| 03-17-2023, 07:02 AM | #1 |
Rep 6
Retrofit OEM alarm
I retrofitted the alarm on my 2015 BMW F11 car but now I have a problem detecting the ECU, when I run ISTA it shows ECU FZD
But when I run esys the ECU FZD does not appear attachment: error in ISTA does anyone know the solution thanks |
| 03-18-2023, 12:19 AM | #2 |
![]() 957
Rep 1,231
Can you provide a bit more information?
Did you change the FZD (A21) from a basic to a "high version"? Did you install the alarm horn (H1) in the right rear bumper area? Did you run the LIN Bus wire from the H1 to the FZD? Did you code S145A option into your FA? What does ISTA list as your error code for the FZD module? |
| 03-20-2023, 11:36 AM | #3 | |
Rep 6
| 03-20-2023, 09:56 PM | #4 |
![]() 957
Rep 1,231
The diagram on page 9 of your installation manual doesn't look like your retrofitted alarm interfaces the FZD module, only the CAS.
This means your issue with the FZD in ISTA, is independent of your alarm wiring. On page 13 of the installation manual, it does show removal of your FZD module to route your alarm wire to your rearview mirror. I would recommend that if you did pull the FZD module, to remove it, and try to reseat all the connectors. It looks like the connector that has the bus wires isn't plugged all the way in. |
StradaRedlands11360.00 |
| 03-22-2023, 06:33 PM | #5 |
Rep 6
hello M_Bimmer
I only had the opportunity today to remove the FDZ module and I verified that the A21*2B connector does not have the CAN wires that connect pins 9 and 10. I will have to make this connection between connector A21*2B and connector A16*1B. |
| 09-21-2024, 04:11 AM | #6 | |
Rep 20
I retrofitted headliner antrazit and therefore I changed my FZD module with the one of the donor car. The donor car was equipped with alarm, mine not. Both have the SOS alarm. The plugs was identical, even though I didn’t check the single pins corredpondence. Now the FZD ECU isn’t visible in E-sys and in ISTA. All seems to work, apart the read lights both front and rear. How can I solve this issue? Thank you Last edited by ghostrider1969; 09-21-2024 at 06:48 AM.. |
| 09-21-2024, 05:41 PM | #7 |
![]() 957
Rep 1,231
ghostrider1969 ....I'm going to make some assumptions since you did not provide any details about your vehicle.
1st assumption: It's newer than 2010/09+ 2nd assumption: Your F10 is a sedan and not a GT model 3rd assumption: Your vanity mirror lights do NOT work 4th assumption: Your rain sensor does NOT work 5th assumption: Your sunroof does NOT work So...What is the MFG date of the donor F10 that you took the SZL from? 1. The ambient lighting wiring pinout pre-2010/09 and post-2010/09 are completely different (which if you connected one for the other, expect a blown fuse, and maybe damage to your rear lighting, and the SZL itself) 2. Check for +12VDC on SZL A21*4B Pin 1 3. Check for +12VDC on SZL A21*4B Pin 4 4. Check for +12VDC on SZL A21*2B Pin 12 ...1 or more of your fuses should be blown. I highly recommend you put the original one back into your car, then come back to the forum for help if you are trying to install an alarm.....which you will need more than just an upgraded SZL (High) unit. |
| 09-22-2024, 05:46 PM | #8 | |
Rep 20
My car was built 09/2011 It is a sedan (F10) Vanity mirror lights work The rain sensor seems work fine My car isn’t equipped with sunroof. My auto was equipped with SOS botton, bluetooth, USB, combox and teleservices. The donor car was built 11/2010. FZD of the donor car differ visually from the FZD I had in nothing. The donor F10 mounted alarm system. Both auto haven’t sunroof. Last edited by ghostrider1969; 09-22-2024 at 05:53 PM.. |
| 08-15-2025, 02:49 PM | #9 |
Rep 20
Hello,
Retrofitted alarm at BMW workshop to my F11 2013 but there is no acoustical when lock/unlock. Workshop told me this is the right behavior and cannot be changed. Any one has same experience? |
| Bookmarks |
