Double sided tape for Carbon Fiber rear spoiler
Thread Tools |
| 03-23-2016, 10:19 AM | #23 |
USAF Pararescue Veteran
336
Rep 770
I wouldn't use rubbing alcohol, it's not real effective on wax. Instead use something like Goo Gone, Simple Green, even Windex. Something non abrasive that can remove grease, grime and wax.
| 03-23-2016, 10:20 AM | #24 | |
Rep 14,537
![]() ~F90Conversion~21"3Piece Forged AvantGardeWheels~KWV1Coilovers~CQUENCE slotted/drilled rotors~GoodridgeStainlesslines~MeisterschaftQuadEx haust~Akrapovic 4"tips~VRSF DP~VRSF CP~TurboSmart BOV~K&N filter~CarbonFiberExteriorComponents~GladenAlphaCo mponents~MatchUp7BMW~Punch P300-12T~ Follow me on Instagram: lsturbointeg |
| 03-23-2016, 10:46 AM | #25 | |
336
Rep 770
| 03-23-2016, 10:50 AM | #26 |
Rep 14,537
the windex will take care of that right?
| 03-23-2016, 11:03 AM | #27 |
336
Rep 770
It should, and it's non abrasive, so those are pluses. I attached my spoiler on my car after cleaning the area well with Simple Green, heck, I would think even Stoners Invisible Glass would work, it does great at removing road grime from windows.
| 03-23-2016, 12:45 PM | #28 | |
Rep 687
Should feel tacky after you are done. Attach the spoiler, then polish/wax/glaze/seal or whatever combo you use to detail around the spoiler as you will obviously be taking the wax off more area than just where the spoiler is going. |
| 03-23-2016, 01:28 PM | #29 |
Rep 14,537
dadysev,
| 01-02-2018, 09:21 PM | #30 |
![]() ![]() ![]() ![]() 322
Rep 717
| 01-02-2018, 09:38 PM | #31 | |
141
Rep 305
| 01-05-2018, 01:32 AM | #32 |
Rep 4,209
I'm pretty sure I used the following link for my rear spoiler on my BMW and my C300 I had for three years. Not a single issue. Just make sure when you put it on, its perfect the first time because once its on, its a pain to take off.
https://www.walmart.com/ip/3M-Super-...3=3705&veh=sem |
| 01-05-2018, 10:20 PM | #33 |
Rep 14,537
since this is an older thread and i posted here when it was created i ended up going with BetaLink just because i wanted it to fit tight and sound
| 01-06-2018, 07:48 PM | #35 | |
![]() 21
Rep 80
Had some sprinklers hit my rear deck lid one time and the water pooled on the deck at the back edge (trunk lid has that lip that prevents it from running off when parked) and with the hard water from so cal , it was a bitc% to rub out the lines that were left after the sun came out and dried the water. Seems like the spoiler would make that issue worse.....but they look cool, especially the ones that are painted to match the car
2001 530i
2004 330i 2006 X5 4.4 the beast 2014 328i 2012 535i ![]() |
| 01-06-2018, 08:32 PM | #36 | |
Rep 14,537
had a couple of dry lines but because i have the car treated with Chemical Guy's JetSeal, BlackLight and ButterWet wax it rubs right off
| 01-08-2018, 05:09 PM | #37 |
Rep 14,537
here's when i did the BetaLink. i had to use some weights in the blue bag to keep the trunk down along with a crap load of painters tape to keep the spoiler compressed.
![]() and finished ![]() ![]()
Ickdeep5819.50 |
| Bookmarks |
