06-26-2017, 01:17 PM | #1211 | |
Plenipotentiary
2616
Rep 3,046
06-27-2017, 09:57 AM | #1212 |
Rep 165
Drives: BMW M760e xDrive (2x)
G11/12 Hybrid
Is there any information about a battery update for the hybrid 740?
I heard that a more powerful battery and using less trunk space should be coming... perhaps for the LCI 2019? |
06-28-2017, 02:32 PM | #1213 | |
Rep 306
I'd be more interested in the 2 series replacement. UKL or CLAR, FWD or RWD? |
nozydog465.00 |
06-28-2017, 04:26 PM | #1214 |
Rep 19,368
As discussed a few months ago, it sounds like RWD given the G42/G43 chassis codes. Nothing is absolutely guaranteed at this point, of course. The F22/F23/F87 LCI is just going into production next month, so it may be a bit yet before we see any next generation mules.
07-20-2017, 03:07 PM | #1215 |
Rep 7
M5 Plans
I'd love to know what they have planned for the M5 down the road. Also about the warrantee issues they seem to be having.. Lots of people getting flagged at the dealer for simple things like different tire/wheel sizes etc.
07-21-2017, 02:11 AM | #1216 |
Rep 162
The i3 news in July update is very good, but I wish they waited with facelift update until the battery upgrade is available. Too many versions...
64Ah 94Ah 94Ah facelift 120Ah |
07-22-2017, 01:33 AM | #1219 |
Rep 364
07-22-2017, 08:57 AM | #1220 |
2006 TIME Person Of The Year
9694
Rep 6,445
The spec isn't useless because the voltage is known. 360 volts. I'm not an automotive engineer but amp-hour seems like the most appropriate spec to point to when describing the sustained power a battery can provide. This predates EVs.
07-22-2017, 09:59 AM | #1221 |
Rep 364
It's not sustained power or sustained amps, it has always been about stored energy. Amp hours on standard AA batteries make sense since the voktagd is generally known and all manufacturets use the same units so you can easily compare between brands.
When it comes to EV's, different manufacturers use different voltage which means you can't easily compare battery sizes based on Ah. You must compare using a unit that directly tells you max stored energy. That is commonly kWh although the SI unit is J. |
08-07-2017, 05:25 PM | #1224 |
Rep 162
BimmerMat135722.00 |
08-28-2017, 12:37 PM | #1228 |
Rep 19,368
Thanks for the update. I had no idea a 1.2L B38 even existed.
Regarding the B58, wikipedia suggests the 250Kw version is actually called the O0. Is that incorrect? It did seem strange to me that the X3 M40i specs call its new 265Kw version the M0, which is the name the original 240Kw version goes by. I agree it would make more sense if, as you say, all of them are M0 than if only the middle child is O0. Still nothing about a new V8 family, eh? Rumors suggest that the 8 Series will get a 4.0L V8 which would presumably be all new rather than simply an N63 with less displacement. |
08-28-2017, 01:00 PM | #1229 |
Rep 195
EOP for Current Models F22 2er - 10/21 F23 2er - 10/21 So does that mean the current 2 series/M2 will last until 10/21? That would be a long overall generation. |
08-28-2017, 01:12 PM | #1231 |
Rep 2,885
Probably the S58 which is also slated for the X3M.
2022 G83 PCD & 2024 G05 S68 PCD
Retired:2021 F95 ZCP PCD,2018 F85 PCD,2018 F83 ZCP- ED/PCD, 2015 X5 50i PCD, 2015 435 vert ED, 2011 X3 PCD, 2011 335is vert ED/PCD, 2007 X3is PCD, 2007 335i vert PCD, 2004 328i vert PCD |
mkoesel7537.00 paliknight2196.00 |
08-28-2017, 01:15 PM | #1232 |
Rep 2,885
I believe the F90 went from Tu 2 to Tu4; wonder if the S63tu4 will be further tweaked for the future X5M/X6M just the current generation was?
