2010 2011 BMW 5 Series Forum F10 Trunk Subwoofer w/o Ski Pass-through |
01-14-2016, 09:52 PM | #309 | ||
Rep 769
01-14-2016, 09:56 PM | #310 | ||
Rep 769
01-14-2016, 11:33 PM | #311 |
Rep 14,521
dual voice coil. the amp will be bridged to a 4 ohm load.
01-15-2016, 02:57 AM | #312 | |
ZEROdoubleZERO
228
Rep 659
Also your poly fill is fine, just make sure its evenly distributed in the box. |
01-15-2016, 04:50 AM | #313 |
Rep 14,521
okay mine is currently wired up series voice coils/ woofers wired in parallel. Thanks Teddy!
i think i'm getting old because on the way to the gym cause it takes me 45 min to get there LOL i found myself turning the sub level output down after like 30 minutes. it's clean hard hitting bass but after awhile it give me somewhat of a headache just pounding and pounding! i listen to a lot of TRAP music!
01-16-2016, 10:58 PM | #314 |
Rep 14,521
so everything's been running great but now when i'm pushing these subs i'll lose signal in and out...not sure if it's the amp self protecting when getting too hot? i am running a cap to both amps. i think they call this clipping right? or my rca's to the sub amp is taking a $hit and needs to be replaced? i'm trying to think of why it's doing this? shouldn't be the way the subs are wired back to the amp right?
01-17-2016, 12:14 AM | #315 |
Rep 14,521
update: i rescraped both grounds to the the chasis...a lil bit of buildup i noticed. also, i checked the gain controls as it was probably around 85%...kicked it down to 50%. amp crossover i notice was active, turned it off since my headunit itself has all the DSP settings. reconnected everything and so far so good!
01-20-2016, 03:47 AM | #316 |
ZEROdoubleZERO
228
Rep 659
I haven't been getting anymore battery drain faults and I've been playing the stereo pretty loud every time I drive my car. I'm going to put my jl 1000/1 on my new subs and remove the AQ3500d to compare and test the electrical system to see how well it maintains 1000 watts vs 3500 watts. I'm hoping to update this thread with the last of my build picks soon, but I've been busy working on my girls e60, I did here rear brakes, oil change, removed her headlights and sanded and polished the lenses, replaced the hid bulbs, fog light bulbs, installed led halo bulbs and removed the LED strip from the eyebrows and changed the amber LEDs to super bright white LEDs. That was a chore but her headlights are bright as hell now and they look 100x better.
01-20-2016, 05:16 AM | #317 | |
Rep 14,521
~F90Conversion~21"3Piece Forged AvantGardeWheels~KWV1Coilovers~CQUENCE slotted/drilled rotors~GoodridgeStainlesslines~MeisterschaftQuadEx haust~Akrapovic 4"tips~VRSF DP~VRSF CP~TurboSmart BOV~K&N filter~CarbonFiberExteriorComponents~GladenAlphaCo mponents~MatchUp7BMW~Punch P300-12T~ Follow me on Instagram: lsturbointeg Last edited by lsturbointeg; 01-20-2016 at 05:29 AM.. |
01-20-2016, 04:08 PM | #318 | |
ZEROdoubleZERO
228
Rep 659
01-20-2016, 04:46 PM | #319 |
Rep 14,521
$hit I'll give it a try. Battery is about 3 years old maybe?
01-20-2016, 09:18 PM | #320 |
Rep 14,521
Teddy, so I tried a couple things on the way to the gym since its a 45 min commute. On low volumes I mean low low the sub still randomly fluctuates. On the way home the bass hit hard and medium volume all the way home for 45 min! Not once did it fluctuate. I'm hoping it's the Stinger RCA's as they are about 15 years old now since I had them in my Integra back in the days. Already ordered some new ones so I'll update of it fixes the problem
01-21-2016, 09:52 PM | #321 | |
ZEROdoubleZERO
228
Rep 659
01-29-2016, 04:44 PM | #322 | |
Rep 769
01-30-2016, 01:58 PM | #323 |
Rep 769
So I got trunk subs added to the bimmertech amp. Changes the sound completely. Definitely worth it to do it. Only problem I'm having is that there is hard hitting bass until I get up high to about 75-80% volume then the bass starts to fluctuate. Almost like it's giving out and they don't have enough juice. To me it's like a voltage problem but I wouldn't even know where to start to diagnose it. I'll add some pictures in a bit, but any ideas as to what the problem may be?
01-30-2016, 10:04 PM | #324 | |
Rep 14,521
01-30-2016, 10:15 PM | #325 | |
Rep 14,521
02-02-2016, 03:47 PM | #326 | |
ZEROdoubleZERO
228
Rep 659
02-17-2016, 02:27 AM | #327 |
ZEROdoubleZERO
228
Rep 659
Guys I've thoroughly tested my sub setup and will be posting the final install pics and my results. I can say it's not for everyone but if you like mega bass it will be the best option.
02-17-2016, 08:01 AM | #328 |
Rep 14,521
It's about DAMN TIME!
02-17-2016, 08:40 PM | #330 |
ZEROdoubleZERO
228
Rep 659
