| 12-24-2021, 04:45 AM | #23 |
Rep 10
Same error code when I plugged it back in. LRE is the correct controller for the steering wheel yes (and also for my chassis).
| 12-24-2021, 04:59 AM | #24 | |
Rep 10
The leather was removed first but it was an exchanged wheel, so not originally my heated wheel as I did an exchange for my non-heated to a heated. It's entirely possible that it was damaged during the re-trim but also possible that someone did an exchange for a re-trimmed wheel because they knew theirs wasn't working and I got their broken wheel! Anyway - have spent some more time on this over the last couple of evenings. I sourced a replacement heated wheel from a 2018 F3x with only 9000 miles on the clock. I checked the resistance of the heating element and it was 2.4 Ohms, which is bang on spec. Swapped it over and it works absolutely perfectly. LED light stays on, message appears in the cluster, and the wheel heats up. I was also doing some more research online and I found a post for a different vehicle manufacturer where someone had reverse engineered the LRE module. They established that the module senses the current load and will not latch to ON unless it's within spec, so I suspect that's what the BMW module is doing. https://www.cadillacforums.com/threa...tions.1090290/ Basically - if the heating element is out of resistance spec then it will not will function. Doesn't have to be a complete short or an open. High or low resistance will do it. |
| 12-22-2023, 09:49 AM | #25 | |
![]() 0
Rep 34
With the testing of resistance in the steering wheel give an indication if the element is going bad? Cuz mine was running extremely hot, to the point where I had to turn it off cuz I couldn't touch it. Then after a couple weeks of that it stopped working. Turns out the controller module failed and it looked like it had been overheating, browned connectors. So now I am worrying that the element may be weakened and will fail. |
| 12-22-2023, 04:48 PM | #26 | |
![]() 956
Rep 1,231
...and you most certainly could use this feature in MN. The controller failure can be explained if it's been asked to drive the heating element greater than it's 100% design intent. A very common failure mode for controllers. The heating element typically fails open, so I would not assume that your heating element failed, and given that your heating element worked while the controller worked, it's unlikely it has failed due to an increase in current. I would definitely be suspect of the following two: 1. Bad thermistor reading by the controller due to a bad thermistor 2. Bad thermistor reading used by the controller due to a bad controller #1 above can be checked doing a resistance check (see earlier posts). If #1 returns a good value, you can assume that the controller was the root cause and the failure mode. The controller is the cheaper element in the system, so you go this route, and after installation, during the test stage, if the heating element is too hot, immediately save the Controller by "stop using it" before it burns up, then start looking at the thermistor. Keep us appraised. |
| 03-10-2026, 10:46 AM | #27 | |
Rep 3
| Bookmarks |
