01-22-2023, 07:16 AM | #155 |
Rep 251
I got the H&R VTFcoils hope front clear, and my car is not xdrive if that makes a difference. still dont know bout front tires but im going triple nickel g2 305/30/20 in the back.
01-22-2023, 12:18 PM | #156 |
Rep 2,349
I'm thinking 265 or 275 is what you'll need to run on the rear, then either 20 or 30mm narrower on the front to match the stretch. Keen to see the end result!
SCOTT26 "So as an admirer of the M5 and a potential customer of an M5 Touring. I would run naked around the streets of Garching if they were to offer one."
01-22-2023, 01:32 PM | #157 |
Rep 251
Why not a 295 or 305 Nitto g2?
01-22-2023, 02:34 PM | #158 |
BMW enthusiast since 2004
342
Rep 183
01-23-2023, 08:36 PM | #161 |
Rep 2,349
People running 34mm offset rear wheels can barely get 295mm tyres on there so a 20mm offset wheel will mean you'll need to go down to about a 265 or so. A 295 or 305 will absolutely not fit
01-24-2023, 09:52 AM | #162 |
Rep 251
02-01-2023, 06:51 AM | #164 |
Rep 5
Hey guys, my BMW F11 2011 (520 diesel, RWD) with 20 inch wheels. Stock height, factory spec tyres. The rear sits flush, the front could use with a 5mm spacer.
(Sorry for European measurements) Specs: Wheels: Aversus Kasia Front: 245/35R20 20x9 ET35 Rear: 275/30R20 20x10.5 ET42 |
03-01-2023, 03:21 PM | #166 |
Rep 75
Here's mine. 535d rwd. All the deletes and mods. Bc coilovers for over 70k miles.666m wheels 20x9.5 front 20x10.5 rear. 245/40 front 285/30 rear. Forget offset. Zero rub even with an iron block motor and a trans in the trunk and three full grown adults in it.
03-01-2023, 10:04 PM | #167 | |
Rep 1,037
https://www.carsaddiction.com/en/wheels/bmw/style-666 Looks good! Rep the diesel crowd! |
cb2004mj24.50 |
03-02-2023, 08:26 AM | #168 | |
Rep 75
03-02-2023, 10:20 PM | #169 |
Rep 1,037
Aha! Exposed! Lol
No sweat man, I totally get it. Either way your car looks great and that’s the point, right? I can’t recall seeing that wheel on an F10 before. It looks great! |
03-25-2024, 06:39 PM | #170 | |
Rep 64
Also, did you do anything with your rear camber? I would assume those 10.5" rears would stick out further than yours are... Last edited by Duck70; 03-25-2024 at 06:56 PM.. |
03-27-2024, 04:09 PM | #171 |
Rep 21
HRE FF04
20 x 9.5 ET 20 20 x 10.5 ET 26 |
B-Buster24.00 Blue Angel997.50 |
04-07-2024, 10:38 PM | #176 | |
Rep 64
Does the M5 brake conversion help at with additional clearances and fitment? |
HI_F1064.00 |
