BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Suspension | Brakes | Chassis
BPM
      05-23-2008, 04:10 PM   #45
swamp2
swamp2's Avatar
Drives: E92 M3
Originally Posted by OC kid View Post
swamp, I'm as anxious as you are to find out. Tomorrow looks like the day of reckoning.
I will be the first to admit if it was just the 100 octane, the cold, moist, night air, coupled with the adjustment to the sensitivity of the center pedal which clouded my judgment.
      05-26-2008, 05:14 AM   #46
IRMthree
IRMthree's Avatar
29
Drives: F80
nice big reds
Current: F80 M3 ZCP
Past: E92 M3 DCT Coupe, E46 M3 SMG Coupe
      05-26-2008, 08:02 PM   #47
Jack28
HUSTLER
Jack28's Avatar
14
Drives: E46 M3-E92 M3
Originally Posted by gadget View Post
OC Kid,
Your car just keeps getting nicer and nicer.
your car is pure sickness my friend! Good job!
E92 M3 ZCP- AW/FR w/Extended Leather) Packages: ZCP, 6MT, Fully Loaded
E46 M3 - AW/IR 6 Spd, Fully Loaded. 19'' BBS LM DBK, V-CSL C/F Bmpr, Botld, Diff, V-CSL Custum IR-CF Center Counsel, V-GTR Hood, Dixis Ti 76mm, Meisterschaft Ti Sec. 1&2, EvoSport Headers, CAI, D/A Chip, tck d/a, Alcantera Headliner with Imola Red Sttitching....
      05-27-2008, 01:21 AM   #48
OC ///M
Dr. Octagon
OC ///M's Avatar
Drives: Moonstone e92 M3
^ Thanks Jack.
swamp: I finally had a chance to do the weigh-in. I also updated lucid's weight reduction thread.
Brembo 380 x 34 front rotor -------------------------------- 24.8 lbs.
OEM front rotor-------------------------------------------- 26.6 lbs.
Brembo 380 x 28 rear rotor --------------------------------- 17.0 lbs.
OEM rear rotor -------------------------------------------- 22.8 lbs.
Brembo 6 pot front caliper -------------------------------- 13.0 lbs.
OEM front caliper ------------------------------------------ 15.2 lbs.
Brembo 4 pot rear caliper ---------------------------------- 9.6 lbs.
OEM rear caliper ------------------------------------------ 12.1 lbs.
OC ///M
2013 E92 M3 Individual
Sold: 2011 E92 M3 SSII | Sold: 2008 E92 M3 SSII | Into a Wall: 2008 E92 M3 SSII | Sold: 2007 E92 335i JB
      05-27-2008, 09:26 AM   #49
KonigsTiger
Racying Dynamics
KonigsTiger's Avatar
118
Drives: E92M3 RS46 Club Sport, others
Wow, thanks for posting!! So no doubt about it now, BBK is the way to go, can't wait to get mine!!!
      06-04-2008, 09:38 PM   #50
swamp2
swamp2's Avatar
Drives: E92 M3
^ Thanks Jack.
Amazing! Bigger rotors (both diameter AND thickness) and seemingly bigger calipers and yet still lighter in both parts. I was dead wrong here. Not only must the hats be larger (more aluminum and less steel) but the cast iron discs themselves must be more vented internally.
Total rotating reduction = 15.2 lb, total overall = 24.6 lb. A decent reduction for sure but I'll still firmly believe there is no way you can feel this.
      06-04-2008, 11:09 PM   #51
mach330
You don't know JACK!!!
mach330's Avatar
43
Drives: 2011 X5 35i
sweet pix. can i see a pix of your front bumper?
Rated /// M
      06-04-2008, 11:53 PM   #52
KonigsTiger
Racying Dynamics
118
I should be getting my BBK in with lighter wheels also this month. I'll try and see if I can feel the difference. Cheers!
      06-05-2008, 01:01 AM   #53
KINGLEH
KINGLEH's Avatar
99
Drives: 00 GTR - 09 E92 M
ur crazy Mmexico!
