2010 2011 BMW 5 Series Forum F10 F10 Technical Topics DIY Guides & Discussions Carbon fiber mirror covers installation on 535 F10
      06-29-2019, 10:50 PM   #1
dzz
Drives: 2015 BMW 535xi, MHD Stage 2+
2015 BMW  [0.00]
There is lot of conflicting information about aftermarket mirror covers installation on 535 F10. I have 2015 535xi F10 and other F10/11 LCI variants are probably very similar or the same.
First thing to know is that you don't need remove a mirror to install aftermarket mirror covers. Mirror cover is held by 3 tabs, see circled areas in yellow:
I got these carbon fiber look a like mirror covers (probably there is only 1 layer of CF on top of plastic but it looks good, we'll see about longevity and color fading) from this seller on eBay for $40.46 which includes the shipping too: https://www.ebay.com/itm/1Pair-Carbo...72.m2749.l2649
First pic on this listing is not accurate, but others are. Also the title of the listing is vague, it mentions M5, but it is M5 style for 535 F10.
Step 1: use trim removal tool (I couldn't find my trim tool, so I used iPhone repair pry tool, similar purpose) to get it under existing mirror cover and gently work it around the edges, it helps if you have 2 pry/trim tools. Go around the edges and tabs will loosen and you can gently pull the mirror cover off the mirror
Step 2: in order to install carbon fiber or any new mirror cover, you need to position it correctly by starting to positioning it correctly from inside towards outside of the mirror (right to left or left to right), and when it is flush with the turn signal indicator, start to push it in.
When pushing it in, make sure mirror cover outer edge is lining up with the mirror and you should hear tabs clicking in place and the mirror should be held in place.
Removal of old mirror covers and installation of new ones should take 5 min per mirror and it is easy. Here is how it looks like installed:
Yes, I've noticed bird poop on the hood :-) The color of these carbon fiber-ish mirror covers is grayish and it is matching my new gun metal wheels which you can see here: https://f10.5post.com/forums/showthread.php?t=1614572
      06-29-2019, 11:28 PM   #2
jonobro
Drives: bmw f10 535i
Attachment 2088455
I got these carbon fiber look a like mirror covers (probably there is only 1 layer of CF on top of plastic but it looks good, we'll see about longevity and color fading) from this seller on eBay for $40.46 which includes the shipping too: https://www.ebay.com/itm/1Pair-Carbon-Fiber-Side-Mirror-Covers-Caps-Factory-Fit-for-BMW-F10-M5-2014-2016/233209278603?ssPageName=STRK%3AMEBIDX%3AIT&_trksid =p2057872.m2749.l2649
Attachment 2088454
Attachment 2088456
Attachment 2088457
Attachment 2088458
Attachment 2088459
If I have pre lci would these still work ?
      06-29-2019, 11:54 PM   #3
dzz
2015 BMW  [0.00]
What year is your 5-series? Go to https://www.realoem.com/bmw/select.d...&kind=M&arch=0 under "Serial number" plug in last 7 digits of your VIN, your car should show up, click on "Browse Parts", scroll down on next screen, click on "Vehicle trim" scroll down and find part #s for mirror covers. For my car they are:
02 Outside mirror cover cap, left, primed 1 51167308683
02 Outside mirror cover cap, right, primed 1 51167308684
when I click on 51167308683, I get a list of all cars this part number is used on and that is:
Part 51167308683 was found on the following vehicles:
5' F07 GT LCI   (08/2012 — 02/2017)
5' F10 LCI   (08/2012 — 10/2016)
5' F11 LCI   (08/2012 — 02/2017)
5' F18 LCI   (10/2012 — 04/2017)
6' F06 Gran Coupé LCI   (05/2014 — 09/2018)
6' F12 LCI   (05/2014 — 05/2018)
6' F13 LCI   (05/2014 — 10/2017)
7' F01 LCI   (05/2011 — 05/2015)
7' F02 LCI   (05/2011 — 05/2015)
7' F03 LCI   (01/2012 — 03/2015)
Another way to validate is to remove mirror cover on your car and see if it has 3 tabs in these places (circled in red):
Name:  Screen Shot 2019-06-29 at 11.25.31 PM.png
It is just $40, so I've decided to take one for the team and it worked!
