02-02-2020, 08:05 PM | #46 | |
Rep 455
Pic of engine bay from left-front. Last edited by John H.; 02-02-2020 at 08:06 PM.. Reason: Added info. |
WinstonE92xi64.50 |
02-03-2020, 10:19 AM | #47 | |
Rep 2,590
How deep did you drill? Thanks for the detailed info break down!
2015 BMW 535xi
02-03-2020, 05:12 PM | #48 | |
Rep 455
Deep enough for the insert to seat. I used blue painters tape to mark off depth on the drill bit. |
02-04-2020, 09:17 AM | #49 |
Rep 2,590
They're definitely strong enough without the red, I just like loctite
2015 BMW 535xi
02-04-2020, 03:40 PM | #50 | |
Rep 455
Let me know how it turns out. |
02-12-2020, 10:11 PM | #51 |
Rep 455
02-13-2020, 07:52 AM | #53 |
Rep 455
02-13-2020, 06:28 PM | #54 |
Rep 1,442
Drives: 2011 535i 6MT
What is the difference between that oil cooler, and this one?
02-13-2020, 07:42 PM | #55 |
Rep 5,356
02-13-2020, 08:04 PM | #56 |
Rep 14,522
Just ordered my Ebay strut! Will post some install pictures when I do. Anyone upgrade their sway bars and if so which one's?
02-13-2020, 08:14 PM | #57 |
Rep 1,442
I did H&R front and rear and will get my strut bar anyday now.
Can someone comment on how this feels and if it has reduced body roll? Last edited by BimmerHausPerformance; 02-14-2020 at 11:28 AM.. |
lsturbointeg9152.50 |
02-14-2020, 04:16 AM | #58 |
Rep 455
Part# 11427573212
https://www.ecstuning.com/b-genuine-...t/11427573212/ You have a thermostat in that. Looks like someone was in there, aftermarket t-stat cover, BMS? A popular mod is to change the valve. https://www.turnermotorsport.com/p-5...-e6061-n54n55/ |
02-14-2020, 04:23 AM | #59 |
Rep 455
02-14-2020, 11:27 AM | #60 | |
Rep 1,442
02-14-2020, 12:08 PM | #61 |
Rep 5,356
02-14-2020, 12:25 PM | #62 |
Rep 2,590
I think it's part of the driver's package (high speed synchronisation). At least according to realoem, but realoem could also be wrong. Says it's also part of the hot climate version (hot OR high speed), but my car does not have that style heat exchanger even though it's a hot climate version. I just have the block style heat exchanger.
2015 BMW 535xi
02-14-2020, 12:45 PM | #63 | |
Rep 5,356
02-14-2020, 12:55 PM | #64 | |
Rep 2,590
Edit: This thread would suggest it's not related to m sport at all: https://f10.5post.com/forums/showthread.php?t=1399982
2015 BMW 535xi
02-14-2020, 02:05 PM | #65 | |
Rep 5,356
02-14-2020, 05:58 PM | #66 |
Rep 1,442
It was super simple. Just make sure you have the correct sockets/torx etc and you are good to go.
