5 wheel. In my opinion, 295s are too much tire. For the front if you go 20x8.5, do a 265-35-20, will work perfectly and give you a better look than the 245s or 255s. I have 255s and just wish I had gone 265 in front so it wrapped over the side of the wheel more.
12-21-2013, 10:01 PM | #17 | |
Rep 154
1996 E36 328i Touring
2000 E46 328Ci 2004 E46 M3 Dinan Exhaust 2011 535xDrive F10 AFE CATBACK, AFE SCORCHER, AFE Performance Air Filter, H&R, AR Down Pipe, ER Charge Pipe. |
12-21-2013, 11:27 PM | #18 | ||
Rep 3,047
2022 RAM TRX
2021 Ford Bronco 2022 BMW M3 |
03-11-2014, 05:45 PM | #19 |
Rep 1,138
sick!! any rubbing on that setup?
sent from bimmerpost Android app
03-11-2014, 05:47 PM | #20 |
Rep 1,138
did you ever rub on that setup? how did it ride?
03-12-2014, 09:41 AM | #21 |
Rep 1,209
Thanks.
I dont rub in that setup. Offsets were dialed in perfectly and am lowered on H&R springs
03-12-2014, 01:38 PM | #22 |
Rep 1,138
thanks! what were your offsets F&R?
