2010 2011 BMW 5 Series Forum F10 Brake upgrades from other BMW models on F10 |
05-23-2023, 04:33 PM | #639 |
Rep 252
Got my 4pots on today and i too need a 5-6mm spacer for center
05-24-2023, 09:23 AM | #640 |
Rep 1,061
Did you try the 4mm Case washer first and the pads wouldn’t fit, or are you measuring to perfect center? On mine the pads BARELY squeezed in with the 4mm washer.
05-24-2023, 04:39 PM | #641 |
Rep 252
Thats a 4mil in there now, i was looking at center but i am running Powerstops slo&drilled also so might be a diff than what most ppl running.
Blue Angel1042.50 |
05-24-2023, 06:20 PM | #642 |
Rep 252
Oh and one more thing bout the brake job i had done for me was a good freind of mine owns a shop with a lot of expensive equiptment that sucks & blows got my pedal 💯, i dont think it can get much better🤌🏾
05-25-2023, 05:07 AM | #644 |
Rep 34
Blue Angel1042.50 |
05-27-2023, 05:59 PM | #645 |
Rep 252
I went ahead and cut my OUTSIDE pads only for some odd reason it worked, it feels like factory for break in but i havent been driving it since then. Ill get back on it soon tho.
Blue Angel1042.50 |
06-22-2023, 08:06 AM | #646 | |
Rep 423
I have a set on mine as well, however the top hats are too large and I had to modify my pads to make them work. I would like to find a set of rotors that are drilled and slotted that I can use that won't require modification. Oh, I have the 374mm pistons.
Checkout my YouTube channel, Like and Subscribe. https://www.youtube.com/user/Gjohnson7771 MHD Flash, RVG Catless DP, RVG CP, RVG Boost Pipe, Walbro 455 LPFP, Style 433 Wheels, BC Coilovers, Ebay Strut bar, M-Sport Front Conversion, RVG FMIC, 6WB Cluster. |
06-22-2023, 10:28 AM | #647 | |
Rep 252
06-22-2023, 12:46 PM | #648 |
Rep 1,061
06-22-2023, 12:54 PM | #649 |
Rep 252
Blue Angel1042.50 |
06-22-2023, 04:23 PM | #650 |
Rep 1,061
Got it - I had forgotten about that but remembered as soon as I saw the slots extended. Thanks!
Still waiting to see some up-close pics of how this covers the 750 rotor face. I also have concerns about whether the piston will be centered enough to avoid uneven pad wear. Hopefully there’s lots of feedback about this by the time I’m in need of new rotors because I actually prefer the way the 750 rotor looks with the larger hat. Also, I find the huge swept area of the 760 rotor gets rusty in winter driving and the reduced pad pressure (same force, larger area) has trouble cleaning the rotors. This could also be the mild natured pads I have… a more aggressive pad might scour the rotor better. I’d be in favor of slightly more dust in exchange for cleaner looking rotors. |
Double Nickel168.00 |
06-22-2023, 05:50 PM | #651 |
Rep 38
I've compensated for that reduced pad pressure by changing to the M5 brake booster and M5 brake cylinder. Pedal feel is at least on par with the stock setup, might be even better. I'm very pleased with the outcome of that.
Using the 760 rotors, Textar brakepads. |
Blue Angel1042.50 |
06-22-2023, 09:13 PM | #652 | |
Rep 1,061
Did you need to change the lines from the master to the distribution block below? The parts diagrams suggest new lines are needed. So many questions I have! As you can probably tell I got about halfway to getting my research done and haven’t had time since. How much disassembly was needed under the dash? Any parts required that are not obvious? Any info you can offer would be VERY helpful! |
06-23-2023, 04:24 AM | #654 | ||
Rep 34
34326790148 Quote:
Under the dash you need to remove the footwell trim panel and then you see the nuts of the brake booster. In Dutch https://www.bimmerportal.nl/forum/vi...?f=538&t=63807 https://www.bimmerportal.nl/forum/vi...?f=538&t=63595 |
Blue Angel1042.50 |
06-23-2023, 05:39 PM | #656 | ||||
Rep 38
ptrkp and I both did the same brake upgrade when it comes to calipers, pads, disc size. In my car we also did the M5 booster and master cilinder and that setup performs even better. Especially when you don't press the pedal hard, the initial bite is better. Not like night/day difference, but noticable. Quote:
I did get a new foam gasket to use inbetween booster and firewall. Taking the master off the booster will make your life a bit easier when installing, we fought mine in as one unit which was a bit of a headache but you can pull it off that way. Bleeding was done on both cars with the official procedure via ISTA. |
Blue Angel1042.50 |
06-25-2023, 06:44 AM | #658 | |
Rep 34
Piston Diameter [mm] : 22,2 https://aftermarket.zf.com/us/afterm...xt=34336796729 Brake Booster https://aftermarket.zf.com/us/afterm...xt=34336792956 M5 Piston Diameter [mm] : 26,9 https://aftermarket.zf.com/us/afterm...xt=34336799903 Brake Booster https://aftermarket.zf.com/us/afterm...xt=34337846664 |
07-02-2023, 05:09 PM | #659 |
Rep 15
Been running G11 Calipers for 3 years
My old post from my F01.
https://www.bimmerfest.com/threads/a...#post-13329695 Also used F32 two piston calipers for the rears. No modification there. I got around to do a brake job today, and again had to modify the brake pads to make them fit. However I did notice on the brembo calipers there are dimples next to the old holes for the pad retainer pins. I think you could redrill those holes so that you can accept different pads. Then you don't have to modify pads to get them to fit. I would only do it if I had the calipers off the car and had a drill press to get the hole perfectly perpendicular. In addition, I didn't want to shell out $160 for EBC pads so I got these cheap power stop pads for < $50. If you choose to modify the mounting holes on the pad: https://www.amazon.com/dp/B0741RMXM9...roduct_details If you choose to cut 20mm off the bottom of the pad: https://www.jegs.com/i/Power-Stop/419/17-1868/10002/-1# Will see if these dust less. |
07-03-2023, 01:07 PM | #660 | |
Rep 1,362
So by doing the rear caliper, you give up parking brake? |