      06-30-2019, 05:08 AM   #4
jonobro
What year is your 5-series? Go to https://www.realoem.com/bmw/select.d...d=M&arch=0 under "Serial number" plug in last 7 digits of your VIN, your car should show up, click on "Browse Parts", scroll down on next screen, click on "Vehicle trim" scroll down and find part #s for mirror covers. For my car they are:
Attachment 2088496
How do you like the look? I would rather get a pair that's the same color code as my car
      06-30-2019, 09:05 AM   #5
lsturbointeg
lsturbointeg's Avatar
Drives: 2011 535i Jet Black
OP great DIY write up!
confirm yours first before you order. if you notice he has a turn signal indicator on the lower part of his mirror whereas mine doesn't. i do like that M5 style so i may have to go back and find one that will work with mine since i also paid like $40 for these. it's been a couple of years now and the carbon fiber has yet faded, turned yellow or show any type of blemishing
      06-30-2019, 01:27 PM   #6
jonobro
I have a feeling they will work, so yours is pre LCI? Aswell ?
      06-30-2019, 02:42 PM   #7
lsturbointeg
Yes. Mine's a 2011 base model. I didn't really know much about BMW's at the time.
      06-30-2019, 03:06 PM   #8
jonobro
Oh same. Im curious on getting what he got but mine don't have side mirror blinkers do not sure if they would still work
      06-30-2019, 09:22 PM   #9
dzz
2015 BMW  [0.00]
I like the color, and I like some contrast, the problem with black cars is that other black parts blend in with the body of the car.
Here is the video where you can see mirror covers and the wheels against black body
      07-01-2019, 12:14 AM   #10
jonobro
My mirror caps don't have the blinker on them and is pre-LCI I wonder if these would still fit ? Do you know
      07-01-2019, 12:45 AM   #11
dzz
2015 BMW  [0.00]
probably not, but even if they do fit into mounting tabs on the mirror, you'll still have a gap on the carbon fiber mirror covers where turn signal light on the mirror is
      07-02-2019, 01:21 AM   #12
dzz
2015 BMW  [0.00]
some aerial shots of my car
      07-07-2019, 06:00 PM   #13
MaximumFreckles
Drives: 2011 BMW 535i Msport
Great post. I absolutely love/want these, except I have a 2011, hence no turn signal. Is it an easy retrofit to put on later model year mirrors? These have been sitting in my amazon cart for months so I wouldn't forget lol.
      07-08-2019, 05:16 PM   #14
MrGreenPump
Drives: 14 535d (N57T)
This may be a dumb question - but will the mirror still fold up without any issue?
      07-08-2019, 09:45 PM   #15
ziekxq
Drives: 2011 535i xDrive
I would buy these in a heartbeat if they were made for 2011 models without mirror lights. I searched but couldnt find one .
      07-08-2019, 10:23 PM   #16
BMW_driver_2008
BMW_driver_2008's Avatar
Drives: BMW M6
Hey DZZ... dig the look from the front but how do they look from the rear. Can you post a few picks please?
      07-08-2019, 11:24 PM   #17
dzz
2015 BMW  [0.00]
on the video I've posted few posts above, at 53 sec and 1:48 there few shots from the back, you can pause the video for a better look. I'll try to post few pics in the next few days
video is here again:
      07-08-2019, 11:26 PM   #18
dzz
2015 BMW  [0.00]
yes, of course. no issues with folding the mirrors
      07-29-2019, 04:19 PM   #19
ThaiBruin
ThaiBruin's Avatar
Drives: F10 535i M-Sport
Just ordered a set. Didn't realize it was this easy to replace the mirrors on an LCI model (mine is 2014). Certainly a lot nicer looking than the ones that stick on with tape! Too bad shipping is estimated at a month.
Retired- 2013 MG 328i Sport Line 6MT - BMS Stage 1 / M Performance exhaust / M Performance steering wheel / M Performance shift knob/boot
      07-29-2019, 04:28 PM   #20
jonobro
They released the same ones for pre LCI finally haha what color did you get ? and what color is your car
      07-29-2019, 04:33 PM   #21
jonobro
They have ones for pre LCI now haha
      07-29-2019, 07:14 PM   #22
lsturbointeg
BurrNinga just ordered his so I'm waiting to see how his turn out before I pull the trigger
