2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications F10 - N63,N63TU intake system
      01-18-2015, 12:55 AM   #1
ARC550
Drives: M3, X5, 720s, X5, 750xi
New intake system is going into production. Estimated cost will be $1000 each.
The system comes with 2X pipes, 2x filters and clamps, and heat shields for both sides. The picture shown is for a 2012 BMW 750XI.
      01-18-2015, 05:32 AM   #2
combatbmw
Drives: 20' X3M CP
2k? That's crazy
      01-18-2015, 06:11 AM   #3
Simple5
Drives: F90 M5 and E84 X1 Xdrive35i
Who's making it? Have they done any testing to see if the numbers are consistent? Does it throw codes? With heatshields this looks really promising! I would definitely pay 1k for this. I bet it sounds beast!
      01-18-2015, 09:45 AM   #4
paul223
paul223's Avatar
Drives: F10
Who is going to buy it?
      01-18-2015, 12:33 PM   #5
badblack550xi
badblack550xi's Avatar
Ok let me start this bash.
Arch this intake has been tested a year ago. In summer time it heat soaks and reduces power. It's sucking hot air that's trapped under hood from engine and turbo.
In parts this intake does not cost more than $200 so charging such a high price is absurd.
      01-18-2015, 12:51 PM   #6
gclions
gclions's Avatar
78
Drives: 2011 550i
Well, it would appear someone is trying to further my efforts. Good for them, and good for us. I hope the heat shields help, because without them heat soak causes hp/torque to nosedive.
I gave up, and sold what I had to someone who wanted to build a heat shield similar to one they had built previously for a different car. I'm not overly skeptical, it will work if it can be protected from heat soak, but the gains weren't promising enough to keep pushing ahead.
Crossing my fingers, I hope it works.
      01-18-2015, 02:10 PM   #7
badblack550xi
This design is same as 180 made and we tested that car would slow down every run... heat shield cannot deflect all the hot air that goes up and stays trapped under hood. And this is Same design as you made.
2011 550i RWD 60-130 7.35
      01-18-2015, 02:32 PM   #8
combatbmw
Drives: 20' X3M CP
Agreed with black. You can't make a product like this and charge 2k. Sure dinan is more. But it's dinan.. Has carbon fiber.. Air filters are where they need to be front.
This looks like heatsoak Ally.
      01-18-2015, 02:38 PM   #9
combatbmw
Drives: 20' X3M CP
I'd like to see a dyno of this hood closed and on a hot day. Cause if you leave this hood open it will make some power I mean those huge filters look pretty but I'm concerned real world hood closed.. I see alot of heat issues lots of hot air..
      01-18-2015, 02:47 PM   #10
badblack550xi
this intake will only work in winter when its so cold tha teven under hood themps are acceptable. once the summer starts these things will decrease power.
      01-18-2015, 03:01 PM   #11
Simple5
Hrmmmm... maybe something is different with this set up? Would be cool if they piped in cold air a la Dinan.... would be awesome to get a fully functional intake. I agree this set up should be no more than 1k... $200 in parts and $800 in r&d if it works....
      01-18-2015, 03:06 PM   #12
badblack550xi
there has been no R&D done tho =D M6beast is developing a full Cold air intake like he did for the M5 and M6 which allowed the cars to get in to 10's
      01-18-2015, 03:42 PM   #13
ARC550
The cost is 1k total.
Also, like the stock airbox is any better?!!
I will be conducting dyno runs with closed hood. Stay tuned.
      01-18-2015, 06:55 PM   #14
gclions
gclions's Avatar
78
Drives: 2011 550i
Arc,
Good luck brother. I have some dyno data if you need it from my intake setup. It lost power every run with the hood open.
I don't have timing data, but my guess is the ECU was cutting timing as temperature kept climbing. There could be some benefit of moving air at highway speeds, so I won't count out the idea just yet.
But, I would hold off on orders until you can prove it works. I wouldn't personally consider it until I knew I had something that showed a gain, but it's your prerogative, and good luck regardless.
2011 BMW 550 i / Sophisto Grey / BMS Stage 2
      01-18-2015, 07:19 PM   #15
RED99HT
Drives: 21 M850i
you might as well try to fit two toaster ovens in there as well
      01-18-2015, 09:34 PM   #16
badblack550xi
      01-18-2015, 09:37 PM   #17
ARC550
the stock intake system is 2 closed boxes that hold hot air! this is at-least open and exposed.
      01-18-2015, 09:39 PM   #18
ARC550
Arc,
I will try and conduct tests. If all goes well after 5-10 consistent dyno runs then we may have something on our hands. Thanks but I think i will start from scratch with a few tests and see what happens. It does not hurt to try you know!
      01-18-2015, 09:47 PM   #19
badblack550xi
you need to do the tests in summer time not when it's below 0 outside.
      01-18-2015, 11:10 PM   #20
ARC550
Worst case scenario I will run intakes in winter and revert back to stock in summer lol.
      01-19-2015, 11:02 AM   #21
Simple5
I'm staying tuned! If this pulls consistent numbers over several dyno pulls then i think it will be a winner. If I remember correctly the one company that tried to do this setup had numbers all over the place due to the ECU cutting timing..
If this works count me in!
      01-20-2015, 04:54 PM   #22
phil7027
Drives: 2015 550xi
If you need help with testing let me know I'm right in staten island. I have an idea also on how to keep the temps cooler near the intakes, same concept that was used on my mustang. If you want shoot me a PM
