04-02-2018, 03:19 AM | #23 |
Rep 1,693
I just saw pics and realised that the N55 turbo has its turbine housing mounted via a bracket to the engine! That would give it plenty enough support. Now I'm thinking I'll just get the VRSF DP. It has a flex section but no mounts.
Thoughts? |
01-25-2019, 11:07 AM | #25 |
Rep 161
Drives: 2015 535i
Did you read the first page of this thread? Thats all they talk about....
2015 F10 535i
FBO BM3 Pure Stage 2 Dorch Stage 2 HPFP E50 tune by Cary Jordan EOS EkP Module Walbro 525 LPFP Variant Argon 20? Wheels E60 M550i Sold “Im a crazy car guy” If it has a motor, it has my attention |
T-Bone1822.00 |
01-25-2019, 11:25 AM | #26 | |
Rep 509
I am hesitant to install it, as the local police are subjectively ticketing vehicles that look and sound loud. It's a pita, and they already eye my car because I'm lowered, and my mufflers are polished. Last edited by John H.; 01-25-2019 at 11:36 AM.. Reason: Added info. |
01-25-2019, 11:56 AM | #27 |
Rep 19
Yes I have but no one has mentioned if it was safe or not, preciate the feedback👍🏼
01-25-2019, 11:57 AM | #28 |
Rep 19
John H.313.00 |
01-25-2019, 12:09 PM | #29 | ||
Rep 19
01-28-2019, 06:18 AM | #31 |
Rep 217
I purchased a low mileage OEM catted downpipe off here and then gutted my 100k Mile one. So I can go back to factory if needed. As for smell, its nothing. The wife did notice at first. She is used to it now. Smells fine on E30.
01-28-2019, 08:51 AM | #32 |
Rep 14,521
I'm gonna ask as I've never seen it done but how exactly do you guys gut the DP and does the exhaust note change at all? Thanks!
01-28-2019, 03:13 PM | #33 |
Rep 161
Drives: 2015 535i
Some people actually cut them in half and clear out the honeycomb as best they can with chisels and other tools and then weld them back together. Ive seen others use punches, torches and bunch of other crafty tools to remove the internals without cutting it apart. Personally I would cut and weld and get out as much of the internals as possible but to each their own.
2015 F10 535i
01-28-2019, 05:34 PM | #34 |
Rep 1,693
It's completely unnecessary to cut and weld. Just use a long spade bit and a drill and it cuts through the honeycomb like butter.
Having said that, gutted cats are crap. The big empty chamber is shit for both sound and turbulence. |
11-21-2020, 08:09 PM | #35 |
Rep 78
Drives: 2014 535i xDrive
Can somebody make a video of what our F10 N55 sound like with a gutted DP vs VRSF Catless downpipe video vs Highflow downpipe, all these with stock exhaust.
11-21-2020, 09:46 PM | #36 |
Rep 2,637
That's a fuck ton of work to basically get "sounds like nothing, sounds like nothing, sounds like nothing". The stock mufflers are really good at muffling.
2015 BMW 535xi
11-22-2020, 07:21 PM | #37 |
Rep 4,633
They are both pretty quiet, i cant tell the difference between the two honestly.
Current: E63S AMG 4matic RENNtech || M5 Evolve..Eventuri || F10 LCI 535i MHD
11-22-2020, 07:35 PM | #38 | |
Rep 78
Now my next dilemma is, how bad is the smell and how do you guys deal with that ? Again we driving a 5 series, which is mostly for comfort. I don't know if you guys carry people in the back seat, your kids maybe, so how it is in the cabin odor wise ? Also, does it smoke ? Evolution Racewerks have a Ceramic Coating DP and here is what they advertise. I would like to know what is your opinion on that feature regarding the smell ? Do you think it's actually smoke less with less fume, less odor or no difference ? Ceramic Thermal Coating The purpose of ceramic coating downpipes is to keep heat from the exhaust gases inside the downpipe from radiating out. This keeps underhood temperatures lower and less heat absorption by nearby parts/surfaces. Another added benefit is that by keeping in heat (energy) in the exhaust gases inside the downpipe, exhaust flow velocities stay up, resulting in lower backpressure. Last edited by T-Bone18; 11-22-2020 at 07:45 PM.. |
11-23-2020, 11:14 AM | #39 | |
Rep 2,637
Even with my hi-flow cats, you can get a strong smell of gas when you're behind the car. So imagine that, but in your cabin, at every stop light. It won't smoke though. If you're comfort oriented, just go for a high flow one and be done with it.
2015 BMW 535xi
11-23-2020, 11:43 AM | #40 |
Rep 14,521
i've had mine on for quite awhile now and as long as it's installed correctly with no leaks i do not smell anything in the car. now if i'm sitting at a light and the wind is blowing over me than yes i can smell the gas. but even than it doesn't bother me at all. if you're going to be around a bunch of modified cars with everyone revving how are you not gonna smell the exhaust that's being put into the air...it just gives me the sense of it's GO TIME!!!
11-23-2020, 07:05 PM | #41 |
Rep 78
I will start with BM3 Stage2 + IC + CP for a while and do the cat mod later. Will see.
Thx for info. I was more concern into the cabin, outside I don't care. |
