2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Navigation, iDrive, Audio, Video, Bluetooth, Phone, Coding BMW F10 Coding DIY (and other Fxx models)
      03-24-2014, 10:47 AM   #67
shawnsheridan
shawnsheridan's Avatar
Drives: 2018 Alpina B6 650ix GC
Depends what you are diagnosing with, but for INPA it is good.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant
2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE
      03-24-2014, 10:50 AM   #68
PaulGreatest
Russian Federation
Drives: BMW F10 528i 3L
With Rheingold 3.41.10, it's good?
      03-24-2014, 10:54 AM   #69
shawnsheridan
Depends on the version, but most support ENET via built-in ICOM Emulator.
      03-24-2014, 11:08 AM   #70
PaulGreatest
Russian Federation
Version of cable or soft?
      03-24-2014, 11:08 AM   #71
shawnsheridan
Depends on the Diagnostic software if it supports ENET or not.
      03-24-2014, 11:16 AM   #72
PaulGreatest
Russian Federation
Looks like it's support ENET interface, hope would work
      03-24-2014, 11:18 AM   #73
shawnsheridan
Yes, looks good to go.
      03-24-2014, 11:21 AM   #74
PaulGreatest
Russian Federation
By the way, what kind of soft would you prefer for diagnostic?
      03-24-2014, 11:39 AM   #75
shawnsheridan
ISTA/D...and performed by my dealer as my car is still under warranty.
      04-13-2014, 09:40 PM   #76
tinghei
Drives: f10 528i
need help, I installed e-sys on my laptop but I cannot connect via VIN, what did I do wrong? I got an error when I run ZGW_Search
      04-13-2014, 10:16 PM   #77
shawnsheridan
For proper connection:
1) Make sure motor is running if car is not on a Charger.
2) Make sure EDIABAS.ini (for Tool32 or INPA) is set for Interface = ENET.
3) Make sure Windows Firewall is disabled
4) Make sure all Antivirus programs are disabled.
5) Make sure LAN Adapter is set for DHCP and not using a Static IP.
6) The Target Connection Window should not be blank (It should show multiple target connections for different chassis').
      04-14-2014, 12:05 AM   #78
tinghei
Drives: f10 528i
Please refer to below
1) Make sure motor is running if car is not on a Charger. OK
2) Make sure EDIABAS.ini (for Tool32 or INPA) is set for Interface = ENET.Already set
3) Make sure Windows Firewall is disabledalready set
4) Make sure all Antivirus programs are disabled.already set
5) Make sure LAN Adapter is set for DHCP and not using a Static IP.I am using USB ENET cable, will that make a difference??
      04-14-2014, 12:17 AM   #79
shawnsheridan
What is a USB ENET cable?
ENET is LAN x OBDII.
      04-17-2014, 07:20 PM   #80
RASHID007
Drives: 2014 535d X-Drive
Long story short picked up a 2014 535d this week and the SOS emergency call malfunction will not go away and the dealer, BMW customer service and BMW assist have no idea how to fix it but are working on it. Apparently this is a problem with 2014 F10 and X5 vehicles. Here is a brief description: HELP - BMW Assist and Real Time Traffic http://f10.5post.com/forums/showthread.php?t=926790" rel="ugc" target="_blank">http://<a href="http://f10.5post.com...p?t=926790</a>" rel="ugc" target="_blank">http://<a href="http://<a href="http...926790</a></a>
Question: Anybody have any idea how I can did this with coding? Is there a setting I can set to active or not active etc? BMW assist says all is set up correctly on their end and it is something wrong work the car hardware or software.
Thoughts please?
      04-25-2014, 11:54 AM   #81
RASHID007
Since no reply to my question above am I safe to assume that no coding can help the BMW assist SOS error message?
      06-01-2014, 05:41 PM   #82
Arturo_spain
Spain
25
Drives: M760Li MY2018
E-sys files
Hello to all from Spain
Have a 535d xDrive EU & will try to code a few options. Shawn, I've been pointed to you for the latest working E-sys (3.24) & data files, I've already bought a one year token.
Thanks!!!
      06-01-2014, 06:48 PM   #83
shawnsheridan
Thanks!!!
PM sent.
      06-05-2014, 09:10 AM   #84
F10Thai
Thailand
Drives: 530e G30 / 528i F10
E-sys 3.23 cannot connect my car
Anyone please help me. I am using E-sys 3.23 program but cannot conncet to my car although it can see my car VIN.
[IMG][/IMG]
      06-05-2014, 09:28 AM   #85
shawnsheridan
Your Target Connection Windows is empty. This means either your PSdZData is not installed correctly, or you have not gone under E-Sys options and set the data path to point to your data folder. If your PSdZData is in C:\Data\psdzdata, then your E-Sys Data path needs to be set to C:\Data.
      06-05-2014, 09:32 AM   #86
F10Thai
Thailand
OK. I will try again. Thanks.
      06-05-2014, 09:52 AM   #87
F10Thai
Thailand
my Code awayDKF01.est shown expired. Where can I get the new one?
      06-05-2014, 10:26 AM   #88
shawnsheridan
PM sent.
