2010 2011 BMW 5 Series Forum F10 Trunk Subwoofer w/o Ski Pass-through |
01-05-2016, 08:00 PM | #287 | |
Rep 769
01-05-2016, 08:00 PM | #288 | |
Rep 203
01-05-2016, 09:04 PM | #289 | |
Rep 14,521
01-05-2016, 09:10 PM | #290 | |
Rep 203
Teddy: I think your best bet for quick responses would be to post a new thread on the topic in the F30 forum. That forum gets a LOT more attention and the F30 is basically identical to the F10 for this subject. I'm honestly surprised Shawn hasn't responded to you yet. |
01-05-2016, 09:26 PM | #291 | ||
Rep 769
01-05-2016, 10:01 PM | #292 | |
ZEROdoubleZERO
228
Rep 659
01-05-2016, 10:18 PM | #293 | |
ZEROdoubleZERO
228
Rep 659
01-13-2016, 03:52 PM | #294 |
Rep 14,521
Got my subs in and I'll wait for them to break in But i got them wired up just like the above diagram. but I was trying to setup my tuning but imma be a newbie at this again but what would I set my crossover on my head unit? I use to have them set at 80hz and my high pass filter at 80hz. Any suggestions if I should said the low pass to 100hz or even 125hz? I can hear the subs cutoff on certain songs that I think is going to the mids but I'm not sure if it's because the subs are still new? I did put 16 ounces(1lb) of polyfill in each chamber. Any suggestions or am I good for now?
01-13-2016, 10:22 PM | #295 |
Rep 769
01-13-2016, 11:10 PM | #296 | |
Rep 203
01-14-2016, 02:46 AM | #297 | |
ZEROdoubleZERO
228
Rep 659
01-14-2016, 02:59 AM | #298 |
ZEROdoubleZERO
228
Rep 659
01-14-2016, 03:17 AM | #299 |
ZEROdoubleZERO
228
Rep 659
My box is different so 200hz may not sound that good for a standard ported or sealed box. I tried setting the crossover at 80hz and 125hz but it didn't hit as hard so I set it back to 200hz. I wish you guys could hear my box the bass is super deep and tight, it is super powerful at normal volume but doesn't over power the stock mids and highs. BUT with a twist on the volume and my bass knob it's good by highs or hearing anything else other than retarded bass, it is very much like an spl setup like Nelson mentioned but it's not what I'm using it for. The bass is just amazing and clean, I've never heard a sealed or ported box come close to this before. I'll never use anything other than a 4th order again, it's what Bose has been using for its subs for the last 20-30 years.
01-14-2016, 03:41 AM | #300 |
Rep 14,521
cool...i'll let them break in and by the end of the week i'll mess around with the settings.
01-14-2016, 07:08 AM | #301 | |
Rep 203
01-14-2016, 08:56 AM | #303 | |
Rep 14,521
I think what I'm trying to understand is series or parallel back to the amp...what's the difference?
~F90Conversion~21"3Piece Forged AvantGardeWheels~KWV1Coilovers~CQUENCE slotted/drilled rotors~GoodridgeStainlesslines~MeisterschaftQuadEx haust~Akrapovic 4"tips~VRSF DP~VRSF CP~TurboSmart BOV~K&N filter~CarbonFiberExteriorComponents~GladenAlphaCo mponents~MatchUp7BMW~Punch P300-12T~ Follow me on Instagram: lsturbointeg Last edited by lsturbointeg; 01-14-2016 at 09:14 AM.. |
01-14-2016, 09:04 AM | #304 | ||
Rep 769
01-14-2016, 02:57 PM | #305 |
Rep 14,521
Guys, is this series or parallel? Here's what Kicker emailed me:
Gene, select 8 on the switches and wire the subs in parallel. If you have any further questions let me know. Have a great day.
01-14-2016, 08:28 PM | #306 |
ZEROdoubleZERO
228
Rep 659
That diagram shows a series+parallel configuration, the coils on the subs are wired in series and then they wired in parallel to the amp. I think what's got you confused is the fact your subs seem to have a switch that already puts them into a series or parallel configuration without having to physically wire them, so there's no need to wire them like in the drawing you provided. Just flip the switch to 8ohms and then wire both subs to the amp in parallel to get a 4ohm load.
01-14-2016, 09:32 PM | #307 | |
Rep 14,521
01-14-2016, 09:36 PM | #308 | |
Rep 14,521
Also, just to confirm the 1 lb polyfill on each side the sub sits in it like a bird nest...should I have some air space between the sub and polyfill? I know when I ram my Jl's my box was deeper so 1 lb just filled it half way. In my Nissan box it's pretty shallow. Like I posted there's about 1.25" of space between the sub and the bottom of the box so I'm wondering if I have too much polyfill?