      06-11-2008, 09:22 PM   #54
badfish
badfish's Avatar
102
Drives: E92 AW M3
2008 M3  [0.00]
Hey OC kid, how sure are you on the weight of the rear rotor? The reason I'm asking is that the difference between the 380x34 vs 380x28 is a whopping 7.8 pounds. That just doesn't seem right to me.
      06-12-2008, 11:43 PM   #55
OC ///M
Dr. Octagon
OC ///M's Avatar
I was as stunned as you....especially since they are not all that far off in size.
I am doing a swap out again Mon or Tues and will post pics with each on the scale for you.
OC ///M
      06-13-2008, 01:01 AM   #56
badfish
badfish's Avatar
102
Drives: E92 AW M3
2008 M3  [0.00]
Thanks man. I will have BBK by Tuesday. But I looked back at this thread for weight savings and saw the difference between front and back rotors and it didn't make sense. There is an error somewhere I believe and I just wanted to clarify. We're talking 6mm and different hats maybe, but 7.8 pounds is a lot of weight.
      06-14-2008, 12:22 AM   #57
OC ///M
Dr. Octagon
OC ///M's Avatar
No error badfish...just a lot more material on the fronts. It adds up.
Rears:
Fronts:
OC ///M
      06-14-2008, 02:16 AM   #58
KonigsTiger
Racying Dynamics
118
Hahahaha!! Thanks OC Kit, that ought to dispel any doubts. Thanks a bunch.
      06-14-2008, 09:28 AM   #59
OC ///M
Dr. Octagon
OC ///M's Avatar
La cosa que no puedo entender es... porque la gente no me creen?
Gracias por todo migo
OC ///M
      06-14-2008, 02:09 PM   #60
badfish
badfish's Avatar
102
Drives: E92 AW M3
2008 M3  [0.00]
Thanks for doing that. I have some doubts as to the accuracy of the bathroom scale though. I don't know about this one but I have one that varies a bit depending on where I step, I couldn't use it to weight objects with small footprints. If you still have them off maybe step on the scale with each rotor and subtract your weight (about 345 pounds) and then see if it's the same.
It does appear that the thicker rotor is a lot beefier in all aspects so that picture of the rotors themselves says a thousand words.
I'm going with a 355x32 on my rears which is about 19 pounds.
Thanks again!
      06-14-2008, 03:24 PM   #61
OC ///M
Dr. Octagon
OC ///M's Avatar
Thanks again!
Yeah... you're right, it's just a freaking $50 bathroom scale. But the tolerances on this thing are closer to +/-.5 lbs. It's not going to be that far off of actual. I determined this after weighing each rotor alone on the scale 10 different times in three different ways, including stepping on the scale while holding the rotors, and simply took averages. I knew someone would mention the bathroom scale and its inherent flaws, I just didn't think it would be you.
***The information I provided is for informational purposes only and is not meant to officially represent manufacturer's specifications, or to take the place of scientific measurement, calibration, or testing.***
OC ///M
      06-14-2008, 04:55 PM   #62
badfish
badfish's Avatar
102
Drives: E92 AW M3
2008 M3  [0.00]
Haha, no I do trust it is pretty close. Like I said, the front rotor is a lot beefier all around so that explains a lot of where that weight went. If it were the same type of design with the thinner rotor you would not see that much of a weight difference.
      06-15-2008, 05:58 PM   #63
KonigsTiger
Racying Dynamics
118
Hahahaha!!! I believe and I think everyone else does now. Or should!!!
      07-04-2008, 11:11 AM   #64
M3Mikey
Drives: Jet Black E92 M3 Fox Red Inter
the red is to gotti for me
Jet Black with Fox Red ext. Interior
      07-07-2008, 09:49 AM   #65
KonigsTiger
Racying Dynamics
118
      07-07-2008, 10:54 AM   #66
BRDHNTR
Ground Pilot
BRDHNTR's Avatar
Drives: e92 BMW M3
2002 M3  [0.00]
2008 e92 M3  [0.00]
Red works on that car, but if I was going with a set of Brembos they would have to be Black to go with my Blue car.
"The laws of physics cannot be repealed, even with DSC." - BMW Owner's Manual
m3post
