03-31-2020, 02:01 PM | #155 | |
Rep 441
2013 535xi M Sport (PWG) // PS2 // Spool fx150 // MHD // xHP // FTP Inlet // FBO: AR HF DP, Wagner IC, BMS Intake, VRSF CP
03-31-2020, 02:11 PM | #156 |
Rep 1,299
03-31-2020, 03:06 PM | #157 | |
Rep 1,299
03-31-2020, 04:06 PM | #158 | ||
Rep 517
Looking at the FTP inlet rn. My custom intake was giving me errors with D Shoups tune. He needed to scale the MAF but to get things right we wanted to remove anomalies out the equation.
BPM Tuned, Advanced Fuel Dynamics, Paddoq Valved Exhaust, Paddoq Magnetic Paddles, EDC dampers, Dinan Springs, H&R Sway. DCT all day long.
https://www.youtube.com/channel/UCFu...fWjCtOz49FDMlg |
03-31-2020, 07:40 PM | #159 | |
Rep 1,442
Drives: 2011 535i 6MT
03-31-2020, 10:30 PM | #160 | ||
Rep 517
04-01-2020, 09:12 AM | #161 |
Rep 1,442
That's awesome and is how it should be done. Man, for what you are paying him he is going through a lot of revisions for you all! Good value!!!!
04-01-2020, 09:20 AM | #162 |
Rep 1,442
That cone filter cries out N54! lol. That's what I thought of when I saw that.
Bmwdoubles_194.00 |
04-06-2020, 06:42 PM | #163 |
Rep 1,299
New log:
https://datazap.me/u/ziekxq/v219-log?log=0&data=4-22 We are doing 5th gear pulls because 4th gear was causing issue with 5th gear for some reason, but with tuning in 5th gear the 4th gear works fine. I believe we are almost done, just need to raise wdgc at higher rpm. |
04-06-2020, 06:46 PM | #164 |
Rep 1,442
That is nice! almost 20 lbs right at 3k rpms and down to 18 at the end of the run. With the WGDC adjustment will that help you keep boost up?
Bmwdoubles_194.00 |
04-06-2020, 07:56 PM | #165 | |
Rep 1,299
Hopefully next couple revision is all it going to take. After that I want to get it on dyno so I can see before and after Helix comparison though I don't know if it is possible with all the lockdown that is going on in Illinois. |
04-06-2020, 08:03 PM | #166 |
Rep 1,442
Very nice, can you get any pulls recorded with your phone? Just the gauge cluster? I'd love to see a rolling pull from like 30 or 40 mph.
04-06-2020, 09:05 PM | #167 |
Rep 1,299
Bmwdoubles_194.00 |
04-07-2020, 08:26 AM | #169 |
Rep 1,299
It can do better because right now after 5k rpm the boost drops from 18 to like 16 then to 15psi, so waiting on new revision to fix that. I might record 40mph 2nd gear as well to see how that does.
04-07-2020, 03:15 PM | #170 |
Rep 1,442
Can't wait to see how that goes. I'd like to see Doubles too with the HOD.
04-07-2020, 04:20 PM | #171 |
Rep 1,230
N55 GENERAL
David Shoup Tuned Fully Built By Miami Engines/Project Motorworks Precision 6266 On Steroids |
04-07-2020, 06:08 PM | #172 |
Rep 1,299
Thanks... With a little bit more tweak to upper rpm boost and one less passenger in the car next time hopefully I can do better 3rd gear pull lol.
Then I'll do Helix OD and call it a day... I might go two maps pump for winter and e85 for summer because I don't know how e85 going to work in Chicago winter. |
04-07-2020, 08:22 PM | #173 |
Rep 1,299
4th gear pull:
https://datazap.me/u/ziekxq/v220-4th...og=0&data=4-22 5th gear pull: https://datazap.me/u/ziekxq/v220-5th...og=0&data=4-22 |
04-07-2020, 09:07 PM | #174 |
Rep 517
Good stuff. Can't wait to find and fix my leak. I'm keeping my AZ-MCRacer inlet. I fitted it with part of the stock grommet so there's no unmetered air happening at that point. I think my leak is at the valve cover which i don't have prior to the DS tune. Which means his tune found my weak points when setting the target to 22psi.
04-07-2020, 09:28 PM | #175 |
Rep 1,442
Ah so you cut part of the gasket from the stock inlet and used that to seal the bigger inlet pipe?
When is he doing another run of those! |
04-07-2020, 09:47 PM | #176 | |
Rep 1,299
