2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums F10 / F11 5-Series Photos - Video - Media What did you do to your 5 series today?
      12-22-2025, 10:50 AM   #3873
zener
BMW enthusiast since 2004
834
Drives: E65 730d, F10 520d, E34 520i
Gentleman button retrofit.
Also bought some wheels for next summer, but I'll probably get them painted silver...
      12-23-2025, 02:24 AM   #3874
ChampagneQrtzPapi
ChampagneQrtzPapi's Avatar
Drives: BMW 535i
Style 214? I haven’t seen them in that bicolor finish. I’ve toyed with this look as well, and I think all silver would look good!
      12-23-2025, 05:59 AM   #3875
zener
834
214 replica. These are 9,5" front and 10,5" rear.
      12-31-2025, 01:21 PM   #3876
zener
834
Had to replace front right soft close motor, because it wen't bad. It's good that I had one laying around. Wash day also.
      12-31-2025, 06:17 PM   #3877
TorqueAndBavaria
Semi-Feral Mechanic
TorqueAndBavaria's Avatar
Drives: 2012 BMW 535i xDrive
Buddy gave me his wheels and tires from his 550i because it’s getting scrapped, got myself a smoke tester and I passed the test! I also updated my ilevel software via enet and Ista! Went from 2015 to 2021 software!
You can live in a car but you can’t race a house.
      12-31-2025, 07:54 PM   #3878
lukmech03
Drives: BMW 535i
4 tires. Trying out a set of some cheapo Lionharts based on a recommendation from a buddy running them on a 650 RWHP C6. Less than $500 for 4 tires, cant be bad right
      01-03-2026, 11:50 PM   #3879
jared21927
Drives: 2016 550i
Any noticable difference in the software update? I always wondered about this but I've also read that updating the software erases your tune, if you have one.
      01-04-2026, 03:26 PM   #3880
TorqueAndBavaria
Semi-Feral Mechanic
I noticed that the seats move a little bit faster and the seat warmers heat up faster, but the biggest difference is whenever I have cold starts the N55 doesn’t drop RPMs as much in it idles a lot better. I didn’t have to reflash My MHD tune, but I did have to refresh my XHP because the software update removes a lot of coding features.
      01-05-2026, 07:46 PM   #3881
jared21927
Drives: 2016 550i
I noticed that the seats move a little bit faster and the seat warmers heat up faster, but the biggest difference is whenever I have cold starts the N 55 doesn’t drop RPMs as much in it idles a lot better. I didn’t have to reflash My MHD tune, but I did have to refresh my XHP because the software update removes a lot of coding features.
Good to know. Thanks!
      01-05-2026, 08:01 PM   #3882
jared21927
Drives: 2016 550i
New diffuser I bought myself for Christmas after a ton of research. This is probably the 4th or 5th I've tried but after lots and lots of research, I realized that there's a difference in M5 specific diffusers and 550 specific diffusers. I had no idea, they look the same in pictures....but they're not.
The M5 exhaust tips are more centered like they are on the other M series cars.The 550 tips angle outward so that's why I've always had fitment issues. 95% of listings say they fit 550 and M5s, which they technically do, but requires modification of the exhaust for the 550. I found one that said it was only compatible with the 550 and would not fit the M5. Perfect fit from day 1 no exhaust modification needed. Hope this helps someone one day.
      01-06-2026, 12:53 AM   #3883
TorqueAndBavaria
Semi-Feral Mechanic
Swapped out the cornering bulbs for LED ones from LASFIT! Ordered H7 6000k 1:1 size on Amazon. Pics of the install and required coding! One thing I would make sure you have is a 1/4 ratchet and 1/4 T20 bit. There are two T20 bolts that hold the bulb in. All you need to do is loosen them and twist the bulb to the left. Reinstall in reverse order.
NikMN4563.00
      01-06-2026, 09:43 AM   #3884
jared21927
Drives: 2016 550i
Blackstone oil report came back on the 550. Don't be scared of the V8. I've had mine just over 3 years and done meticulous maintenance. It's been on a custom BM3 tune and stage 3 xhp for most of my ownership. Take care of your car and for the most part, it will take care of you.
