2010 2011 BMW 5 Series Forum F10 What did you do to your 5 series today? |
03-05-2022, 04:43 PM | #2575 |
Rep 3,089
Drives: 2006 BMW 330i MT
Garage List 2006 BMW 330i [8.25]
2009 BMW 328i Touri ... [8.00] 2013 BMW X5 35i [7.80] 2011 BMW 528i [8.70] 2006 Mazda3 [5.50] |
Today was air filter day! The engine air filter is quick and easy, but cabin air filter took a bit of work. Not as bad as on our Mazda3 (those are miserable!) but more of a hassle than on our E90! Hengst aftermarket filter definitely flimsier than the BMW/Mahle (original?) cabin filter I took out.
03-06-2022, 10:01 PM | #2576 |
Rep 3,089
Driver's side door pull/handle swap out. Pretty easy job. The ebay replacements look and feel fine, but bolt holes weren't 100% lined up. Took a little massaging to get just right, but in the end a huge improvement over the nasty disintegrating one!
musclesmarinara75206.00 4Romie112.00 |
03-10-2022, 10:52 AM | #2577 |
Rep 507
Drives: 2013 BMW F10 N55 535i XDrive
I did the same thing not to long ago, night and day difference, and you can find good ones on ebay for a good price!!
$ PURE STAGE 2 {} JORDAN CUSTOM TUNE {} DORCH HPFP {} SNOW METH {} DINAN EXHAUST {} EVOLV DARK OLIVE WRAP $
StradaRedlands5033.50 |
03-16-2022, 12:54 AM | #2578 |
Rep 3,089
I paid a professional to change the transmission fluid and filter/pan! Not the hardest job, but hard enough that I figured I'd help cover their salary today!
03-16-2022, 05:40 AM | #2579 |
Petrolhead
445
Rep 814
Drives: 24 X3 M40i/14 550i/08 Z4 3.0si
Honestly probably worth it. Yes not the hardest job, but without a real lift, you're lying on your back for 2 hours with sore a** arms and fluid dripping down all over you. Can truthfully say it was "the" job I hated doing on my car.
2024 X3 M40i 2014 550i 2008 Z4 3.0si 6MT 2011 Z4 35si (sold) |
SummerallGuard0483.50 StradaRedlands5033.50 |
03-16-2022, 06:02 PM | #2580 | |
Rep 3,089
My accessory belt kit came in today... no excuses for not doing that one myself though! |
03-16-2022, 07:33 PM | #2581 |
Rep 5,409
spielnicht444.50 |
03-16-2022, 07:43 PM | #2582 |
Rep 114
Swapped out the hideous chrome grills with the gloss-black dual slats, removed the front license plate and bracket, plugged the 4(!) holes left behind and debadged the rear...oh and threw in a bottle of Liqui Moly Jectron at fuel fill-up today. Finally got it looking to where I want it. I'm thinking I'm going to smoke vinyl overlay the fogs next.
2016 BMW 550i M Sport - Mineral Gray Metallic
2015 BMW X5 base - Jet Black 2011 BMW 335i - Alpine White Last edited by SummerallGuard04; 03-16-2022 at 07:53 PM.. |
03-17-2022, 12:33 AM | #2583 | |
Rep 3,089
Nice garage BTW! |
SummerallGuard0483.50 |
03-20-2022, 06:47 PM | #2584 |
Rep 3,089
When I took the 5er in for "intake clatter," the indy suggested accessory belt & tensioner be changed out. I don't have any record of P.O. doing that, so today was the day! $500 for them to do it, or $130 in parts and I do it. And what an easy job! I was worried about clearances and thought I might have to pull all the trim and fan, but easy fitment. I couldn't quite nail down a definitive torque amount for the bolt, but averaged everything I could find and settled on 25Nm+90^. Didn't break, so that's good! This was my redemption for paying to get the transmission serviced last week!
