| 02-08-2014, 02:20 AM | #46 |
![]() 10
Rep 156
| 02-08-2014, 08:32 AM | #47 |
![]() 37
Rep 81
I picked up a used 550x last week and immediately noticed the slight Highway vibration and drone. Seems to happen around 70 mph and feedback is mostly in the steering wheel. I changed tires which helped but not eliminated. I had chalked it up to terrible western pa highways but may be it is something else. Cars has brand new tires and an alignment.
| 02-08-2014, 09:26 AM | #48 |
![]() 10
Rep 156
Mine is perfectly balanced and aligned on bmw's machine with good even wear on all tyres and the vibration noticeable from 65ish. Wife hasn't noticed so cant be too bad
It Frustrates me though. |
| 02-08-2014, 10:12 AM | #49 | |
![]() ![]() ![]() 6589
Rep 15,857
HighlandPete |
| 02-08-2014, 12:27 PM | #50 | |
![]() 37
Rep 81
| 02-08-2014, 05:47 PM | #51 | |
![]() 10
Rep 156
| 02-09-2014, 02:48 PM | #52 | |
Rep 15,857
There are frequency dampers on the rear sub frame and differential casings on some models. I think the 525d has both, worth checking if you have them fitted. If so, I'd be tempted to experiment with removing one or the other, to see if the vibration changes. BMW do list different HZ values across models, build dates, so there is scope for BMW to try options, if you have a supportive dealer. You can put you VIN number in RealOEM and look at the rear axle assemblies, your exact spec' for vibration absorber frequency will be identified. HighlandPete |
| 02-09-2014, 04:02 PM | #53 | |
![]() 10
Rep 156
it's great advice and something I'll explore if the tyre and wheel situation is not a fix. However It still occurs if the gearbox is put in neutral whilst moving so would this disprove your theory? Thanks so far. |
| 02-10-2014, 04:16 AM | #54 | |
Rep 15,857
I tracked the other user who was going to experiment, he traded his F30 back in for another car before getting to change parts. His next car is fine. Not sure if being in neutral would take it away if it is caused by a rotation induced vibration, could still be either diff or sub frame absorber which could cancel it out. Does it change at all, if on or off the throttle? I recall this sort of thing years ago, often it was the prop shaft balance that caused issues. Usually through a wide range of speed. A common solution was a couple of jubilee clips, mark a start point then experiment with rotating the two 'lumps' until you eliminated the vibration. Could take a few attempts to get it sorted. I can't imagine BMW having individual component balance issues, more likely a stack issue on some examples, if it is a drive train vibration. HighlandPete |
| 02-11-2014, 07:28 AM | #55 |
Rep 61
Drives: BMW 528i M-Sport and BMW X1
Greetings people!
I have the same issues with a slightly vibration at the rear tire.Problem happened when I upgraded to 19" from 18".Currently using M Performance wheels 313 type wrapped with Dunlop Sport Maxx Gt. ![]()
BMW X1|sDrive 18i|Black|
BMW 528i M-Sport 2012|Alpine White| |
| 03-04-2015, 03:00 PM | #57 |
Rep 8
I am driving an F32 430d, having the same issue. Very annoying vibration felt in the whole car. Starting at around 120 kph. Had different rims, tyres on. Had balanced several times... I am about to have a deal with my dealer to trade in my F32 for an F10 530d. So I started trying F10s of my friends. The first one was a pre-LCI 530d had exactly the same vibration, the second one was an LCI 525d and, guess what, had exactly the same vibration. I'm damn confused now...
Do I have the right understanding that the only member here who had the problem resolved is smudge973 with the 5 bolt lug hole balancing? |
| 04-04-2016, 07:50 PM | #58 |
Rep 2
bmw f10 vibration issue 2011 530d
hi i have that issue with vibration between 60 to 80mph
did anyone manage to found what it was causing it cause i real all forums in germany in russia uk and usa but did not found resolution for it..... thanks |
| 04-04-2016, 08:22 PM | #59 |
Dream crusher
1043
Rep 2,420
My vibration problem was the run flats switched to non run flats and life is good. Pulling is a separate issue.
