02-01-2020, 07:53 AM | #23 |
Rep 1,458
Drives: F10 S55, E93 M3, E89 N54
I just did a write up in the suspension section.
04-12-2020, 12:16 PM | #24 |
Rep 159
Lol I come here to this thread thinking finally someone had the balls to do the LSD conversion and bunch of people end up discussing suspension mods.
04-12-2020, 12:29 PM | #25 |
Rep 1,458
I am gonna do this eventually - makes too big of a difference not to! But after a turbo.
Bmwdoubles_210.00 |
04-13-2020, 09:29 AM | #26 | |
Rep 137
I did message RacingDiffs.com and asked them if they make anytrhing for the F10 535i and this was their response: "Hello, Justin Unfortunately nothing that we currently have available will fit into your differential. Due to high demands for production of other parts and company’s strategy which leads us in different direction, we are not able to tell you when we will be able to make the set for your application. Sorry about that. " |
04-13-2020, 12:50 PM | #27 | |
Rep 1,458
04-16-2020, 09:14 AM | #28 | |
Rep 683
I think BMW makes pretty stout axles. 90% of us modding are never really going to get over 380WHP anyway. The few that are over that mark on F10s/ F06s are all running stock axles without problems (to the best of my knowledge** someone please correct me if I am wrong). Based on that, I think that for most of us that just want to have a locking rear diff, the Quaife would be plenty enough. What are your thoughts guys?
2011 F10 Shuenk N55+ Turbo'd is SOLD. Building a 2018 Golf R! |
04-16-2020, 10:21 AM | #29 |
Rep 1,458
Wow yea, good info and you are right, probably NOT worth it. n54 335's M diff is a direct swap - but it doesn't surprise me we have that much difference between our 535's and M5's.
Full bolt-on and e85 (with tune obviously) will get you over 400 WHP out of a n55. I mentioned this in the LPFP thread where a guy had that and dyno'd over 400. Link in the other thread. |
95blkmax222.00 |
04-17-2020, 10:08 AM | #30 |
Rep 221
Just to throw in my $.02 worth, I just tried installing the WaveTrac LSD in my 2011 535 and even though WaveTrac shows PN#30.309.175WK as the required part, IT DOES NOT FIT. It is actually made for the older type diff with the output flanges which we do not have.
04-17-2020, 04:09 PM | #31 |
Rep 159
Think if my puts cash in I may look into getting the Wavetrac for the 550:
https://www.ecstuning.com/b-wavetrac...309172wkwvtkt/ Realistically I'm looking into about 3k since ring gear is apparently welded on and needs a shop. That's if I remove the pumpkin myself which I may be able to do. |
04-17-2020, 05:15 PM | #32 | |
Rep 5,611
04-17-2020, 06:50 PM | #33 |
Rep 1,458
I've got a 535 6MT, I wonder what the difference is between my diff and a 550 diff. I'm sure the 550 one is a lot more similar to the M5 diff.
04-18-2020, 01:22 PM | #34 |
Rep 221
Don't quote me on this but if I am not mistaken the 550 diffs are welded and the axle diameter and spline count may be different
04-19-2020, 01:46 PM | #35 |
Rep 159
04-29-2020, 10:26 PM | #36 |
Rep 137
MODs: "FBO" VRSF Downpipe, VRSF Chargepipe, BMS CAI, GPlus FMIC, GFB DV+, Walbro 450 LPFP, MHD Stage 2+, 20" HRE FF01, KGSplitters 5-Piece Kit
04-29-2020, 10:37 PM | #37 |
Rep 1,458
Looks like an option! 3000-4000 ish depending on options.
05-03-2020, 10:19 PM | #38 |
Rep 683
I just realized this was a nugget of information that was not delved into! Are we talking E90/ E90 LCI 335?
05-03-2020, 10:33 PM | #39 | |
Rep 221
05-04-2020, 09:28 AM | #40 | |
Rep 683
UNLESS, what Brow meant was the gear set? Unfortunately I have no way to confirm if this would work or not based on the catalog, as these internal parts are not sold separately by BMW. External shape and dimensions are VERY similar so it's possible???
05-04-2020, 10:10 AM | #41 |
Rep 137
From some brief research it looks like the E9x diffs have axle shaft flanges and the F10s do not. I don't know if those are removable and the F10 axle would fit.
05-04-2020, 08:50 PM | #42 |
Rep 221
The flanges are removable. Problem I came across with the Wavetrac unit is that even it was listed for F10 it was designed for the E90 which some have the same gear ratios. Problem came up when trying to insert the F10 axle into the diff the axle diameter was larger and the axle spline count was completely different.
05-05-2020, 07:57 AM | #43 | |
Rep 683