Also tried fitting on some ebay pedal inserts. The accelerator and brake were fine, but the dead pedal was for a RHD vehicle, or just poorly designed. Definitely isn't going to work. You can kind of see the outside lip on the wrong side here: And finally, buffed out as much as I could of last week's parking lot hit and run. Sucks. Last edited by StradaRedlands; 03-21-2022 at 02:00 AM.. |
03-22-2022, 07:36 PM | #2585 |
Rep 114
Blacked out my fogs and front side amber markers:
2015 BMW X5 base - Jet Black 2011 BMW 335i - Alpine White |
03-23-2022, 02:03 PM | #2586 |
Rep 3
Upgraded Grille.
Changed the front Grille. Grey & black works so well.
What're your thoughts on changing the grey wing mirror covers for black flare tip ones? Thanks! 😃 |
03-28-2022, 08:32 PM | #2587 |
Rep 262
It was a long weekend, but got alot done.
Guibos/Flex Discs replaced
2011 550i (N63)
Upgraded 51mm turbos, Heatsync Stage 3 Flash, JB4 stacked, BMS WMI, Arm Charge Pipes, Heatsync Catless DPs, X-Pipe, Res Muffler Delete, xHP Stage 3 Trans Flash, Turbosmart Diverter Valves, 3.5 TMAPs, Oil Cooler, Heatsync Front Mounted Max Cool Intakes, Walbro LPFP and e40 mix rollin on Stance SF07 9x20 w/Toyo Extensa and 10.5x20 w/Toyo R888R. |
03-28-2022, 08:34 PM | #2588 |
Rep 262
6WA install with custom face plates. I know it's not everyone's cup of tea but I just wanted something more me.
2011 550i (N63)
03-28-2022, 08:38 PM | #2589 |
Rep 262
OLED taillights and Air Filters. Last weekend I swapped out my RacingDynamics DP's (garbage) for Heatsync DP's. The next few days will be LPFP. Finally some warm enough weather for all this stuff to happen
2011 550i (N63)
04-09-2022, 11:11 PM | #2590 |
Rep 262
Updated the old CIC screen with a touch screen 10.5", pretty nice update for the interior. Just need the steering wheel and time for paint.
2011 550i (N63)
cdmulders330.50 jayster0966209.00 |
04-13-2022, 11:39 PM | #2591 |
Rep 5,409
Actually, yesterday. I replaced the cabin filters in our 2014. That was the hardest, easiest job I think I've done! Gaining access was the hardest part. Interestingly, the filters were installed backwards! I'm pretty sure they were never changed as we bought the car with ~25K miles on the clock and we're now at 77K miles. From what I've read, it is very, very common to have the filters installed backwards.
04-15-2022, 08:49 PM | #2592 |
Rep 14,521
Wow 4/13/2017 I created this thread and it's still running pretty strong 118 pages! That's freakin AWESOME fam!
04-16-2022, 12:11 AM | #2593 |
Rep 188
I view this thread multiple times a day! Thanks for creating it, turbo!!
04-17-2022, 05:42 AM | #2594 |
Rep 179
Drives: BMW 535i F10
New lip installed
04-21-2022, 06:14 PM | #2596 |
Rep 1,156
The best part of being part of a community is the ability to help one another out.
This weekend I was able to do a full detail on a good friend and forum members F10. (Addy27) Also, his new custom plate came in so it was a nice touch to put that on after finishing! The car had light swirling and other light scratches all around.. The process was as follows. The car came to be already washed. Clay Barred the entire car Washed the car with CarPro Iron X Decon Soap in my foam cannon, and scrubbed down the paint with a clay mitt. Rinsed and Foamed again, and rinsed thoroughly. First pass with medium cutting foam pad and Griot's Garage Compound Second pass with Jeffs Werkstatt Prime Polish, with foam polishing pad Third pass with Jeffs Werkstatt Prime Acrylic Sealant, with foam finishing pad Then another wash with CarPro Reset in the Foam Cannon Finished off with a wipe down of the entire car using Griot's Garage Spray Wax... This Black Sapphire Metallic beast looked amazing when done. I was also able to play with this beast on the back roads, It has Alpina Turbos / Intercoolers and Dinan Stage 6 tune, along with A BUNCH of other upgrades.... Everytime i put my foot down the gas needle moved a few centimeters First 2 pics are before rest are after... Enjoy the pics... |
lukavergille206.00 addy27389.00 cdmulders330.50 SummerallGuard0483.50 musclesmarinara75206.00 destruct00718.00 |
