2010 2011 BMW 5 Series Forum F10 Bmw f10 LED headlights suck! |
12-02-2020, 04:20 PM | #23 |
Rep 129
Odd after I coded VLD with bimmercode I only noticed my headlights go up and down like they always have on startup. They do not move left or right on startup. Only thing I did not do change is the VO for it.
12-03-2020, 03:45 AM | #24 |
Rep 953
You also need to wait for 90s before you adjust the LED headlights as adjusting them before they go into a diagnostic setup, will only move them back to original position after a sleep cycle. You should turn the ignition on but not start the car, wait for 90s, then adjust the headlights.
12-03-2020, 08:40 AM | #25 | |
Rep 7,588
While idling and in drive...do you see the driver's side headlamp sweep 12° to the right if you engage reverse..then sweep back left 12° when drive is re-engaged? If no, then VLD is still decoded (not working). This is shown in the 2nd video I posted.
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 12-03-2020 at 08:46 AM.. |
12-03-2020, 08:46 AM | #26 | |
Rep 129
Can you please post the settings you changed for VLD? Also I have coded anti-dazzle headlights on my f10 using bimmercode and they work. |
12-03-2020, 08:50 AM | #27 |
Rep 7,588
The two LeMaster parameters below is what I used to code VLD...it only worked on my 2014 f15 X5 and the coding parameters were found in teh BDC (body domain controller) module. It did not work for my 2013 f06 650ix GC where the exterior lighting is controlled by the FRM (footwell module):
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. |
12-03-2020, 01:40 PM | #30 |
Rep 2,595
No, VO coding is for 2 things:
1. Easier coding. You add/remove the option from the FA, and just code the modules. It'll set all the relevant FDL codings to the proper settings. Think of it as a factory reset, but you changed what factory means a little. 2. Dealer won't wipe out the coding. Because you changed what the factory default is, when the dealer updates or resets the module for whatever reason, it'll preserve the VO changes. So you don't have to go back and redo the FDL codings for VLD. Honestly, if you're just adding and removing package options like adding VLD, adding 2TB (sport automatic transmission), high beam assist (HBA), etc, VO coding is the proper and much better way to go about it. Just requires E-sys. What Bimmercode does is FDL codings. FDL codings is just the slow and more tedious way to do things. Think VO coding as 2 x 5 = 10, and FDL coding as 2 + 2 + 2 + 2 + 2 = 10.
2015 BMW 535xi
12-03-2020, 02:02 PM | #31 | |
Rep 5,409
12-04-2020, 12:47 PM | #32 |
Rep 2,595
No, VO coding isn't required, it's just a better way to code. Maybe your FDL codings got wiped somehow?
2015 BMW 535xi
12-04-2020, 02:28 PM | #33 |
Rep 5,409
12-04-2020, 06:04 PM | #34 |
Rep 2,595
Hm. What's your vin? Let me check something.
2015 BMW 535xi
12-05-2020, 06:27 PM | #35 |
Rep 129
12-06-2020, 09:16 PM | #37 |
Rep 2,595
Hm, not sure. You have adaptive headlights, so not reason it shouldn't work.
2015 BMW 535xi
12-09-2020, 11:23 AM | #39 |
Rep 129
So I just came across this video and the led headlights on an euro car seem super bright. Is this a coding option?
My headlights are not even close to being this bright with the same headlights. Only difference is my car is a Canadian version. |
12-09-2020, 11:59 AM | #40 |
Rep 538
Mine are bright, but nowhere near like that either ^^. I was able to code my LED Halos to 100%. I think they were at like 60% stock. However, I don't think that you can code the headlight LED itself. If you can, I'd love to do that.
Wish I had tunnel mode..or maybe I do, but can't tell because my lights aren't bright enough.
'07 Montego Blue/Saddle Brown E92 335i - 6spd. - SOLD
'16 Carbon Black Metallic F10 535i M-Sport - TOTALED 11/21/21 '13 Black Sapphire Metallic F30 335i M-Sport - unknown charge pipe, MSport Exhaust, 20" 405M wheels, $61k MSRP, CF M4 Mirror caps & Spoiler, NGK plugs, Dinan Coils, BMS intake |
12-09-2020, 12:19 PM | #41 |
Rep 207
Although I also suspect there's a small difference in brightness between different regions, the brightness from the video may due to the camera enhancing it.
12-09-2020, 01:15 PM | #42 |
Rep 870
Anyone willing to "trade" my headlights with your "lousy" LED headlights....of course you'll have to swap harnesses too...
This is what you get from me... |
12-14-2020, 10:40 AM | #43 |
Rep 953
With everything else you've done to the car, the LED headlights will fit right in and make you quite happy!!
12-15-2020, 10:52 PM | #44 |
Rep 870
Honestly was thinking about upgrading the lights to LED...a pair runs about $3000....still debating.
This thread did make me pause...but definitely would do it for "free" (aka swap) given the chance. |
Tags |
bmw, f10, led, xenon |
