2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum NBT EVO retrofit
      04-27-2020, 06:07 PM   #45
AmooManiak
Drives: 21 X5 M50i -> M2C -> 21 M5C
Yes, I got it done. Total cost was about $1,700 with a few additional cables. The installation itself was pretty straightforward. Worst part was waiting for the items to arrive from Russia, but the guys were great with remote coding.
Before that I had the Bimmertech Carplay/Android Auto, and for about $1,000 more, this was absolutely worth it. The resolution is so much better and the added touch screen, touch Idrive controller added a nice "touch" (no pun intended.) Only thing I lost out on was Sirius XM radio.
      04-28-2020, 04:09 PM   #46
seansimsneill
seansimsneill's Avatar
Drives: 2016 535I 2000 528I
2016 BMW 535I  [0.00]
Link of seller?
2016 535i
2001 530i
et700711.00
      05-04-2020, 03:13 PM   #47
seansimsneill
Originally Posted by delje08 View Post
Found a G30 touch screen on ebay and retrofitted coded on the F10.
Still waiting for a effing response.... how did you get the screen to fit dude?????????
2016 535i
2001 530i
      05-07-2020, 09:08 AM   #48
seansimsneill
Got it [IMG][/IMG]
2016 535i
2001 530i
Poochie9095.50
      05-13-2020, 01:06 PM   #49
mlr1989
Drives: bmw f10 528i
What is the head unit model that I need? I am so confused right now!!😤😤
      05-13-2020, 01:07 PM   #50
mlr1989
I have a 2011 f10 and so far I have only purchased the display shown in the picture above, can someone tell me what all else is needed?!
      05-13-2020, 02:27 PM   #51
AmooManiak
Link of seller?
https://www.facebook.com/bmwupgradech/
      05-15-2020, 09:09 AM   #52
Jorjel
Drives: E90 LCI 323i
Originally Posted by Jorjel View Post
Indeed, that was the most challenging part in my F10 as well, especially if using an ATM emulator and a quadlock extension yo not cut car's harness.
Do you have more pictures with the g30 screen installation under the trim? Have you cut some parts?
Did you do this set up as well? Really hoping someone had more details
Yes, have used the extension harness and also i stalled a g30 screen under the original frame.
To make it reusable in another application i have i stalled a screen protector on the screen before glueing it to the frame and build a custom bracket on the back. I would use a g01 screen as it's a bit smaller and easier to fit in.
      05-26-2020, 12:41 PM   #53
seansimsneill
Did my g30 screen on the outside. Easier to use touchscreen. Also fabricated a backing so its clean with no hole
2016 535i
2001 530i
Poochie9095.50
      05-26-2020, 03:10 PM   #54
philipm785
Drives: 2016 550i
Nice job!
      05-31-2020, 02:45 PM   #55
addy27
Drives: F10 550i
Looks great but im sure you thought of trying to install it in the same spot as the OEM screen right? Was this a hard no due to the dimensions or you think you could have installed it in the OEM spot? I'm thinking about it even though I just completed the NBT retrofit, the EVO with the CarPlay is quite enticing..
      05-31-2020, 06:53 PM   #56
seansimsneill
Nah i wanted the new look plus with the touchscreen its a tad bit closer. It can out super clean. I got a guy that i got the unit from and he coded it. We did the atm as well so i still have ConnectedDrive and remote service.
2016 535i
2001 530i
      06-07-2020, 12:30 PM   #57
cyclone111
Kazakhstan
Drives: 2020 M340i XDrive
Need help with NBT Evo pinout
Hi all,
I have installed NBT Evo and all works nice, but my car (2012 F06 640i) has analog TV tuner and DVD changer. Could someone advice where in quadlock I need to plug in video input from them? I don't have videomodule and car is pre-LCI, so have some struggles with reading schemes in newTIS.
      06-09-2020, 02:10 PM   #58
addy27
Drives: F10 550i
There should be only two FBAS port on the quad lock for NBT/NBTEVO, one at pins 21(+),24(-),23(Shield) the other on pins 27(+),28(-),26(Shield). If you switched from CIC, the move your video pins from current location to the ones I just mentioned. The next step would be to change/edit the "werte" setting in HU NBT EVO and try to see which one of the 4 settings works. (Could be Werte 41, 42,43 or 7 I think). You can try one at a time and see which one works. For me, I have NBT only and I have Nivi on 42, TRSVC on 41, DVD on 43.
      06-20-2020, 11:30 PM   #59
rvashi
rvashi's Avatar
Drives: BMW M5
I’m a bit confused....So is there a hole where the original screen was? Because otherwise, how did you get the cables to the new screen if the old screen is still attached, because there would be no space to pull the cables from.???
      06-21-2020, 08:43 AM   #60
AmooManiak
Hey, that looks awesome. I recently did an install but like your backing much better. How did you do that? Would you be willing to fabricate and sell another one?
      06-24-2020, 10:47 AM   #61
dzz
Drives: 2015 BMW 535xi, MHD Stage 2+
2015 BMW  [0.00]
I'd be interested in backing plate(s) too
      06-24-2020, 11:02 AM   #62
AmooManiak
This is what I did after I posted that - I ordered this panel, which will cover most of the back and allow me to properly mount the Evo screen. It will probably take a few weeks to get it, but I think it's the best way to ensure that it looks as OEM as possible.
The hole on the plate of my original screen was much bigger, so there was still a big gap, which is why I didn't use it.
https://www.ebay.com/itm/BMW-OEM-ORI...3269%7Ciid%3A1
      06-24-2020, 11:48 AM   #63
dzz
2015 BMW  [0.00]
I have seen G01 touchscreen (which is still 10.25" big) but smaller in overall size than G30 screen being fit into F10 screen enclosure so it looks almost stock, see pics. I am thinking of doing this since G01 just needs F10 screen plastic frame, some cutting and glue to keep it in place and it look stock for most part.
      06-24-2020, 03:17 PM   #64
AmooManiak
I'm sure that will look nice.
I prefer it being closer to make full use of the touch display without having to reach forward.
      07-09-2020, 08:51 PM   #65
AmooManiak
I finally received my 6.5" plastic cover from Belarus today, and am getting close to finishing the project. It is not 100% yet as I need to fix some rough edges, but I would say it's 95% done.
Hands down this is my favorite mod so far on the car because I use it on a daily basis. I had the Bimmertech Android Auto/Apple Carplay on my NBT unit, but this experience with the G01 screen is so much better.
      07-14-2020, 11:12 PM   #66
dzz
2015 BMW  [0.00]
It looks good. Did you put any backing plate on the sides of G01 screen? It is hard to tell on the pics if there is a black plate or a hole.
