2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Navigation, iDrive, Audio, Video, Bluetooth, Phone, Coding BMW F10 Coding DIY (and other Fxx models)
      09-11-2018, 01:06 PM   #331
ZaphodB
Drives: 2016 BMW 528 (F10)
Coding Questions
I have a 2016 528 and have been successful and coding some options, but not others.
Accoustical_Lock_confirm doesn't seem to do anything. Is there a way to disable sound when locking with the remote, but leave the sound when unlocking?
My car has the ability to dictate text messages, but only when parked. Dictation is actually allowed in CA while driving...is there way to remove this restriction using coding?
Thank you
      09-16-2018, 08:55 AM   #332
Bruno112
Croatia
13
Drives: 2014 F10 530d MSport
Did you try with this in HU_NBT?
Disable Office Function Speed Lock-Out
3000 OFFICE_MESSAGES_SPEEDLOCK_CONDITION set to: nicht_aktiv
Enable Full Text Lines in Office While Driving
3003  PIM_DRIVING_TEXT_LENGTH set to: whole text_07
      09-17-2018, 03:33 PM   #333
pcp1234
Drives: G03
hi guys
is it normal that engine management light comes on after odd flash ? reading ista d, it obviously sees faults from flashing stage but actual car is ok
also i was under impression that EPS hasn't been updated because of below message but now its no longer on list of items to update. has it been flashed ok in the end ?
https://ibb.co/h3WRme
      09-19-2018, 10:23 AM   #334
ZaphodB
Thanks Bruno112.
I tried those setting, but it did not help...I couldn't actually tell if they did anything. Just to clarify, I can read and listen to message I receive, but when I try to dictate a reply, it tells me that the car needs to parked.
      09-19-2018, 11:39 AM   #335
Bruno112
Croatia
13
Originally Posted by ZaphodB View Post
Thanks Bruno112.
Hmm,maybe try this with video in motion in same HU_NBT modul.
DVD-in-Motion activated:
3000  SPEEDLOCK_X_KMH_MAX Change werte to: FF
3000  SPEEDLOCK_X_KMH_MIN Change werte to: FF
3000  VIDEO_HANDBRAKE set to: nicht_aktiv
3000  VIDEO_FRONT_LOCKED set to: nicht_aktiv
3000  VIDEO_SPEEDLOCK_CONDITION set to: none=00
Disable Legal Disclaimers
3001LEGAL_DISCLAIMER_TIME set to: kein_ld
3001MACRO_CAM_LEGALDISCLAIMER set to: kein_ld
3001MACRO_NVICAM_LDISCLAIMER set to: kein_ld
      09-20-2018, 02:43 AM   #336
et7007
Drives: F10
Hi,
(I am new on this forum)
Just bought the cable and got the links to E-sys (E-Sys_Setup-3.27.1_RC_b44813), ESysLauncherPremiumSetup_2.7.1_Build_135 and v63.4_PSdZData_Lite but I can not get the ESys Launcher working.
In the installation instructions its said - E-sys Launcher Premium to stop working after 30/12/2017. - To work around use Launcher ReArm and change the PC date back to April 2017. Followed the instructions but couldn't get it working. Am I going the right way or do I need another Launcher version?
Thanks!
      09-20-2018, 06:22 AM   #337
shawnsheridan
shawnsheridan's Avatar
Drives: 2016 650i GC M-Sport
Originally Posted by et7007 View Post
Hi,
Thanks!
You need to be using Launcher PREMIUM 2.8.2., which is good until the end of 2018.
TM built in Date Manipulation protection in newer Launcher, and that is why you have this problem. Only solution I have seen that works is a fresh install of Windows. Good luck with it.
2016 650i GC M-Sport w/ 20" 373M Wheels; Alpine White; Individual Opal White Full Merino Leather; Gray Poplar Wood Trim
Anthracite Alcantara Headliner; Ceramic Controls; Executive Package w/ B&O Sound System; Integral Active Steering, etc.
      09-23-2018, 12:16 AM   #338
et7007
Drives: F10
Thanks Shawn.
I gave it a try but turned out that launcher didnt install on virtualbox windows on my mac
I need to find a spare laptop for fresh windows
      10-03-2018, 03:20 PM   #339
OrcaPod
Drives: 2011 BMW 528i
Hi Shawn,
Can you please send me link for the software (my car is 2011 bmw 528i)
Thanks in advance
      10-03-2018, 03:46 PM   #340
shawnsheridan
Originally Posted by OrcaPod View Post
Hi Shawn,
Thanks in advance
PM sent.
