2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications 10th billion Sprint Booster review
      12-26-2016, 10:23 PM   #67
Graffix
Graffix's Avatar
23
Drives: 2013 550 xi M sport
Took me about 10 mins to install, and most of that time was trying to get my finger in the back of the plug to depress it. After that it was a breeze.
Took it for a test drive after, all I can say is, it's a good thing I have an X drive.
      12-30-2016, 02:55 PM   #68
Sylverlee
Drives: White 535i M-Sport, 911 GTS
Just installed this last night. Has a bigger day to day improvement than BMS Stage 1, or changing stock wheels to 343 M5 forged wheels/ditching run flat. Car always felt sluggish at the throttle. Install would recommend using your pinky to get the inside clip.
      12-30-2016, 05:06 PM   #69
Bmw doubles
Dream crusher
Bmw doubles's Avatar
Drives: Fast
2011 535  [0.00]
Glad you guys are finding the same joy i am with this mod. How are more people not raving about this? It is pricey for a throttle mod, but worth it in that it unleashes all of your motors potential immediately. Even more so when tuned.
IG: @bmwdoubles
      01-01-2017, 11:01 AM   #70
Graffix
Graffix's Avatar
23
Do you guys take SB off if taking car in for dealer service?
      01-01-2017, 12:08 PM   #71
Bmw doubles
Dream crusher
Drives: Fast
2011 535  [0.00]
Its off when i valet, dealer or let the wife drive it
IG: @bmwdoubles
      01-02-2017, 03:10 AM   #72
whiteaccordvtec
Drives: None
i believe he meant unplugging/uninstalling it , thats a good question, should i ?
      01-02-2017, 09:54 AM   #73
Graffix
Graffix's Avatar
23
Yes, that is what I meant.
      01-04-2017, 08:01 PM   #74
mko9
mko9's Avatar
Drives: '11 535i
Dunno when it happened, but they have launched a v3 Booster. Now instead of a discrete little light, it has a giant controller. And there are apparently 9 levels of adjustability to the modes. Seems like far more than would ever be required. Now I will have to track down a v2 somewhere.
Mike
'04 330i ZHP
'11 535i
      01-04-2017, 11:52 PM   #75
xxpanipuri
Drives: 550i
you should be able to buy the v2 on their website still
      01-05-2017, 09:07 PM   #76
mko9
mko9's Avatar
Drives: '11 535i
For some models it shows both the v2 and v3 option, but when you go to the 5 Series section it only shows v3.
Mike
'04 330i ZHP
'11 535i
      01-06-2017, 01:21 AM   #77
Bmw doubles
Dream crusher
Drives: Fast
2011 535  [0.00]
Might be able to only co a used one for cheap then.
https://www.ebay.com/itm/152380830395
IG: @bmwdoubles
      01-06-2017, 03:32 AM   #78
ThaiBruin
ThaiBruin's Avatar
Drives: F10 535i M-Sport
Is there truly a manual only version?
Retired- 2013 MG 328i Sport Line 6MT - BMS Stage 1 / M Performance exhaust / M Performance steering wheel / M Performance shift knob/boot
      01-06-2017, 12:52 PM   #79
Bmw doubles
Dream crusher
Drives: Fast
2011 535  [0.00]
Personally I don't see why the pedal connection would be different between an auto and a manual. Check realoem part numbers
IG: @bmwdoubles
      01-07-2017, 01:15 AM   #80
xxpanipuri
Drives: 550i
the part #'s are different on the manual and auto trans sprint boosters on their website...
      01-07-2017, 01:43 AM   #81
Bmw doubles
Dream crusher
Drives: Fast
2011 535  [0.00]
I know, but I'm saying i don't think the part number on a throttle pedal for our cars is different therefore the SB part number for a manual or auto is irrelevant.
IG: @bmwdoubles
      01-07-2017, 07:32 AM   #82
hp jnkey
Drives: 2008 535i M-Tech
Guys
I thought the same thing, that there should be no difference between the Auto version SB and the Manual version.
I tried both and the Manual version is definitely sharper than the Auto model.
It was way to jumpy on the highest setting [ Red Light ] which is where I like to have it set on.
I would not recommend the Manual version for an Automatic trans application.
      01-07-2017, 09:59 AM   #83
Graffix
Graffix's Avatar
23
Spoke with my SA and he said that it's not an issue.
      01-07-2017, 03:51 PM   #84
STiLLsLow
Drives: 2013 535i M Sport
Just installed the v2 and ran through all the setting in comfort and sport. Along with my BMS intake and JB4, comfort in green mode should be perfect for daily driving.
I do a good bit of highway driving to get to work and would usually have to throw it in sport mode but switch the tranny into manual and use the paddles. This would allow me to sit in M8 while cruising but give me better throttle input with it being in sport (manual because while cruising, sport keeps it in 7th gear). Now I'm pretty sure I can just chill with it in comfort/green and be good to go. We'll find out Monday morning but loving the feel of it already!
      01-08-2017, 01:29 AM   #85
top ramen
Drives: Schwarz II 535i
Originally Posted by hp jnkey View Post
Guys
Please explain why you would not recommend the manual version for an automatic trans because in your first post back in 01/16 of this thread you said that both is the same and you had a manual version from a 3 series in your car and it ran fine. Niw you're kinda contradicting your statement by saying you would not recommend the manual for an auto application.
      01-08-2017, 11:47 PM   #86
DigitalNav
is there a return policy on these?
2013 F10 535i M-Sport
Alpine White
Oyster/Black
OEM M5 Exhaust with Resonator Delete
      01-08-2017, 11:59 PM   #87
DigitalNav
My biggest thing is using my car always in sport now... or getting a SB and using comfort for more MPG
Alpine White
Oyster/Black
      01-09-2017, 08:58 AM   #88
STiLLsLow
I'm also used to driving in sport before installing the SB but this morning I left it in comfort with the SB in green and it was perfect for the commute. Loving this little mod.
