2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums Regional Forums UK 19 Inch 351 Alloy Tyre Pressure sanity check ?
      03-15-2015, 11:26 AM   #1
shiner
Drives: 535D MSport Touring
Just checking.... The sticker on the drivers doorway states 220 for the front and 270 for the rear. 270 for the rear tyres seems quite high to me? That said I just followed what it said and inflated to those pressures this morning - have not driven the car yet though. They were at 245.....
Thankyou.
2015 F11 535D M Sport Touring, Space Grey, VDC, HUD, Comfort Seats, Sport Auto, Pro Media. GONE
2013 Z4 35is + tons of options. CURRENT
      03-15-2015, 12:22 PM   #2
SpeedTrip
SpeedTrip's Avatar
England
27
Drives: F21 M140i LCI-2 Alpine
Thats correct - I run mine a tad higher with a 10 stone Newf in the back !
Mine drops 10-15% after a month, so dont rely on the TPM warning !
M140i LCI-2 is the 16th BMW since 1977 ....
320i *2, 323i, 520i *2, 540i, 535i, 840i, E36 M5, 328i, 530i, 320d, 535d, M135i, M140i * 2
      03-15-2015, 03:32 PM   #3
shiner
Great stuff thanks for clarifying!
      03-16-2015, 12:47 AM   #4
AP
AP's Avatar
2880
Drives: G30 M550
What units are those? My sticker says (for 1 person in the car no luggage) 2.2 bar all round
More obviously if the car is loaded.
      03-16-2015, 03:39 AM   #5
Pottsy
Drives: F10 535d MSport
kPa, AP. Not the most commonly found unit of pressure when dealing with tyres in the UK!
The sticker in my car is definitely not "quick reference", with the wheel sizes in small print and scattered all over (this is a 535d F10, so not for use on an F11!).
      03-16-2015, 06:26 AM   #6
kbullet
Drives: F10
hmm isn't the 245/40 Front ones and 275/35 rear? i'm confused lol i've prob been pumping incorrect tyre pressure all these times!
      03-16-2015, 08:15 AM   #7
The Beast
The Beast's Avatar
Drives: VW Transporter Sportline
Your not reading the diagram correctly. The bottom right hand box is for the 19" wheels, within that box the first (left box) reading is for the front tyres and the second (right box) is for the rear tyres. Therefore under normal loads tyre pressures should be 2.2 for both front and rear wheels. When you have 5 passengers and suitcases i.e. the car is fully loaded then it should be 2.6 front and 2.7 rear.
Current: VW Transporter Sportline, F48 X1 20i M Sport. Previous: F10 530d M Sport, W176 A200 CDI AMG Evolution, E70 X5 3.0 SD M Sport, F20 120d M Sport, E81 120d M Sport, E46 325i M Sport, E46 318ci & Many Others...
      03-16-2015, 08:28 AM   #8
The Beast
The Beast's Avatar
Actually looking at it again you may be right if referring to 18" wheels... Really confusing layout that I've not seen before on BMW's tthat I have owned. My last two cars have had 20" wheels and the readings for these are all contained within one section rather than having to refer to two as seems the case for 18" & 19". To make it even more confusing it appears you have to reverse the way you read the front rear pressures depending on whether you have 18" or 19" wheels.
Madness!
      03-16-2015, 08:37 AM   #9
The Beast
The Beast's Avatar
Sorry to bombard with replies but just noticed OP has 19" wheels therefore the box marked as rear is actually front tyre pressure and box marked as front is rear for his set up...
      03-16-2015, 09:29 AM   #10
Pottsy
The marks on the diagram are for me! And I have 18" summers and 17" winters.
The OP has 19" wheels and an F11, so the diagram is not for him.
      03-16-2015, 09:34 AM   #11
Pottsy
That's why I posted it - look carefully and in fact the bottom right box is for 19" and 18" wheels. It's utter madness.
The 19" front is in the bottom right box (2.2 bar) and the 19" rear is in the bottom left hand box (2.3 bar). Scope for error is high.
      03-16-2015, 10:05 AM   #12
HighlandPete
Drives: BMW F11 535i Touring
Look at the tyre placard as tyre groupings for the same pressure settings, then it should make sense.
Any other format requires lists of pressures. (There is a bigger range of tyres than pressure settings). Maybe it's how my brain works as an engineer, but the BMW placards make perfect sense to me.
HighlandPete
      03-16-2015, 10:10 AM   #13
HighlandPete
Thankyou.
Same pressures for the F11 530d as my 535i. Tourings run higher rear pressures than saloons, wear balance is pretty even if you don't get tempted to lower them because you feel the pressure is too high.
HighlandPete
      03-16-2015, 11:21 AM   #14
kbullet
Drives: F10
yeah I have the F10 with 19" on mine, and have the exact diagram as yours. So its reversed on mine.
the 275/35 R 19 is the rear tyre but on the diagram it is the front
and 245/40 R 19 is the front tyre but on the diagram is the reverse
so it a bit confusing
      03-16-2015, 11:23 AM   #15
shiner
Well I did 140 miles in the car today and it felt fine with the higher pressure in the rears. As I said they were down at 245 so I did what it said on the door sticker.
      03-16-2015, 12:15 PM   #16
Pottsy
HP,
The BMW table would make perfect sense if you were to enter it with pressure data. "So I have 2.2 and 2.2, that means I have 19" wheels on the front and 18" wheels on the rear...."
These tables need to be designed so that you go in with the wheel/tyre size (nicely grouped) on the left, and you read the answer on the right.
To me the BMW table has been designed by someone clever, who has missed the point entirely!
      03-16-2015, 01:23 PM   #17
AP
AP's Avatar
2880
Drives: G30 M550
I'm going to check mine again tonight, I think I've misread it . Looks like its 2.3 bar on the rears (19 275/35)
      03-16-2015, 01:25 PM   #18
The Beast
The Beast's Avatar
Makes sense now, so much simpler with 20's
      03-16-2015, 01:29 PM   #19
The Beast
The Beast's Avatar
Yep 2.2 front and 2.3 rear for normal loads
It's basically a crap table!
      03-16-2015, 04:13 PM   #20
AP
AP's Avatar
2880
Drives: G30 M550
I've take a shot , excuse the poor quality from my 2012 model and there are slight differences. It seems I've been running my rear tyres at 2.2 instead of 2.3 bar since new for my 19 inch wheels. Glad I read this thread!
Very obvious when you read it carefully and seems quite logical.
      03-16-2015, 05:17 PM   #21
Pottsy
If I worked for BMW, this is how I'd do it:
      03-16-2015, 06:29 PM   #22
HighlandPete
Attachment 1175302
Yes, I follow the logic of the Jaguar placard and your own example for a specific BMW list.
All fine if you don't have to change the listing, within the same label size parameters. What would Jaguar do if they added another 3 tyres for example? Bigger label, looking even more overloaded with figures?
BMW use a format that can be easily modified with extra tyre specs as production moves forward, without needing a bigger label. Don't forget some placards have far more listings than your F10 example, I've an example with 14 different tyres, 7 in one of the pressure groupings.
What would Jaguar do in that instance, make a much bigger and even more cluttered label?
I guess some users would prefer that format, however big it had to be. But for me, the BMW format is just fine.
HighlandPete
