2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes Sway bar angle to measure for End Links?
      12-30-2021, 10:07 AM   #45
Unspec
Unspec's Avatar
1312
Drives: 2015 BMW 535xi
Originally Posted by Bmwdoubles_ View Post
Got it so detach sway links while resting on ramps and adjust the sways accordingly
Yep, the flat part of the sway bar "arms" should be roughly parallel to the ground, at least it is for me. You'll see what I mean once you start adjusting.
2015 BMW 535xi
ISTA VM Setup/Tutorial
      12-30-2021, 09:45 PM   #46
BimmerHausPerformance
514
Drives: F10 S55, E93 M3, E89 N54
2012 BMW Z4  [0.00]
2011 BMW 535i  [10.00]
Originally Posted by Blue Angel View Post
Correction:
"Got it so detach sway links while resting on ramps and adjust the end links accordingly"
If you want an A+, put the front on ramps and jack the rear off the ground using the central jacking point. This will allow the front suspension to settle without being influenced by any unevenness in the ground.
This is also a great way to set up each corner height using coilovers if you don't have a known flat surface to work from.
You are exactly right, I demo's this in the YT video I did, I built tire cradles for this exact purpose. I am just too lazy to get my link situation sorted!
2011 F10 S55 6MT
      12-31-2021, 05:18 AM   #47
Blue Angel
Blue Angel's Avatar
Lol. At this time of year with cold weather and an icy driveway to work in, laziness definitely takes over for me!
      01-02-2022, 10:26 PM   #48
Bmwdoubles_
Bmwdoubles_'s Avatar
Drives: BMW F10 535
  [0.00]
Correction:
Makes sense thanks
BPM Tuned, Advanced Fuel Dynamics, Paddoq Valved Exhaust, Paddoq Magnetic Paddles, EDC dampers, Dinan Springs, H&R Sway. DCT all day long.
https://www.youtube.com/channel/UCFu...fWjCtOz49FDMlg
      03-29-2024, 08:15 PM   #49
John H.
John H.'s Avatar
Drives: 2014 535i XDrive
I installed the Super Pros adj. end links with my front H&R sway bar. I basically adjusted the links -1.5 in., which is my drop from lowering springs. There is a noticeable difference in handling....especially for those that have been on stock links for a long time. Going into/out of corners is much smoother, with greater sway bar performance range. In the near future, plan to do the rears with another set of Super Pros. I would definitely recommend adjustable links for spirited drivers. Cheers!
      03-29-2024, 09:24 PM   #50
Luky
Luky's Avatar
Drives: 2016 550i M Sport
Do you remember which specific end links you used? I was looking at super pros website and the parts selector only shows 2/3/4 series models. No 5er.
      03-29-2024, 09:56 PM   #51
John H.
John H.'s Avatar
SuperPro TRC12200 on H&R front sway. They are not application specific, as they are considered universal. Good quality.
The flat nut on adjustable link requires a thin wrench to hold. I bought an SAE wrench, as it fit better than my Metric wrench. Purchased the wrench on
AMZ... https://www.amazon.com/dp/B09G6HSV67...t_details&th=1
Currently, Super Pro products are on sale, 20% off.
Blue Angel1042.50
      03-31-2024, 11:18 AM   #52
514
2012 BMW Z4  [0.00]
Very nice! I have the same ones but need to install them. Excited that they worked!
John H.230.00
      04-06-2024, 05:24 PM   #53
John H.
John H.'s Avatar
Hi Dan, I have a set of rears on order. This will be a hybrid, TRC1025A (M10) and TRC1225A (M12). Basically, swapping ends...creating two sets. I spoke with SP Aus., stems are the same. Member Luky did the initial research on this. I report back with progress.
      04-08-2024, 07:46 AM   #54
514
2012 BMW Z4  [0.00]
Thanks for the info! That is something I'll need to do. Very curious if you feel a difference.
2011 F10 S55 6MT
