08-18-2023, 05:23 AM | #23 |
Rep 1,167
08-23-2023, 10:39 AM | #24 | |
Rep 183
cause am planning to to lug conversion after tapping them , but am not sure should i use the insert or not .. does it have advantage ? |
08-23-2023, 11:02 PM | #25 |
Rep 1,167
I used an M14x1.25 tap to chase (clean up) the original threads after the wheel shop cross threaded the bolt. This allowed me to keep using the stock wheel bolt for a while, but the threads in the hub eventually stripped.
My attempt at making a larger thread with an M14x1.25 insert failed. |
09-07-2023, 11:46 PM | #26 |
Rep 183
n3985 i have used this helicoil and fixed the thread and on top of that i have upgraded to studs setup and using it now . i have not used any thread inserts or helicoil inserts , just tapped the thread and cleaned it and applied red thread locker and installed the studs and torqued to 25ftp.
