2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum Car Died Completely
      07-21-2025, 12:51 PM   #1
BLKF10
BLKF10's Avatar
Drives: 2011 BMW 528i
Car Died Completely
2011 528i , turned on the car this morning without an issue, put it in reverse and the entire thing just turned off … not slowly, I mean rapidly and it has NO POWER. I tried to jump start it with one of those small portable jump starters. The car lights turn on, it cranks and then suddenly dies 100% again.
The car usually indicates when someone is wrong, there was no warning this time.
Waiting to test battery and possibly replace, but I never received a battery issue light on the dashboard?
The only thing that came up was a TPMS malfunction about 2 weeks ago and it has stayed on.
Any ideas!?
      07-21-2025, 01:40 PM   #2
zener
BMW enthusiast since 2004
828
Drives: E65 730d, F10 520d, E34 520i
What is the voltage measured from engine bay?
      07-21-2025, 09:10 PM   #3
BLKF10
BLKF10's Avatar
12.55 currently
      07-22-2025, 06:53 AM   #4
Walt White Coupe
Walt White Coupe's Avatar
295
Drives: 2013 650ix Coupe, 23 C8 Vette
At 12.56 volts, it's not the battery. On an AGM battery, that's over 80% charge.
      07-22-2025, 09:26 AM   #5
BLKF10
BLKF10's Avatar
After a battery test, this was the result.
      07-22-2025, 11:47 AM   #6
zener
828
And not battery cable... Seems to go bad on early models. I replaced mine just before failure.
      07-22-2025, 11:53 AM   #7
Walt White Coupe
295
Does the tester say why it should be replaced?
      07-22-2025, 01:24 PM   #8
I'd say it's the SOH (state of health). 64% is only 2/3 of it's capacity.
      07-22-2025, 03:45 PM   #9
Walt White Coupe
295
Seems to me, if that's the reason, it's about selling batteries. That should not have caused the OP's car to shutdown.
      08-08-2025, 11:45 PM   #10
BLKF10
BLKF10's Avatar
Update!
I have replaced the battery, programmed it using BimmerLink, and the car has not failed yet.
Although I’m still skeptical, not sure how/why a battery would cause an issue like that on a running vehicle.
I have cleared all codes & will scan again soon to see if anything pops up.
zrile187.50
zener828.00
      08-10-2025, 05:12 AM   #11
zrile
zrile's Avatar
Croatia
188
Drives: BMW F10 520d
I had e36 316i 6,7 years ago....once, it just died on road,battery was dead. Couldn't jumpstart it or push start it. Replaced battery and drove it 4 years with no problem.
