2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications MHD Tuning Post Your Logs
      05-11-2018, 05:45 PM   #1
ey2001
ey2001's Avatar
310
Drives: F10 535i 6spd
just wanted to create a thread for people that have F10 could post some logs..
This is second gear
https://datazap.me/u/ey2001/second-gear?log=0&data=3-13
I am going to change out the plugs this wknd and do a 3rd gear pull with dsc off
Stage 1
F10N557.00
      05-12-2018, 06:34 AM   #2
harris69
Drives: 1997 M3/4, 1984 533i,1997 328i
Check out mine; I left mine in sport and hit it. Let me know what you think, and can you also tell me the proper procedure for recording a log?
      05-12-2018, 07:41 AM   #3
ey2001
ey2001's Avatar
310
Your link is not correct... from what I read online 6spd put in 3rd turn off traction dsc off and then 2500 rpm floor it to redline... autos was 4th gear
Read this link...
https://www.docdroid.net/IyQ24N5/int...d-datalogs.pdf
      05-12-2018, 08:22 AM   #4
harris69
https://datazap.me/u/harris69/log-15...og=0&data=3-12
      05-12-2018, 08:36 AM   #5
harris69
Read this link...
Thanks for the link; it was very insightful. My car is auto, so I need to leave it in M4 around 2500 rpms, and hit it to ~6000 rpms, and shift it into 5th?
Thanks in advance for replying.
      05-12-2018, 08:59 AM   #6
ey2001
ey2001's Avatar
310
Were you wot? Your accepted pos% are not at 100
F10N557.00
      05-12-2018, 12:45 PM   #7
SC300T
Drives: 13 E92 M3, 540xi, 535ix GT
Where you wot? Your accepted pos% are not at 100
I was thinking the same thing.... Didn't look like he floored it. If you have an auto, you need to be in M, select a gear, then hold the pedal to the floor but before the kickdown switch. If you feel the gas pedal it will go all the way, but then at the end of the pedal travel, there is a click that you will feel. Push it all the way, but before the "click".
Harris, can't tell how much boost you are making because it doesn't appear that you logged WOT. Especially if you are in comfort mode there is a lot of boost left in the last bit of the pedal. You want to log in sport if you have that switch, and be in manual mode.
      05-12-2018, 12:49 PM   #8
SC300T
Here is my MHD stage 1 6MT E30 log.
As you can see around 14psi midrange fading to 9.5ish up top.
      05-12-2018, 03:11 PM   #9
harris69
Ey2001, and SC300T It was my first time logging and it was right after the tune so most of it was trying to figure out how to log. My car doesn't have Sport, or Sport+ (all I can do is turn off dsc) and when I made the log I didn't know that I had to turn off traction control. I think I just hit it around 2500, and hit redline. I guess I need to do another log, and take the above recommendations into consideration.
      05-12-2018, 03:15 PM   #10
ey2001
ey2001's Avatar
310
Man your logs are good... I did a third gear and pull and it was ugly... a lot of timing was pulled... I'm change the spark plugs tomorrow and do another run...
F10N557.00
      05-12-2018, 05:59 PM   #11
nwob
nwob's Avatar
16
Drives: 13' 535i
https://datazap.me/u/zakary6/stage-2...og=0&data=3-14
3 logs take a look, stage 2 map
      05-12-2018, 09:43 PM   #12
SC300T
...I just posted my best one
My others in 3rd and 4th that have some timing pulls... Trying to figure it out like everyone else. My car has a stumble at low throttle settings which seems unrelated to any tune (it did it on stock map).
It seems the E30 stage 1 map doesn't target much more boost, but does seem to target a few extra degrees of timing.
      05-12-2018, 09:45 PM   #13
ey2001
ey2001's Avatar
310
Did you change out your plugs to see if it helps with the timing? Also are you on 91 or 93 mix?
F10N557.00
      05-12-2018, 09:55 PM   #14
SC300T
Looks like shitty gas. The last log doesn't look bad. Seems that a stage 2 car on 91 performs a lot like a stock car on E30.
I'm assuming you have DP and FMIC? Do you have E85 available?
      05-13-2018, 01:58 AM   #15
nwob
nwob's Avatar
16
Drives: 13' 535i
no fmic only DP, 20 minutes from e85, You think Im good to run it stage 2 with the shit 91 near me?
      05-14-2018, 08:09 AM   #16
SC300T
Yep, did the NGK 95770 (5992) plugs from the Burger Tuning site. Using E30 map now with 5 gallons E85 and 9 gallons 92 octane.
I'd maybe start with a gallon or two of E85 on your 91 map, then if that works, maybe experiment with the MHD Stage 1 or 2 E30 maps.
      05-14-2018, 04:19 PM   #17
harris69
Here is my latest one. It was hot and late in the evening. What do you guys think?
      05-15-2018, 06:15 AM   #18
harris69
Couple more from this morning. Did one pull in 3rd, and the other one in 6th.
https://datazap.me/u/harris69/log-15...=0&data=3-5-13
https://datazap.me/u/harris69/log-15...og=0&data=3-13
      05-15-2018, 07:43 AM   #19
harris69
For some reason I am getting a lot of timing correction on cylinder 3 (as high as -6.0 degrees). I have brand new set of Bosch plugs too; so I am really not sure what's going on.
      05-15-2018, 08:26 AM   #20
SC300T
For some reason I am getting a lot of timing correction on cylinder 3 (as high as -5 degrees). I have brand new set of Bosch plugs too; so I am really not sure what's going on.
Looks pretty typical to me.. Is this stage 1 93 octane map? Do you have any E85 you can throw at it?
      05-15-2018, 09:11 AM   #21
harris69
It is stage 1 (93 octane), and no mods. I have no idea if there is any E85 in my area but I can look. How much E85 would you suggesting using on a fill up?
      05-15-2018, 10:48 AM   #22
SC300T
http://www.georgebelton.com/E85Calculator.php
Maybe 2 gallons at most per tank full. 2 gallons will raise the octane a little over 1.5 points. If your 93 fuel is more like 91, this should clean it up. You could also run a 91 octane MHD map with your 93 gasoline to see if it cleans up - that may be the conservative way, and might not reduce performance much at all if you are getting pulls on 93, and also might feel smoother without the pulls.
