04-27-2015, 02:50 PM | #1 |
Rep 666
Normal, Sport, Sport +
ok newb question whats the difference?
Normal = Daily plodding Sport = more engine power & chassis option if you have now Sport + is this just sport without traction control or is there any more power given?
Current: 2017 M6 Gran Coupe
Previous:2014 640D GC 383BHP + 733NM, F10 2010 530d 520i (2000), E36 comact 318i, E46 M3, E46 318Ci, X5, Non BMW: 5x Skyline / GTRs, 5x Supras, 2x Nissan 200sx s14a, lots of other stuff |
04-27-2015, 03:13 PM | #2 |
Rep 5,320
sport changes the throttle response, so if you press the pedal say 3 inches in comfort mode for a given level of performance, you'd only press it say 1 inch in sport mode.
the gearbox will straight away change up to give more revs and it hangs on to the gears longer for maximum performance. it weights up the steering as well. Sport + is the same but changes DSC to be in DTC mode instead. All above is not assuming you have any dynamic suspension fitted. The difference between comfort and sport is very obvious that's the basics essentially. |
04-27-2015, 03:14 PM | #3 |
Rep 413
Driving Dynamics Control
The Driving Dynamics Control rocker switch next to the shifter lets you cycle easily through Comfort, Normal, Sport and Sport+ modes to vary multiple settings.
04-28-2015, 03:29 AM | #4 |
Rep 15,857
The above chart is a bit confusing and not correct.
BMW use the terms Drivetrain and Chassis, when we have the ability to split the two in the Sport menu, configured on screen via iDrive. Drivetrain = gearbox and throttle. Chassis = suspension and steering. I run with just the Chassis checked. When toggling from Sport to Sport+, besides activating DTC, it also adjusts the drivetrain (although not configured) to a sport setting. I assume the OP listing Normal, Sport, Sport+, doesn't have the Comfort option. Comfort (in the list with Normal) indicates an active suspension option. (VDC or AD). Early models with active suspension list Comfort, Normal, Sport, Sport+. Later models with active suspension list Comfort+ Comfort, Sport, Sport+. HighlandPete Last edited by HighlandPete; 04-28-2015 at 03:39 AM.. |
04-28-2015, 04:26 AM | #5 |
Rep 666
Thanks for the info
04-28-2015, 06:12 AM | #6 |
Rep 413
Thank you for attention to the details and your comment. It helps to improve things.
The above chart is taken directly from the official training "BMW Driving Experience" of the 2013. This way is how BMW explains these settings, so we can like it or not. I admit you are right: the word drivetrain should be replaced with chassis, sorry for screwing that up in fast translation. I did my best, and the rest seems to be fine. I also wish someone attends BMW training perfectly introduced in the proper language and than shares. Last edited by valbmw; 05-13-2015 at 04:13 AM.. |
05-11-2015, 03:17 AM | #8 |
Rep 15,857
05-11-2015, 03:53 AM | #9 |
Rep 1,597
Yep I'm sure you only get Sport + with SAT
Current: VW Transporter Sportline, F48 X1 20i M Sport. Previous: F10 530d M Sport, W176 A200 CDI AMG Evolution, E70 X5 3.0 SD M Sport, F20 120d M Sport, E81 120d M Sport, E46 325i M Sport, E46 318ci & Many Others...
05-11-2015, 07:07 AM | #10 |
Rep 666
Im loving the SAT gearbox, 8 speed and sits at 1500rpm at 70mph is fantastic, very smooth also
Yurisrus0.00 |
05-11-2015, 08:58 AM | #11 | |
Rep 1,597
I would be interested in trying the newer version with the GPS link...
05-12-2015, 03:14 PM | #12 |
Rep 158
I have the GPS box, and although the effects are subtle, they are also brilliant. Bear in mind this is a 535d, so change points might be different for different cars...
If you (on a straight) just lift off and let the car slow down, the box will change down at just below 1000 rpm, giving about 1250 rpm. If you do the same coming into a roundabout, it will change down (just before the roundabout) a little earlier, giving you around 1600 rpm - leaving you ready for the roundabout. It's always in the right gear as you enter a roundabout. Going up a motorway slip road, it goes into "frisky" mode, hovering around 2000 rpm minimum. As soon as you are on the motorway (as you cross the line) it scoots all the way into 8th. And as soon as you come off the motorway and get on a slip road, it drops a couple of gears. It's all quite subtle, but the net effect is that it always appears to be in the right gear - you never seem to get that press - wait - drop a gear - go thing. Possibly the best feature on my car (joint with AD). |
05-12-2015, 03:30 PM | #13 | |
Rep 666
that sounds really good, its the little things that really make a good car
05-13-2015, 02:45 AM | #14 |
Rep 1,597
Sounds great though as those are all situations that I would either manually drop the gears or shift the box over into sport mode in order to prepare to accelerate or to get some additional engine braking
05-13-2015, 08:26 AM | #15 |
Rep 158
Indeed. Except there is now no need - it does it for you. With the exception of preparing for an overtake, I just leave it to do its thing and it works beautifully.
