2010 2011 BMW 5 Series Forum F10 N63 550i Drivetrain Malfunction |
02-12-2018, 04:03 PM | #23 | |
Rep 167
Stage1: Connection to both TMAP sensors only. This allows performance equivalent to the current Stage1 system for someone looking for a quick and simple install. Stage2: Adds in OBDII CANbus cable providing in dash map changing, boost gauge, boost by gear, stronger and smoother mapping, etc. Stage3: Adds in two pairs of wires to the DME for fueling support allowing the use of E85 fuel mixtures. Stage3+BCM: Adds in a BCM module that connects to two additional pairs of wires in the DME for direct wastegate control. With sufficient octane this allows the system to fully maximize power. n63 JB4 MAP GUIDE: Map 0: JB4 disabled Map 1: 4psi over stock additive Map 2: 6psi over stock additive Map 3: Undefined Map 4: Stock map w/ CANbus enabled Map 5: Undefined Map 6: User defigned boost additive map. Enter boost over stock values to use. Requires experienced tuner. Map 7: 8psi over stock additive, requires BCM Map 8: Undefined Firmware Updates: Current dash settings as of OBDII v1 firmware: '*************************************** 'OBDII In Dash Menu '*************************************** '0 map menu, map shown on tach (TACH shows Map) '1 Unused '2 Boost gauge on fuel, scaling in dash is 0 to boost safety setting, turns on when gas pedal is pressed 50% or more and turns itself off when you resume low throttle use. (OFF tach = 0, ON tach = 1000) '3 Unused '4 Delete fault codes. '5 1st gear boost limiter. (Tach = boost cap / 3) '6 2nd gear boost limiter. (Tach = boost cap / 3) '7 3rd gear boost limiter. (Tach = boost cap / 3) for further information - go to http://www.n54tech.com/forums/printthread.php?t=40626 |
02-12-2018, 04:24 PM | #24 |
Rep 659
02-22-2018, 02:38 AM | #25 |
Rep 2,062
I do but I deleted it to keep the confusion down.
'10 BMW X5///M - Alpine White on Sakhir Orange - JB4 w/ HCP Stage 2 BEF, NGK 97506 @ .20, SS tubing & BMC filters, gutted cats, AC Forged 312 22's, H&R 2"
'98 BMW 740iL - ///E39 M5 6spd swap, fully built engine (sleeved, P&P, cams), 3.46 LSD, H&R Stage 2/Bilstein HD, Magnaflow 14816's '97 BMW 328ci - ///E36 M3 clutch & L/W flywheel, Z4///M 18's |
