2010 2011 BMW 5 Series Forum F10 Confused with which tires I need |
04-19-2012, 07:43 AM | #1 |
Rep 409
Ok guys here is my situation.
I have a 535i non xdrive. I purchased the oem 331 wheels from a member that came off of an xdrive (does that mean they are 19x8.5 and 19x9.5?) or are they probably the same size all around. Tire wise- what would be the recommended oem setup for these wheels if I put them on my car and additionally what sizes would work without affecting the speedo? Would I use the same size all around or a staggered setup and what would the correct size be? Thanks! |
04-19-2012, 08:18 AM | #2 |
Rep 4,721
typical wheels setup for square xdrive:
19x8.5" ET33 245/40/19 However, there is a chance the previous owner may have a staggered setup, in this case, the rear would be (the front would not change from above): 19x9" ET44 275/35/19 Can you identify any marking on the wheels to see they are different/bigger ? What would you like to change to ? If you are sticking with the same wheels ? |
04-19-2012, 09:37 AM | #3 | |
Rep 409
If by chance they are indeed staggered wheels would using 245/40/19 all around be contraindicated or cause any problems? |
04-19-2012, 10:33 AM | #5 |
Rep 4,721
visually, you can line up all four wheels and see if there are diferent sizes. There should be marking at the back of those wheels as well.
By default on xdrive car: A square setup, then go with the factory spec. 245/40/19. If you want to go wider on the rear, you cannot do it with those rim. If by remote chance: If staggered setup, then you can go with square setup (no issue at all) or you can make the rear 275/35/19 (to make it a bit more aggressive) As for tires, lots of bloggers, incl. myself use Michelin PSS. Very good tires. Last edited by bobblehead; 04-19-2012 at 10:39 AM.. |
04-19-2012, 10:35 AM | #6 |
Rep 29,212
Yes, size and offset are stamped on the back of the spokes of OEM wheels. Offset will be marked IS, e.g. IS33.
04-19-2012, 11:47 AM | #7 | |
Rep 409
Thanks |
04-19-2012, 01:43 PM | #9 | |
Rep 409
04-19-2012, 01:43 PM | #10 | ||
Rep 409
04-19-2012, 01:49 PM | #11 |
Rep 4,721
May I suggest the following:
Since you already have a set of winter (17"), why don't you go with the new set of performance 19", instead of all season 19" ... the reason is you should get the most out of your high performance car with a high performance tires. They have much more better grip/traction in dry & wet. The all season will never achieve this type of performance. |
04-19-2012, 02:53 PM | #12 | |
Rep 409
