2010 2011 BMW 5 Series Forum F10 Whirling noise from car while moving |
02-16-2021, 12:08 AM | #1 |
Rep 3
So I was driving home one day and then after about 5-10 minutes of starting my car I get a strange noise which I've never heard before. I looked around online but none of the solutions I found really described the noise I heard. I found that when my car was at a stop the noise would also stop but then world pick right back up when I started moving again. Here's a video of what it sounded like from inside the cabin while I was driving.
My car is a 2011 BMW 528i with the N52 engine. Not sure if this matters but I'm from the Chicago area and the weather has been really cold recently and the car was parked outside in below zero temperatures for around 8 hours while I was at work. Let me know if any other details are needed. Thank you! |
02-20-2021, 08:32 PM | #2 |
Rep 9
Difficult to tell from the audio. Sounds like it may be a bad tire or wheel bearing. Could also be rust on the rotors, if it really just happened after sitting for an extended period of time. See if it goes away after some miles, or gets worse.
02-20-2021, 11:05 PM | #3 |
Rep 916
Did you drive through snow? Any shaking that you feel? Does the car pull any way if you let go of the wheel at speed?
Instgram @burninja
02-20-2021, 11:34 PM | #4 |
Rep 3
The car didn't seem to pull when I let go. Steering wheel sometimes shakes at idle(I have a muffler delete, not sure if that can cause slight vibrations). Whenever I heard this noise there's been pretty heavy snow coming down
BurrNinja431.50 |
02-21-2021, 12:25 AM | #5 | |
Rep 916
Instgram @burninja
Tags |
engine whine, engine whirl, n52, noise, whine |
