01-06-2017, 03:42 PM | #1 |
Rep 2,825
Coilovers
Hi all.. looking to explore some coilover options for our chassis. as we all may already know, the F platform was the first step toward chasing sales figures and customers who prioritize comfort over road feel and choose not to attack every corner as fast as possible. while the stock coils feel nicely tuned on the highway, there is too much "float" and body roll around corners.
those of you with coilovers, how is the ride compared to stock? was the sportiness we have come to expect from BMW regained with the installation of coils? which brand would you say is best for this chassis? how does it ride on the highway compared to OEM? I am considering to either install coilovers or simply install urethane bushings to help combat some of the roll around corners. I was thinking about lowering my ride with some springs in order to keep the factory damping, but if there are coils out there that can still maintain a comfortable ride, I dont think it is necessary. any opinions, reviews, ideas are much appreciated. thanks! |
01-06-2017, 03:58 PM | #2 |
Rep 14,521
there's quite a few of us rolling on KW coilovers which is real big in the BMW world. never heard one complaint about KW's and there's 3 versions you can choose from. i just realized if your XI i believe the KWV3 is the only version available. also, if you have EDC you need the module or you can have it coded. you could also go with CKS coilovers as another option. there's also cheaper options out there like Megan, STS, BC Racing, ect...what's great about coilovers is you can set the height to whatever you think looks good. some of us drop it like it's hot...some drop it as much as what springs can do...it's up to you as far as the ride quality it's firm. not floaty compared to my stock suspension. i think combined with my wider tires 255's and 295's in the rear my car hugs the ground especially around corners and what not. upgrade swaybars and i've read handling improves even more. there's quite a bit of threads on this
01-06-2017, 04:06 PM | #3 |
Rep 2,825
what is the difference between V1 and 2? what about bilstein? i have heard good things from those as well. My only real problem is toronto roads.. on stock suspension with 55 sidewall rubber, the ride is already harsh on alot of stretches of pavement here. I do not know if i should get coils or not.. |
01-06-2017, 04:12 PM | #4 |
Rep 14,521
mine is RWD too so i did not have to get the EDC module or have it coded. V1 is already engineered/designed for a overall no adjustments needed coilover whereas the V2/V3 have damper controls. i've recently been hearing about the Bilstein's but yet heard anyone here use them or install them yet? you can still run coilovers on stock wheels.
01-06-2017, 04:39 PM | #5 | |
Rep 2,825
the 17 inch stockies have been tranferred to winter tire duty. will be purchasing summer rims for the next season. if the ride is already firm with stock suspension, perhaps coilovers will not be the best idea? what about a bushing upgrade and some anti roll bars? |
01-06-2017, 06:42 PM | #6 |
Rep 688
i have the KW V2s and I love them. the ability to adjust the height is key, and with a wife and kid, dialing the dampers to something comfortable was a must.
Retired- 2013 MG 328i Sport Line 6MT - BMS Stage 1 / M Performance exhaust / M Performance steering wheel / M Performance shift knob/boot |
01-06-2017, 08:15 PM | #7 |
Rep 14,521
no...the ride was firm after the coilovers. kinda the point why guys want to upgrade their suspension because some feel they're too soft? they want a firmer ride with better handling characteristics while being planted into the corners at higher speeds. too much body roll than usually guys will upgrade their sway bars to either M5, Eibach and i think there's a couple of other combos guys have done. so far i have not needed to upgrade my sways.
01-06-2017, 08:45 PM | #8 | |
Rep 2,825
01-07-2017, 12:29 AM | #10 |
Rep 688
beauty of coilovers... I just raised the front half an inch to avoid scraping. love that this can be done at any time.
Top pic is raised.