IG: @bmwdoubles |
| 10-10-2017, 02:29 PM | #60 |
Rep 4
Vibrations
I have had terrible vibration problem with my F06 on 20 inch OEM wheels since buying it in April this year. Got so bad every now and then that I was convinced a wheel was coming loose so I stopped to check them.
I had the wheels balanced 4 times. I replaced all 4 tyres (Bridgestones). I replaced the front disks and pads (Zimmermann's). But the vibration still there. The vibration wasn't constant. It came and went every 20 or 30 seconds, but never stayed the whole time. I researched and spoke to "pros" and they said if it comes and goes it would not be tyres. They said it would be bearings, bushes, ball joints, engine mounts, suspension components or prop shaft. But not wheels / tyres.... So, I learn't about road force balancing. Had that done today at The Tyre Shop in the UK (highly recommended ) and have driven 70 miles and not a single vibration. The car drives spot on. £95 well spent, even though it seemed a lot for wheel balancing. BMW want £90 for an hours diagnostics....... Hope that helps others. Bite the bullet and give it ago before replacing components. http://www.balancemycar.co.uk . |
| 12-31-2017, 03:48 PM | #62 |
Rep 1
I have a BMW 2011 F11 525D M-Sport, I am experiencing vibration at between 60 and 70 mph.
I got my local garage to do a balance on all 4 wheels to start with, but that had no effect what so ever! I then came across this thread and wanted to say a big thanks to akroblade954 for pointing me in the right direction and saving me a lot of time and money working out what was wrong! Using http://www.balancemycar.co.uk I found 'Discount Tyres Luton', who did a professional job. They have a Hunter Road Force Balancer and found that all 4 wheels were balanced, but had 'run out' (egg shape) and 'Force Variation' (sidewall stiffness) issues. I have just bought the car and it had budget tyres fitted. ![]() One of the wheels with was within limits, but the other three were too far out and need to be replaced. One tyre was the worse tyre that the technician had ever seen, I think it was the 'Force Variation' that was 380lbs out! He span it up for me on the machine and you could easily see visually that it was way out! The technician said that it should be no more than 80lbs out normally.To my mind this seems to be more of a problem with manufacturing defects in lower profile tyres, that are not being picked up by just balancing alone! As you can balance an egg-shaped wheel no problem, but it's going to vibrate the crap out of the car, so I found out! I think that the car in my case was doing quite a good job keeping it all together until 60mph quite frankly. I have just ordered a set of 4 x Goodyear Eagle F1 Asymmetric 3 tyres to be fitted in the new year. So hopefully this will fix the issue for me! |
| 12-31-2017, 08:48 PM | #63 |
![]() 15
Rep 39
So, I noticed the same exact thing on my car on my way home from buying it! At 75 +/-5mph, the (passenger) head rest, steering wheel, etc...would vibrate like crazy.
Had the tires balanced and the tech said two rims were bent. Took them to get straightened and found that they were 0.090 and 0.110" run out (2.5-3mm) . Got those two fixed and its probably 70% better. I feel like the other two are bent as well. I paid $260 to have 2 straightened, balanced, and mounted. 2014 M-sport 550xi (19" rims).
2022 M550i 2015 X5 XDrive M-Sport/BM3 Stage II 2014 550xi M-Sport/BM3 Stage II/Catless DP/Comp Exhaust 2002 RSX-S 2.4L on corn spooling 62mm=550+whp/2500lbs ![]() |
| 11-06-2020, 12:31 PM | #64 | |
Rep 1
| 11-06-2020, 03:09 PM | #65 | |
Rep 6,358
| 06-18-2022, 06:05 AM | #66 |
![]() 9
Rep 36
70-80mph Vibration FIXED!
I know this is an old thread but...
I had exactly the same issue on my F10 520d MSport from when I bought it a year ago. I changed tyres, all the brakes, suspected buckled wheel so I bought refurbed wheels but nothing solved it. Then, last week, the lower coil snapped on the rear spring. I had them changed for BMW original parts at my local indi for £375 including the springs and the wobble has dissappeared. The car drives sublime again. Rear has firmed up too. The road force thing is junk, don't waste your money. I've been searching for a solution to this issue for a year now and hundreds of people seem to be having this issue please spread this solution.
2015 520d F10 Saloon B47 351 Alloys
| Bookmarks |
