2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes Pictures of F01 303 20" wheels on F11 - Opinions?
      11-12-2010, 04:21 PM   #1
ClausCoupe
Norway
30
Drives: Soon: 640xi Gran Coupe
Hi,
I got to try on a set of 20" M-sport 303s which is for the 7 series, on my F11 today. I love these wheels, but needed to check if it was possible with the offset of the wheels.
I think the rear looks perfect! What do you guys think? Does the front wheel stick out too much?
FYI the tyres on these wheels are for the 7 series, so too much rubber.
They are 245/40/20 (front) and 275/35/20 (rear)
On the 5 series they should be:
245/35/20 (front) and 275/30/20 (rear)
Question: Do you think I should try out a 235/35/20 in front, to keep as much of the tyre inside the fender?
Also; Is it OK to do this. A bit concerned about the fact that these wheels wasn't built for this car. Offsets are off (even though it looks nice).
Is there any other cons for using different offset than the actual fitting of the wheel?
Best
Claus
      11-13-2010, 03:11 AM   #2
wannes
Drives: BMW 535 E61
i thought to try it myself
but now that i saw it ... i don't realy like it ... they don't become 'one ' with the car ...
      11-13-2010, 08:34 AM   #3
deejaygee
Drives: 320d M Sport
I have to say and this is only my opinion but not feeling those wheels, they look to big for some reason.
      11-13-2010, 04:38 PM   #4
cidair
cidair
cidair's Avatar
Sweden
93
Drives: BMW 435d xDrive
Wow, I think they look terrific! Really powerful wheels.
But, as You say, there are too much rubber. The diameter of the wheels are too big.
One other consideration with big offset changes are that you change the wheel geometry. I don´t know if it makes any big difference with 8mm / side?
2016 435d xDrive
Previous:2019 M340i, 2014 335dx,2012 M5,2011 550ix,2008 M3,2007 330xd,2005 M5,2004 545iA,2000M5.
      11-14-2010, 07:03 AM   #5
remmib
remmib's Avatar
Norway
1645
Drives: 2013 F10 520d M-Sport
I think this should work and the wheels looks great, of course change the tires to F10/11 size.
The difference in offset is 8mm in the front. ET25 (F01/F07) vs. ET33 (F10/F11)
Also, I think Lacster is running 20x9 ET25 on his F10.
      11-14-2010, 10:59 AM   #6
Jason
Jason's Avatar
Drives: F80 M3
I think they look great. The F11 is no small car so the 20" fits it nicely.
Check on the Latest BMW News
      11-14-2010, 04:30 PM   #7
ClausCoupe
Norway
30
Yeah, I need to change tyres.
Do you think I should go for 235/35/20? F11s normal tyressize is 245/35/20.
Because the offset is a bit off, maybe I should compensate with a narrower front tyre?
Also: This car need to be lowered! Is that a problem with EDC?
Any expert comments on this matter?
/c
      11-15-2010, 10:49 AM   #8
remmib
remmib's Avatar
Norway
1645
/c
I'd stick to 245/35/20. Lacster's F10 has 20x9 ET25 with 245/35/20 (stated in post #80 in this thread). He's now lowered on KW v3 coilovers.
http://f10.5post.com/forums/showthread.php?t=401721
ACSchnitzer has lowering spring for F10/11 with EDC.
Take a look at EdwinF10's F10, looks great if you don't want to slam it.
http://f10.5post.com/forums/showthread.php?t=451540
      02-08-2011, 11:06 AM   #9
remmib
remmib's Avatar
Norway
1645
Forget the 20s, here the 21" 311 on a F10.
http://f10.5post.com/forums/showthread.php?t=486370
      05-28-2011, 03:53 PM   #10
BMW BRAD
BMW BRAD's Avatar
Drives: F10 535d M, F31 328d M
^^^^ WOW! That is the the best looking f10's I have seen! WOW! ^^^^
[SIGPIC]
