| 08-05-2016, 04:07 AM | #1 |
Rep 22
Torque specs. F10 suspension
Hi All , does anyone has the details of the torque spec. on the front wishbones. I have a manual that ref.s the below spec. I can't seem to find it anywhere.
31 12 20AZ Any help would be greatly appreciated. |
| 08-16-2016, 02:49 AM | #2 |
Rep 1,088
front and rear torque. Did the dinan control arms..
StradaRedlands11490.00 |
| 03-22-2020, 08:53 PM | #4 |
Rep 447
Drives: 2011 750i
About to replace struts. Does anyone have specs on bolts for the struts?
| 03-22-2020, 11:10 PM | #5 |
![]() 1504
Rep 2,684
For the ones that bolt it to the chassis? 28nm. Don't reuse the old bolts.
2015 BMW 535xi
| 07-09-2024, 10:53 AM | #6 | |
Rep 6,924
Drives: 2006 BMW 330i MT
Garage List 2007 BMW 328i E91 [10.00]
2009 BMW 328i E91 [7.56] 2006 BMW 330i [8.17] 2007 BMW 328i [8.83] 2013 BMW X5 35i [8.43] 2011 BMW 528i [9.07] |
Thank you for posting this! I need to clarify which are the torque values for the front thrust arms? I see all those listings, and I don't know which is which! Both the subframe bolts and ball joint nut. I need to swap these out, and have never done it on the F10. It's an easy job on an E90, so presuming the best! Thanks! Last edited by StradaRedlands; 07-11-2024 at 11:50 AM.. |
| 07-19-2024, 12:32 PM | #7 |
Rep 6,924
M_Bimmer gave a great answer to my question over on the main conversation page: https://f10.5post.com/forums/showpos...20&postcount=2
Thanks! |
| Bookmarks |
