2010 2011 BMW 5 Series Forum F10 688 Harman Kardon retrofit |
09-02-2019, 10:10 AM | #26 |
Rep 88
12-07-2020, 08:26 PM | #29 |
Rep 35
Hi Koanga! I car is F10 LCI come with basic stereo sound, there is no speakers in rear door panels. I am thinking of upgrading to HK system. Just want to know if the all the wire is already pre-routed? If not pre-routed, what wire do I need to purchase? Can you let me have the part number? As I cannot find the wire harness specifically for audio system with HK option in realoem.com, I suspect that it maybe already pre-wired. Meanwhile, what if I just replace all the speakers/tweeters with HK speaker/tweeters without adding amp and necessary wire harness (if not pre-wired), what could happen?
12-07-2020, 11:22 PM | #30 | |
Rep 88
If you'll end up just replacing all the speakers with tophifi ones (logic7) and swap the amp without adding rear speakers, I guess you'll be ok, but you'll not get the same sound quality. |
12-08-2020, 12:19 AM | #31 | |
Rep 35
By the way, what tool did you use to code the HK system into your car? Thanks! |
12-08-2020, 12:21 AM | #32 | ||
Rep 88
12-08-2020, 01:56 AM | #33 |
Rep 35
I see. Thanks! However, I do not have speaker in rear door panel, so are you sure there is AMP in the trunk? As I know, no amp for just stereo speaker system.
12-08-2020, 03:41 AM | #34 |
Rep 36
12-08-2020, 06:49 AM | #35 |
Rep 35
Yes, I added tweeters in A pillars. How about adding speakers and tweeters in the instrument panel as I believe there are no speakers there, and also adding tweeters in the package shelf? It is pretty expensive to replace rear door panels and add amp and run wiring.
12-08-2020, 01:53 PM | #36 |
Rep 36
If there is no speaker there, there is no wiring also, you have to run all the wires from the boot.
Depends on your colour if you can find some cheap door panels on eBay |
05-22-2021, 03:44 PM | #37 | |
Rep 403
1) Basic- 6 speakers no tweeters 2) Hifi- 10 Speakers 3) Logic 7 professional DSP/HK- 16 speakers 4) B&O In the US you dont get the option 1 (basic). If your front doors do not have tweeters (triangular black section next to the mirrors)...then you have option 1 above and that has no amplifier in the trunk. In this case the amplification is artificially done by the Idrive unit itself. |
07-27-2021, 01:22 AM | #39 | |
Rep 4
10-26-2021, 11:00 AM | #40 |
Rep 7
Changing HK or HiFi 676 speakers with better ones makes also big difference. I have replaced HK speakers with Morel Virtus 402 and made me huge difference.
01-08-2022, 05:51 PM | #41 |
Rep 38
I have Hifi F11 , but I'm confuse on the numbers, front what I read beside the sound quality improvement from Hifi to H&K its the adicional 4 read doors speakers.
HiFI - Central - 1 Speaker + 1 Tweeter Front Doors - 2 Speakers + 2 Tweeters Under Front Seats - 2 Sub-Woofers Rear Deck or Roof - 2 speakers + 2 tweeters 12 Speakers H&K Same as Hifi plus Read Door - 2 speakers + 2 tweeters 16 Speakers |
11-19-2022, 08:16 PM | #43 |
Rep 1,507
It plugs into this connector. Brown wire goes to the ground connector nearby. Red/Green goes to the rear fuse box. It's 5A Fuse 121, pin 10
