2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications Water pump
      09-08-2021, 11:41 PM   #1
Water pump
I think my water pump is failing. The fan ramps up to high when I start the car (mainly when it's hot out), stays there for a bit, then ramps down. That said, what should the cost of repair be? Before ya'll tell me it's not that bad of a DIY, my chest is being held together by piano wire and two titanium plates so this and pretty much all future repairs will have to be done by someone else.
TIA.
      09-09-2021, 12:28 AM   #2
Sylverlee
Drives: White 535i M-Sport, 911 GTS
TIA.
Hmm this just happened to me the other day. Is there a way to test it with a diagnostic tool?
      09-09-2021, 10:53 AM   #3
Unspec
Unspec's Avatar
1312
Drives: 2015 BMW 535xi
A failing pump should throw some codes. I think the fan ramping and then going down on first start on a hot day is normal.
2015 BMW 535xi
ISTA VM Setup/Tutorial
Sylverlee150.00
      09-09-2021, 11:31 AM   #4
Stupid question... would that be a BMW specific code? Will a "generic" code reader do? I'm too computer illiterate to install and use ISTA. If it doesn't install automatically I'm completely lost.
      09-09-2021, 11:43 AM   #5
Unspec
Unspec's Avatar
1312
I think it would be a BMW specific code, but some code readers can read BMW codes. Carly might be a good bet for that, or even Bimmerlink
2015 BMW 535xi
      09-09-2021, 01:17 PM   #6
LivNowPayL8r
LivNowPayL8r's Avatar
Drives: 2016 535d, Space Gray
Likewise, I do not have ISTA on a laptop but have had good results with a Foxwell NT530.
      09-09-2021, 06:24 PM   #7
TZ
Drives: 2011 535i xDrive, 2014 435i CO
TIA.
For your 2014, you are probably still qualified for up to $1k water pump reimbursement. Check it out.
2014 435i RWD Convertible
Service Manual: www.newtis.info
Part: http://www.realoem.com
      09-09-2021, 06:35 PM   #8
Dan944
Drives: 2012 BMW 535xi
2012 BMW 535xi  [0.00]
I just had to replace my water pump. A symptom for me was the fan would ramp up to high for 5 seconds and then go back down. It would keep doing that over and over. That's how I noticed something was wrong. I scanned the car and sure enough the water pump code was there.
      09-09-2021, 06:43 PM   #9
I'm over the 7 years, but 10K miles under the 84K miles.
      09-09-2021, 06:44 PM   #10
Did you DIY or pay? If you paid, can I ask how much?
      09-10-2021, 06:12 PM   #11
Dan944
I did it myself. I bought the kit on FCP Euro.
      09-10-2021, 09:37 PM   #12
TZ
I DIYed mine too. I saw somewhere it is around $900-1200 at dealer.