      10-12-2018, 03:07 PM   #341
ciscospirit
Austria
Drives: BMW 640d xDrive GC (F06)
Hello,
i have a F06 from year 2015 with a S302 Alarm System.
i coded a bit arround to enable headlight and highbeam flashing if alarm is triggered, but it doesn't work.
i tried to change this from nicht_aktiv to aktiv:
FZD > 3002 DWA:
Optische Alarmausgabe Fernlight = aktiv
Optische Alarmausgabe Abblendlicht = aktiv
if i trigger the alarmsystem, my flashing lights start flashing and the alarm signal chime, but no headlights or high beam...
did i miss something?
Any idea if i had to enable something else somewhere?
At first I thought it might be because it was daytime, but i also tried it at night and the lights still have not flashed.
hm :/
Last but not least: can you tell me, how i can increase the duration time of the alarm signal chime to 2 minutes or more?
i think it should be done with this settings, but i am not sure about and also not which value will be the right setting for duration time.
FZD > 3001:
- Alarm duration time with external supply
- alarm duration time in self-powering mode
- alarm pause duration
- duty cycle
It would be very nice if you could help me
      10-14-2018, 07:23 PM   #342
Almaretto
Almaretto's Avatar
Drives: Test Vehicles
Originally Posted by ciscospirit View Post
Hello,
FZD > 3002 DWA:
Did you check light modules (FLE or TMS/LHM)?
      10-23-2018, 05:24 PM   #343
ciscospirit
Austria
Hello,
thanks for the hint... hmm no i didn't check them.
do you have some more detailed information what excactly i could search for?
thanks again
      10-23-2018, 05:26 PM   #344
ciscospirit
Austria
btw: can you help me also with that:
how can I increase the duration time of the alarm signal chime to 2 minutes?
FZD > 3001:
- duty cycle
      10-23-2018, 06:42 PM   #345
Almaretto
Almaretto's Avatar
Hello,
thanks again
No. There are various parameters in each that refer to functionality. It will depend on which hardware vehicle has.
No...I have never messed with duration, so I cannot help.
      10-24-2018, 05:37 AM   #346
aladinn006
Drives: Bmw f10 520d
Hi everyone i love my bmw , my bmw loves me
I wish to do some diy and coding and whould be helpfull some tips from you guys
      10-26-2018, 09:03 AM   #347
ciscospirit
Austria
Hello Almaretto,
i checked my CAFD Files and can just found "FLE" but not "TMS" or "LHM".
in "FLE" i found something like:
PANICMODE_Idx => 02_Value
RAIDALARM_Idx => F010Wert_SA552_ECE_LA_LL
LWR_Offsets_B_PANICMODE => 01_Value
LWR_Offsets_B_RAIDALARM => 01_Value
but i have no idea, what i should change here to get my lights working if alarm is activated.
      10-28-2018, 10:08 AM   #348
Gixxer550i
Drives: 2015 550i
Last time I coded I used the cheat sheet And manually changed some codes. Has things changed recently? Also where can I get the latest files? When were they last updated?
Another issue is my with parking assist. Not sure if this is a coding issue. When I initially put the car in drive from initially starting up the car the parking Assist does not detect anything unless I put it in reverse. Not even sure if this is a thing. Any help would be nice. Thanks.
      10-31-2018, 12:06 AM   #349
dzz
Drives: 2015 BMW 535xi
2015 BMW  [0.00]
link to E-sys software
Shawn,
can you please send me the link to E-sys software. I have 2015 535xi M-sport
      10-31-2018, 12:15 AM   #350
shawnsheridan
Originally Posted by dzz View Post
Shawn,
PM sent.
      10-31-2018, 10:14 PM   #351
dzz
2015 BMW  [0.00]
I cannot install ESysLauncherPremiumSetup_2.8.2_Build_155.msi in the virtual machine. Can E-sys be run under the Vmware Fusion, Win 10 on a Mac? Please see attached image for the message that I get
      10-31-2018, 10:25 PM   #352
Almaretto
Almaretto's Avatar
E-sys can be run in VM. Launcher cannot. It will work in Bootcamp.
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
