| 04-06-2012, 02:32 AM | #1 |
Gerrit
Rep 1
A tip for new springs !
Hello,
I need some advice to lower my car, witch springs to buy for my new 535i f10 the wheels are 20" v-spaak 356 liquid black..........; thanks in advance Gerrit |
| 10-18-2013, 05:41 AM | #2 | |
![]() 4
Rep 36
Or you could buy a set of AC schnitzer springs, price is more expensive and only 25mm drop. Also a lot of other brands available but you must look for one with GOCA papers, otherwise you will get in troubles with the car control.... Grts Frederick |
| 01-07-2016, 04:49 PM | #3 |
The Flasher
61
Rep 164
i run 20" with h&r sport springs, would definately recommend them. they tightened up the handling so much and now the car does not wallow like a boat going around corners.
Due to you having the 3.5L, a slightly heavier engine than mine the drop should be just right, mine to be honest is just a little bit to high for me on the front, but apparently as i said the bigger engines can sit up to 1cm lower! Go for H&r, Eibach sportline is to much of a drop in my opinion and prokit not enough. hope this helps
BMW F11 520d M-Sport, Stage2 Remap, Sophisto Grau, Oyster leather, Pro Nav, 20" M5 reps, H&R Sport Springs, Vorsteiner Rep Front&Rear Carbon valance, Quad exhaust Conversion, M5 Grill, Focal Audio |
| Bookmarks |