      01-06-2026, 08:34 PM   #3885
ctcarbonari
ctcarbonari's Avatar
Drives: 2015 BMW 535i M Sport
2015 BMW 535i  [0.00]
It's always a happy day for me when I check my email and my Blackstone OA report is ready!
They'll do OA on your tranny oil too!
      01-07-2026, 08:42 AM   #3886
fredde85
fredde85's Avatar
25
Drives: BMW 428i
Do you have the part nr for the Gentleman button?
      01-07-2026, 01:07 PM   #3887
zener
834
Yes it is this one: https://www.hubauer-shop.de/de/bedie...319361174.html
      01-07-2026, 01:53 PM   #3888
jared21927
Drives: 2016 550i
Agreed. An even better day if the report is good lol
      01-07-2026, 03:50 PM   #3889
s_ribs
Drives: '15 535i xDrive M-Sport, E30
I was getting ready to redo this task again when I thought to myself "hey dummy, why don't you make sure it's not the cap?" as I had a hard time believing that the previous silicone bead didn't seal.
So, a few days ago I applied 1/4" window weather stripping to the inside of the cap.
Bingo - No more condensation.
What thickness weather stripping did you use? I grabbed some off amazon that is 1/4" thick and there was no way I was getting the caps back on. Wondering if I need to find something that's 1/8" thick instead.
      01-08-2026, 01:24 PM   #3890
TorqueAndBavaria
Semi-Feral Mechanic
Originally Posted by markivvv View Post
Changed out the old halogen interior dome lights, footwell lights, and door lights out for some LEDs. Swapping in these lights along with the LCI steering wheel has made my pre-LCI feel so much more modern and IMO it’s probably the best bang for buck interior mod I’ve done, at only $7.
Next up: making the OEM ambient lighting brighter with some replacement LEDs
Lemme get the link for this kit because $7 is cheap!!
      01-15-2026, 10:13 PM   #3891
ctcarbonari
1/4" window weather stripping from Lowes. And yes, I had to mash the cap back down and twist.
Long story short: My condensation issues came back after 2-3 weeks. Twice I removed the headlamp assembly entirely, dried completely, and went at every possible mating point I could find with silicone. Both times it seemed to work after reassembly; however, again, after 2-3 weeks the condensation would return and gradually get worse.
Last week I installed a new headlight assembly. Condensation issue fixed. However, I have to go back at it one more time and install a new Xenon Headlight Control module as I let the issue persist for too long and fried the board. (Low Beams, High Beams, turn signals work. Adaptive lighting and DRLs do not)
Don't do what I did and wait too long, that board sits at the bottom of the headlight assembly and is very susceptible to the moisture.
s_ribs136.00
      01-16-2026, 08:31 AM   #3892
markivvv
Drives: F10 535i M Sport
https://www.amazon.com/dp/B00JRE38EA
Here you go! If I remember correctly I was was short a couple as this is a 10 pack and you need 12 (4 door lights, 2 footwell lights, 3 front dome lights, 3 rear dome lights). I replaced everything else except the rear dome lights, on those I only replaced the main light in the middle. Don't really use those anyways so it works out
      01-16-2026, 09:58 AM   #3893
musclesmarinara75
musclesmarinara75's Avatar
2013 535 XDrive  [9.75]
Module
I have an extra module if u want purchase it, I have a 2013 535 pre LCI do not know if they are all compatible
$ PURE STAGE 2 {} JORDAN CUSTOM TUNE {}TURNER CF INTAKE{}BURGER OCC{} DORCH HPFP {} SNOW 2.5 METH {} MPE EXHAUST {} EVOLV DARK OLIVE WRAP $
      01-16-2026, 03:24 PM   #3894
ctcarbonari
The offer is MUCH appreciated! However, I've pulled the trigger and have a new one on the way.
