| 11-26-2024, 01:38 PM | #1 |
Rep 3
N20B20B engine overhaul
Hi, i was lucky to have my engine with 130k km spin one of its rod bearings.
These engines are for whatever reason extremely expensive and hard to get by. So after a lot of scouting for replacement engine, an overhaul has been decided. However i need torque specs for essentially the entire engine as most Of the engine have to be taken a part and cleaned properly to remove metallic residue. Changing the oil pump also. As that cannot be trusted anymore, and also Can the oil control valve be trusted? or disabled in anyway to keep max oil flow At all times? Regardless, what is most needed is the torque specs for all the nuts and bolts in this engine Assuming it is similar for both N20 eninges so for either is fine. Any tips to where to get a hold of or purchase is greatly appriciated. Cant seem to find it myself. |
| Bookmarks |
