2010 2011 BMW 5 Series Forum F10 Bavsound Revenant vs. Powered sub in the trunk |
06-24-2021, 11:13 PM | #111 | |
Customize Everything!
44
Rep 279
Already removed everything from out of the trunk and just let my tools and all the hardware for the install. Looking at Bavsound website, they have an installation video but using an m3 for the demo vehicle. After watching the plug and play aspect of this kit has me more than reassured I can do the installation myself. Since I will be throwing in the Rockford Powered subwoofer, I'm curious just how much sound deadener I will need to use for the trunk. I doubt I will use some to line the trunk lid. Don't want the trunk lid to get too heavy and stress the power tailgate motor any. Will keep you posted as I go along. |
06-25-2021, 11:06 AM | #112 | |
Rep 441
https://f10.5post.com/forums/showthread.php?t=1726050
2013 535xi M Sport (PWG) // PS2 // Spool fx150 // MHD // xHP // FTP Inlet // FBO: AR HF DP, Wagner IC, BMS Intake, VRSF CP
06-28-2021, 11:02 PM | #114 | |
44
Rep 279
some initial observations. Overall install was very straight forward. although the video reference on the Bavsound website was of a M3, the mechanics still applied. What I noticed off top was that once you have the amp and bracket installed in the proper location, the outlets are all top loaded, as opposed to the fty amp and a Match7up amp which have the connectors side loaded. This was bound to yield some clearance issues, but went ahead with the install anyway. Wiring up the amp and all the connectors took about an hour or so. The good thing is that I have an led strip on the top of my trunk for interior lighting, so I had all the light I needed for the job. The Bavsound amp has a tune chip with 4 profiles pre loaded. 2 for those with the Bavsound speakers and 2 for factory speakers. I chose the multi seat profile instead of the driver centric profile. I felt like the driver centric profile had most of the music playing from the center channel in the dash and less from the door speakers. I like to have my music completely surround me. The space is very tight when putting the carpeting back on. I actually swapped the toslink optical cable for a rocket fish cable because the carpeting kept knocking out the Bavsound supplied optical cable. The rocket fish one had a shorter "barrell" so to speak. I wasn't worried about the power cables too much, but I am growing uncomfortable that there is a bulge in the pocket when the carpeting is installed back. Its not too pronounced, but I prefer the wires to be away from the carpet. I may just drop the bracket and amp and zip tie it secure or use velcro or something. Any suggestions? You will also have to cut the wire sleeve for the ground and power cable to give more slack to when you attach your ground and power cable. You wont be able to put the hidden pocket carpeting back if you don't. Borrowing from itsturbointegra's build, the box of choice was the Rockford Punch 12". I ended up taking my car to a local audio shop since I know the owner and he was interested in carrying Bavsound products. I showed him the amp and he was very interested. Actually he put an installer on the job to wire up my sub for free just to see how everything sounded. The end result.....Sound deadener is a must! I was only able to put about 3 sheets down on the left side of the trunk. You definitely want to add some on the right side because you can hear the gas cover rattling. From the inside the music sounds great, but that rattling make the car sound tacky....almost Honda Civic in Washington Heights like (if you are in the NY metro area you know what I mean.) I'm going to add some sheets onto the right side of the trunk this weekend and see how much that helps. Before I installed the amp and was running the fty Harmon Kardon Logic 7 factory amp, I felt as if the sound was louder, but not as clear now with the Bavsound amp installed. I do have to turn up the volume higher in order to get to the level I want, but the sound does sound cleaner. The Rockford subwoofer gave the right amount of bass I was looking for without overpowering the mids and highs. Overall, I can recommend the amp for someone that is looking for a clean plug and play solution. But I have definitely heard some custom audio systems that are stronger , louder, more powerful. It all depends on what you're going for. I'll post more pictures once I sound proof the right side of the trunk. |
06-29-2021, 09:36 AM | #115 |
Rep 441
Glad you're happy with the build!
Not the prettiest solution but I lined the inside perimeter of my gas lid with some weather stripping and that stopped the rattle there. I also put 4 rubber washers between the back of my license plate and the trunk and that stopped the license plate rattle. Those two things helped more than the sound deadening. Unrelated - last week I tried out apple music's spatial audio in the car compared to Spotify very high quality streaming...some songs are just slightly better some felt surprisingly better. Eg, Tiesto's BOOM always sounded good but Spatial takes it to the next level. Kind of shocking.
06-29-2021, 05:50 PM | #116 | |
44
Rep 279
Interesting observation on the spatial stream. Might have to check it out. I feel as if I lost some volume for clarity with the Amp. Still getting used to it I guess. |
06-29-2021, 11:04 PM | #117 | |
Rep 57
Thanks for the comments. Sounds like there may need to be some further modifications with cables and/or bracket to truly make this plug and play. Have you played with the EQ settings to try to address the volume or is the low volume issue occurring with a particular audio source? I’ve noticed that my iPhone volume impacts my car volume when running off Bluetooth. |
06-29-2021, 11:35 PM | #118 |
44
Rep 279
Actually I stream my music off of Spotify. Interesting you are have low volume issues on your iPhone. I have an android device so this may be an issue with the Bluetooth or something. I'm far from an audiophile so maybe some of the more qualified in the forums can chime in on possible causes.
06-30-2021, 06:44 AM | #119 | |
Rep 57
07-04-2021, 09:18 PM | #120 |
Rep 96
I decided to just resolve this on my own. I removed the mounts, and trimmed them so that they fit back in sideways. This allowed the amp to lay flat. I think used the strong velcro to attach the stock module and the MOST box to the amp. I used the factory holes to mount the modified bracket. I was able to use one existing hole on the bracket itself and only had to add one. Just used a couple of bolts to attach it. Everything fits perfect and allows the factory plastic support to be added back in. Everything fits perfect now. Glad to have this resolved.
lsturbointeg9167.50 |
07-08-2021, 07:39 AM | #121 |
Rep 14,521
dude that looks so much better. BAV needs to edit their "plug and play" feature to minor adjustments need to be made but there's not a lot of guys out there who are gonna just cut things to make things work
07-14-2021, 09:31 PM | #122 | ||
Rep 441
On the Spatial Audio topic: I noticed tonight it's not just the Apple Spatial audio that sounds a lot better than Spotify's Very High audio setting - I was listening to Foo Fighters's "Ballad of the Beaconsfield Miners" on both, it's "only" on Apple's Hi Res Lossless and not Spatial and it still sounds a ton better than Spotify. Now I wonder if Hi Res Lossless is very different than just Lossless haha...I guess it's a testament to the Match amp and speakers that I'm now noticing these things in a big way, but then again the amp alone would probably make it pretty noticeable on stock speakers. Anyways. I had assumed there'd be no noticeable difference between Very High and Lossless but I'd say it's dramatic, at least with Hi Res Lossless. Enough that it's a bit of a drag listening to it back on Spotify.
07-15-2021, 08:59 PM | #123 | |
44
Rep 279
